November 23, 2024, 08:25:27 am *
Author Topic: Remote command for Volume Up and Down doesn´t work  (Read 10112 times)
« on: September 18, 2011, 12:17:58 pm »
Remote command for volume up and down (Alt+U and Alt+D) doesn´t work using Unattended,  Monitor Off and Minimize OS. To use the remote command I have to start XXHighEnd.
The other remote commands seems to work properly.
« Reply #1 on: September 18, 2011, 12:38:51 pm »
No "Interrupt out of order" messages ?
Please apply Alt-U (or -D) during Unattended, and one minute after this was applied and nothing happened, grab the log files (XX, X3, X3PB) and post them please.
Monitor can be left On.
Thanks !
« Reply #2 on: September 18, 2011, 12:47:31 pm »
Additionally : Is this Alt-U etc. on the keyboard, or via an actual remote ?
And, make the "XX log file" the last two (most new) of them !
So, that will be 2x XX, 1x X3 and 1x X3PB.
« Reply #3 on: September 18, 2011, 01:34:14 pm »
Thanks !
- No messages at all
- Where are the XX, X3 and X3PB files?. Sorry, but I can´t find them.
- The commands are on the keyboard
- Again I don´t know how to find the "XX log file".
Thanks, Juan
« Reply #4 on: September 18, 2011, 02:39:21 pm »
You need to have 'logging' active. Look at the very bottom of your configuration options to enable it.
After that is done, you will see a folder in your 'install' folder called 'Temporary' ( i think it's called). You will find the log files ( which are in plain text format actually) in there.
Bundle up those Peter needs, either in a zip or individually, and attach to a post in this thread.
« Reply #5 on: September 18, 2011, 04:03:59 pm »
Thank you Russ!!
Here I attached the log files for Peter
* XX log files.rar (25.28 KB - downloaded 479 times.)
« Reply #6 on: September 18, 2011, 06:54:21 pm »
Thank you Juan. The log files tell much. But no clue yet what actually is going on.
For now : just set the Volume to maximum, so you can be sure you don't need to set it higher.
swoon
« Reply #7 on: September 18, 2011, 07:38:17 pm »
Ok, thanks Peter
