November 23, 2024, 07:08:04 pm *
Author Topic: No sound after returning from stand-by?  (Read 8554 times)
« on: September 15, 2011, 09:07:01 am »
I would like to have the PC running (ie on stand-by when not used) but once it went to sleep I can't get any sound without rebooting.
I can prevent it from going to sleep but then the remaining activity while I am not around is only consuming energy and to me this seems a waste...
Any ideas? Perhaps it will not be a problem after the USB upgrade?
« Reply #1 on: September 15, 2011, 09:17:47 am »
Hey Bert,
This is a (commonly known, in general I mean) problem since Vista. So, I always let it run ...
Maybe if you Google for it, by now there's a solution. It could be (or actually should be at last) that this was solved in SP1. I never tried anymore ...
PS: Recovering from it (the standby) is slower than a cold boot. Maybe that helps ?
« Reply #2 on: September 15, 2011, 09:18:10 am »
Hi Bert,
I suspect it's the drivers for the Juli@ card non getting re-initialized. Happens here also with mine. I just try and remember to reboot after coming back from hibernation. I'm quickly reminded when I forget and no sound eminates Wink
« Reply #3 on: September 15, 2011, 09:20:45 am »
Still existed under SP1.
« Reply #4 on: September 15, 2011, 01:47:46 pm »
Okay, understood. It is a common problem but I do not want to waste the energy...
No, it does not help but perhaps you could enlighten me by telling me that this problem will not occur with the NOS1 through USB?
« Reply #5 on: September 15, 2011, 04:11:08 pm »
I don't know. And I'm afraid I am not going to try either.
*If* it would work, it might not a next time. It is just unreliable (like in general all the Energy Saving settings are from off Vista).
