November 23, 2024, 06:28:47 am *
Author Topic: Interrupt Mechanism out of order  (Read 17791 times)
crisnee
« on: September 19, 2011, 07:45:54 am »
Interrupt Mechanism out of order; Notify XXHighEnd development (Restart Playback)
I am reporting as commanded by XX-6. Guess what I did to engender this command. Trackus Interruptus.
-Chris
« Reply #1 on: September 19, 2011, 08:09:18 am »
Tell me ...
(if that was a question)
crisnee
« Reply #2 on: September 20, 2011, 02:30:57 am »
The answer was right there. Trackus interruptus--a play on... ok nevermind, not fair.
I interrupted the track; tried to stop a track and start another. Tried it several times, always the same message. Happens right when stopping the track.
-Chris
« Reply #3 on: September 20, 2011, 07:14:03 am »
Ah, so not at starting, but at stopping eh ?
Hmm ...
crisnee
« Reply #4 on: September 20, 2011, 09:08:23 am »
Hmm ...
Yup.
Edit: Let me add to this already lengthy post. I'm using AntiImage for the first time (if that matters) because the Audio-GD only does 96 and 192.
« Reply #5 on: September 20, 2011, 09:55:30 am »
Is that with Attended or Unattended ? (not that I see the real difference).
Well, what happens if you don't use any filtering at all ?
(I think I wouldn't apply filtering in your case).
crisnee
« Reply #6 on: September 20, 2011, 10:18:29 am »
Attended. OS minimized.
Interrupt problem remains with AntiImage off.
If I want to upsample, the track won't play without AntiImage on.
« Reply #7 on: September 20, 2011, 10:36:02 am »
Ah, that thing.
Ok, thanks.
When you have some spare time, can you please post the XX, X3 and X3PB log files from the moment the message is on the screen ?
Please restart XXHighEnd just before that, so the log files will be more clean. Before quitting XXHighEnd maybe also use Off to stop the Audio Engine. Notice though : exactly this latter may incur for everything being ok. If that happens, just press Stop, and Play again. Then the message should occur again (if it happens "always"). Ok ?
Shouldn't you be sleeping ?
« Reply #8 on: September 20, 2011, 10:45:19 am »
PS: I think I said something strange about the Play - Stop sequence for when it doesn't happen the first time. I mean, since it happens when you Stop ...
crisnee
« Reply #9 on: September 21, 2011, 04:23:50 am »
I'll send the logs eventually. It's a bit of a pain to do anything other than listen to music with that computer.
-Chris
HAL9000
« Reply #10 on: September 29, 2011, 08:47:36 pm »
Hi Peter.
count me in.  I have the same issue here.
Comes when pressing play.  I have to first push stop then play to avoid it.  Tricky that the message comes behind xx-window  Wink took a little while to figure out the first time. Happy
I do not use minimize OS.  setup is pretty much standard.
But sound is awesome Happy
Jan
*Windows 7 Home Premium 64bit SP1, CORE i7 2600k / Engine#4 Special Mode / Q1/2/3/4/5 = 14(4096)/1/1/1 (Dev.Buffer = 4096)/*ClockRes = 15ms*/*adaptive*/*SFS = 0.40*/ not Invert Phase / Arc predict / Peak Extend / Playerprio = Low / ThreadPrio = Real Time / Scheme 3-5 / 2x Upsampling / MOTU 2408mkIII SPDIF to Metrum Octave DAC -> Abrahamsen main amps -> DALI MEGALINE
« Reply #11 on: September 29, 2011, 11:21:29 pm »
After starting up with my NOS1 USB I got those anoying messages too.
But they disapeared after I did the following:
Reboot PC.
Starting to use "minimize OS".
Adopted some clock and memory settings, essentially those in Peters signatur.
« Reply #12 on: September 29, 2011, 11:21:32 pm »
Thank you Jan. Still strange, but good to hear from as many as possible that this can happen.
But ...
This puzzles me a little. So what are you saying ? that pressing Play *without* Stop causes the message ? If that is so ... I guess I never thought of people doing that (although it should work anyway .. but regarding this ... hmm.)
Please let me know !
crisnee
« Reply #13 on: September 30, 2011, 08:24:14 am »
Well just to add to the confusion, or lack there of, my interrupt error has miraculously corrected itself. In other words, it don't happen no more. Don't ask. Alright go ahead. I don't know.
Really! I can't think of anything I've changed, certainly nothing that should effect such a change. I run pretty standard settings.
-Chris
« Reply #14 on: October 01, 2011, 09:36:30 am »
But I do by know. yes
It goes wrong when the Thread Priority is set to "Nothing".
So people, change that into an explicit value, and for 0.9z-6 it will be okay.
Will be solved for the next version.
