November 23, 2024, 08:52:46 am *
Pages: 1 2 [3] 4  All
Author Topic: XXHighendModel 0.9z-6  (Read 46667 times)
« Reply #30 on: September 13, 2011, 11:03:30 pm »
See here : 0.9-z6 illegal windows version.
And here of course : http://www.phasure.com/index.php?topic=1792.msg18230#msg18230
scratching
lasker98
« Reply #31 on: September 16, 2011, 11:31:43 pm »
I'm also getting the "interrupt mechanism out of order " message. I'm running Win7 SP1 Ultimate 64 bit.
I downloaded 0.9z-6 yesterday (first time trying XXHighEnd) and was getting the message in demo mode. I thought it was something to do with it being demo version.
Today I un-demoed and have been getting the message quite a few times. I'm using remote desktop from Win XP  Pro 32 bit to log into my headless music player. I seem to get the message when I click on the play button in lower area of default UI. It usually goes away when I click the stop button then play is ok. Sometimes I've had to do it multiple times to finally clear it as the message would keep popping up as soon as I closed it.
I've never got to the point where I had to close the program to get rid of it.
I love this player. I'm coming from J River MC16 and as I said above, last night was the first time I tried XXHighEnd. Within minutes I'd heard enough to decide to buy it. I truly can't believe the improvement in sound quality.
Bill
« Reply #32 on: September 17, 2011, 07:09:50 am »
Actually that "Interrupt" message is a left-over debug message I built in for myself a couple of moths back (for 0.9z-6), and it is there to tackle the annoying volume change which doesn't work for some. Or not always. I never saw the message, so I forgot about it.
I'm not sure now wheter it's a convenient thing, or just not. Anyway it indicates something wrong. Something which is too slow, or ... I really don't know what it is.
Again today I heard a story of someone who reinstalled the OS, and for the life of him never could change the volume anymore. Tried everything and all, and in the end installed the OS *again*. Problem gone ...
I don't know about you all, but if I install the OS 3 times, I see things happening 3 times different (just on the screen). I alwasy say "huh ? never saw that !".
I don't know what this is. But then I don't (re)install the OS so often.
Ok, I think that message should go, because it is not convenient, and there are log entries for it as well. But before I do so, can everybody who has this (more or less frequently) let me know about this ?
and thank you for the kind words Bill !
Bigear
« Reply #33 on: September 23, 2011, 11:49:57 am »
sometimes I have a strange error.
When I add files to my playerlist, I browse through the directories with the FLAC's and click on the album button showing in the player list window of XXHighend. Normally the songs of the album appear as they should in the player list. However, sometimes I get a popup window for each song of the list with the question if I want to run ...\tag.exe. I can just cancel this request, pressing on the accept button creates no further action.  Pressing cancel puts the files in the player list but with 0:00 playing time (so they are empty)
I have the impression it has something to do with the security setting, however my old version (9.4) worked fine and the W7 UAC shift button is down...
Any ideas on what would be the problem here?
Thanks.
Quint
« Reply #34 on: September 23, 2011, 12:49:18 pm »
Hey Quint,
Most 100% probably that you accidentally never used tag.exe before (on this OS install). It is used only in special occasions at getting data from a track.
Now, at installing XX the first time, there is this warning about the 10 or so programs passing by, and which you have to enter as "always accept and never ask anymore". For at least this program you will have forgotton this (which is merely about checking a checkbox). And now it is too late. Things now run under the hood with (indeed) security problems, but you can't answer upon what it is about anymore.
I am not even sure what happens when you run it yourself from within your XX folder. It just might ask you that question I'm talking about.
Otherwise reinstalling XX should do the job.
And if I am not right at all (about a 100% sure blahblah), let me know ...
lasker98
« Reply #35 on: September 29, 2011, 12:31:16 am »
What does the button between the input and output bit depth indicators do? It says "fx" but has no tool tip.
Bill
praphan
« Reply #36 on: September 29, 2011, 01:08:58 am »
Same question: what does "persist" on the right of those close service buttons do?
Thanks
Praphan
« Reply #37 on: September 29, 2011, 08:31:05 am »
Praphan, nothing for changeable settings at this time. See Release Notes.
Bill, the fx button -when active- denotes a fixed output sample no matter the input. When not active it merely follows the input sample rate. Hard to explain without looking at it myself (which I don't at this moment). But load a HiRes and see what happens to the output rate with fx active and inactive.
I will look into that ToolTip. Must have forgotten it.
lasker98
« Reply #38 on: September 29, 2011, 04:13:07 pm »
Thanks Peter,
I see now. My "dac is" setting is 24-96. If I use 2x upsampling and play a 24-96 file with the fx button active, then the 24-96 file plays at 24-96 (no 2x upsampling).
If I try to play the same file without the fx button active, then XXHighEnd upsamples to 192kHz and gives an error about improper sample size for dac and won't play the file.
For my dac then, I need to have fx button active to avoid errors playing hi res files.
I'm guessing for a nos dac it doesn't matter if it's active or not because the dac can accept any sample rate.
Thanks again,
Bill
« Reply #39 on: October 01, 2011, 06:10:41 am »
I have noticed the following bugs with 0.9z-6:
1) The coverart does not appear during playback of the first track. However it appears from the second track onwards.
2) Twice, since a week of starting using 0.9z-6, the computer has suddenly starting rebooting while playback.
« Reply #40 on: October 01, 2011, 01:23:52 pm »
Solved for 0.9z-6-1.
For now I can only assume this is some kind of coincidence. I really don't know of anything else. Yeah, that you hooked up that EMM Labs maybe and that this went together with using 0.9z-6 (I think it does).
Please keep this under your attention, and let me know any news about it.
« Reply #41 on: January 03, 2012, 11:34:48 pm »
Recently I've noticed that when I initially boot up I can get XXhighend to run in Straight Contiguous with an initial SFS of 200. Previously I had to run in Mixed Contiguous for a few seconds before switching to Straight Contiguous or, if I wanted to boot into SC, the largest SFS I could get was 60. Now, booting up in SC, SFS 200,  I play a track for a few seconds and then  change the SFS to 350 and all just works.
Sounds great too!
« Reply #42 on: January 04, 2012, 07:51:13 am »
With the latest version ?
« Reply #43 on: January 04, 2012, 11:36:37 am »
No, the first 9z-6.
« Reply #44 on: January 04, 2012, 11:42:49 am »
Then you know the story ...
Nothing changes because of the bug in there (but SQ may for whatever unknown reason -> still interesting of course).
