November 23, 2024, 12:14:38 pm *
Pages: 1 [2] 3 4  All
Author Topic: XXHighendModel 0.9z-6  (Read 46694 times)
stefanobilliani
« Reply #15 on: September 12, 2011, 12:32:58 pm »
But this is more great news than I ever could hope for myself. I had some ideas about it, but still ...
But keep on watching this; it is my experience (well, that was with Vista) if things are really "overdone", your PC (laptop) may run into throuble when it needs more memory. Similar happens when I go over an SFS of 450 (which is not really "MB" as such) on my W7 with 8GB; it will work - it will keep on working - but at some stage other anomalies will occur in the memory realm. Like "Could not read from memory" or something, and that when you are doing something not audi related. So, when this happens it is time to decice that your SFS is too high afterall.
Otoh, when you aren't doing anything else much, it should keep on going forever.
And then a side note : at this moment this is not 100% true. Each time you start Playback, a small amount of general memory is taken away. So, do that a 100 times and things may go wrong because of that. When this happens, Off (button) the Sound Engine and start Playback as soon as possible will solve that. Otherwise a reboot will help.
This will be solved later.
All clear , thanks . I am probably seeing this already , *while* I am doing something else with the OS ( minimized ) .
Does not really report errors ( I have seen an altered screen resolution coming up by "itself" a couple of times to the extreme SFS SC allowed for the 32 bit OS and of course the "lower SFS message  )  , but rather it doesn't start playing in Mixed C.
Settings of the SFS to the values allowed *before* it cures perfectly . Values for this system are : SFS=70 in Mixed C.
Stefano
PS : I am seeing also an occasional rip-related ( WMP , imo ) thing about hdcd , but will addres that later and to another topic. .
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #16 on: September 12, 2011, 12:54:44 pm »
Do you get this while you have played before for the (boot) session and never used the Off button ?
In that situation you should not get those messages, although I think I saw it one time myself.
stefanobilliani
« Reply #17 on: September 12, 2011, 01:32:19 pm »
Good question , not sure if I respond correctly but probably not , I didn't received the messages in that situation .
Now I understand better the function of the new Off button ; anyway is it possible that after Off function activated , the playback just doesn't start anymore , but  *it will* after lowering the SFS without rebootin ?
Just guessing
Stefano
Edit , Have try the off button , and start again the playback and it plays , SFS 70 MC , SFS 70 SC and also SFS 90 SC . So that seems good ...
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #18 on: September 12, 2011, 01:43:55 pm »
Nah, this is not clear to me. Maybe because it is not clear to you. Happy
The Off button just removes XXEngine3.exe from memory. This frees that memory.
When you next lower the SFS and initiate Playback, that new amount of memory will be reserved. It should (again) stay as long as no Off is used. BUT, it needs that Playback to get XXEngine3.exe running in the first place (hence allocate the memory).
Once you get the message about lowering the SFS, XXEngine3.exe will be out of memory after that. But, use Off to be sure.
And no, there is no indication at this moment whether XXEngine3 is in there or not.
Maybe now you can rephrase your question ? (if still necessary of course)
stefanobilliani
« Reply #19 on: September 12, 2011, 01:47:50 pm »
Jaja ,  Happy it's ok now !
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
christoffe01
« Reply #20 on: September 12, 2011, 03:19:20 pm »
the SQ (same settings as with 0.9z-4.1) with this version is really amazing.
This is the biggest step forward since I'm with XXH.
The tonal balance is much better (improved mid tones replay) than before. The fine resolution in the highs improves a lot (I like cymbals), the bass is unbelievable, very tight and I can hear "Nathan Easts"  bass with "Fourplay" as never before. He is playing a "melody guitar" with his bass on some tracks.
The holographic image of the SQ is lifelike.
Now it is really time for an update of the NOS1.
Great job Peter.
best
September 02., 2011 (due 0.9z-6)
Plain Windows 7 Prof 64bit on SATAII spinning disk, / Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *6*/0/0/0/0 (Dev.Buffer = *512*)/ClockRes = *10ms*/Mixed/SFS = 200/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended (Just Start) /All Services Off + No Running Time / / 4x Arc Prediction Upsampling /-> WEISS Minerva -> main amp
stefanobilliani
« Reply #21 on: September 12, 2011, 04:32:42 pm »
the SQ  with this version is really amazing.
Yes indeed !!!
Received this message though : "interrupt mechanism out of order ; notify XXHiHend development ( restart playback ) .
Then I stop playback and press "ok" on the message .
I am playing  minimize os now , but left on the wasapi services .
stefano
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #22 on: September 12, 2011, 05:01:09 pm »
That makes you the second one.
This "check" was not in there before, and may indicate totally nothing. The only thing is : I did not expect it.
If you can recognize when exactly this happens, please let me know ...
« Reply #23 on: September 12, 2011, 06:31:31 pm »
Terrific sound!!!!!!!!!!!!. Really holographic.
I raised the Q1 from 5 to 10 and feel it´s still better.
Working flawlessly
Congratulations Peter!
« Reply #24 on: September 12, 2011, 06:51:23 pm »
Hi Juan, if/when you get your NOS1 upgraded to async-USB (and I recommend that you do), I'll just remind you that the optimum settings are:
- KS Adaptive
- device buffer 4096
- Q1=30
I know this doesn't affect you yet, but it might do the future...
« Reply #25 on: September 12, 2011, 07:02:12 pm »
- KS Adaptive
- Q1=30
Hi Mani
Thanks a lot for your advise, I keep it! You´re really lucky that are enjoying the NOS1 USB already.
I´m in the waiting list for the upgrade, btw: Hey Peter! when is my turn?  clapping
christoffe01
« Reply #26 on: September 13, 2011, 09:14:31 am »
the bass is exceptional. Really nice to listen to.
best
« Reply #27 on: September 13, 2011, 04:12:39 pm »
Hey Peter,
Nice Job on this release.
Must have been a whole lot of work you've put in this one.
First impressions are VERY GOOD,
I've been out for a couple of months, as you know.
So I went from 0.9z-2 to 0.9z-5 just last week, which was a somewhat big relieve on the hights part.
But the 0.9z-6 version even tops that.
Just tried the minimize OS function, I REALLY LOVE IT!!
The background of the sound is black and darkened now!
Thank you for all you time and effort.
I hope you enjoy the music package i've send you  Wink
Grtz Roy
« Reply #28 on: September 13, 2011, 07:03:55 pm »
I nodiced that my W7 activation sometimes seems like it has gone. Right under the screen a message apears that say's my Windows 7 is not legitimate.
This is only with Minimise OS on. When i go back by pushing OFF the activation is recovered.
« Reply #29 on: September 13, 2011, 09:47:38 pm »
[I nodiced that my W7 activation sometimes seems like it has gone. Right under the screen a message apears that say's my Windows 7 is not legitimate.]
I have the following message:
Windows 7
build 7600
This copy is not genuine
