November 23, 2024, 04:31:33 pm *
Pages: 1 2 3 4 [5]  All
Author Topic: SFS Privileges  (Read 61594 times)
« Reply #60 on: October 04, 2011, 03:03:16 pm »
The remapping of PCI memory is in the Chipset > Memory settings of my BIOS not in the area for video card settings.
Well, still can't find "remapping of PCI memory". In fact, there is no option whatsoever for "chipset", though it is shown in the BIOS system information screen, but its grayed out which I believe just means it's stating the info regarding the chipset.
 Anyway, in the "Advanced" tab I selected the "Integrated Graphics Config" and changed the "DVMT/Fixed Memory" from 256 to 128. That resulted in my being able to select any SFS, even 2000 SC, though I still had to start with the MC 200 SFS first. Clearly these huge SFS's were "fake." After playing around with things to try to get real SFS changes, about 40 minutes (turning off the minimize OS, several reboots, etc.), it started to "work" again: Going above a SFS of 400 resulted in a SFS error message and there was a clear difference in sound between a SFS of 200 and 400.  What's really strange though is that XX now acts like the OS is not minimized:  the first time playing XX after a reboot, with the OS minimized, the stop services screen takes forever to disappear, just like it did before the "Minimize" feature. BUT, I am able to get a SFS of 400 (anything larger gives an error) which I could only get with the OS minimized. Not sure what's going on.... wacko Though I do have my good sound back.
« Reply #61 on: October 04, 2011, 03:13:11 pm »
SFS freak !
haha
I think I will put up something like 0.9z-6-1 today, so at least you can't confuse yourself with combinations which won't work anyway. I don't say you do, but I will say that I don't understand much of it anymore. So, it will be more for myself, ok ?
« Reply #62 on: October 04, 2011, 03:41:31 pm »
Sounds good Boss. (If you haven't seen Zorba the Greek, you should.)
« Reply #63 on: October 04, 2011, 08:41:39 pm »
Hi Nick,
I find that if I set SFS=500 with Straight Contiguous then provided I play a file via XX as soon as possible during the boot sequence then XX works fine (i.e. Engine3 grabs SC memory before other apps. do). However, if I let my PC go through the whole boot sequence go off for a cup of tea, wonder around, have a chat, read the paper then come back and play a file then I tend to get SC alerts and will not run on SC.
The strange thing is that provided I have been through the procedure of a reboot, run XX as soon as possible so that XX works on SFS 500 & SC then for all subsequent reboots there is no problem running on SFS 500 on SC even if I do not rush to run XX after a reboot. I cannot think of any reason why this should be - maybe there are some subtleties of memory allocation that are not obvious.
SFS=500 is about the max I can get easily and as Nick states above it is possible to coax it higher. It seems although I have 12Gig of memory this does not particularly help in getting a bigger SFS.
Question for Peter SFS=500Mb is shown in settings in XX so why does Engine3 grab over 3Gigs of memory what is the relation between SFS size and actual memory used?.
P
Hi Paul,
I also tend to play as soon as possible after booting. As Peter mentioned this seems to have a better chance of getting the memory allocated. You would think with your 12Gb there would be a very long run of continous memory somewhere  Happy
Best Nick.
« Last Edit: October 05, 2011, 04:21:33 pm by Nick » Logged
« Reply #64 on: October 05, 2011, 10:50:51 pm »
Hi Nick,
I have to say that I was expecting a bigger SFS to be possible with 12Gig of memory. Maybe there is a limit in the o/s regarding the amount of contiguous memory that can be allocated to one programme otherwise it does seem odd that 12Gig does not allow significantly more. I can easily get 520 on a normal boot but not more. It is possible to nibble away and get more but it will be lost on a re-boot.
P
« Reply #65 on: October 06, 2011, 07:13:39 am »
Around 500 is the absolute maximum; this is related to the audio engine being a 32 bit application (which it will stay for a while).
In the end it is about how much can be played from memory, and how "gapless" it will be. This means all has to be several times in there. So, the 2GB available is enough for an album to be there twice (think 800MB max for an album), but it is far from enough when we start to upsample that to 705600 in 32 bits (now suddenly an album is 25.6GB. See ?
As soon as 2 albums don't need to be gapless (and they don't of course) and 1 would fit in memory, all is different (could be setup differently by me). But 1 won't fit ever. Not with these upsample rates.
Don't think the 12GB in your PC isn't useful, because it allows for an easy contiguous memory allocation. Although these days it goes with 8GB as easy. Maybe with even far less.
« Reply #66 on: October 07, 2011, 12:14:37 pm »
Well Z6-1 works as described: changing SFS restarts the sound engine. The result is that I can't get a SFS larger than 200, so I'll be using Z6 instead. Call me crazy, but I get a much less "articulated" sound with a SFS of 400 which I can get with Z6.
Perhaps someday the Maestro will figure this out.  Happy
« Reply #67 on: October 07, 2011, 02:03:54 pm »
So what you are saying is that with 0.9z-6 you are able to allocate 200, -watch the memory *increased* useage- and next allocate 400 and see double of the increased memory used. Right ?
« Reply #68 on: October 07, 2011, 06:19:47 pm »
A rhetorical question of course... Happy What can I say? The sound is the sound. I sent you some pics in case they offer any clues.
« Reply #69 on: October 07, 2011, 07:25:55 pm »
I can get 300 now. Don't even need to start MC first.
I play as soon as i can as Peter said we should do.
