November 23, 2024, 09:44:20 am *
Author Topic: 0.9z-6 RAR'd now ?  (Read 7565 times)
christoffe01
« on: September 12, 2011, 09:44:45 am »
no ZIP compression, which I can open with W7,  for the program anymore?
best
September 02., 2011 (due 0.9z-6)
Plain Windows 7 Prof 64bit on SATAII spinning disk, / Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *6*/0/0/0/0 (Dev.Buffer = *512*)/ClockRes = *10ms*/Mixed/SFS = 200/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended (Just Start) /All Services Off + No Running Time / / 4x Arc Prediction Upsampling /-> WEISS Minerva -> main amp
« Reply #1 on: September 12, 2011, 09:53:33 am »
Somehow I have problems with W7 and using normal Zip. Not Unzip, but Zip. It can be installed I guess, but WinRAR is much more powerful. I figured that by now the whole world is using WinRAR (which is free anyway).
Is this a real problem ?
christoffe01
« Reply #2 on: September 12, 2011, 10:00:26 am »
No,
maybe by others. There are 56 downloads until now only.
« Reply #3 on: September 12, 2011, 10:04:46 am »
Thank you Joachim.
That 56 as off now is the most normal after this time of the upload.
But I hope people will chime in when they see this as a problem.
PS: A bit off steam now, I can of course investigate some time in getting that Zip running.
« Reply #4 on: September 14, 2011, 11:13:21 am »
I downloaded free 7zip
(portable for on the usb stick I use to transfer XX to the music PC)
Works like magic on .rar files!
regards, Coen
