November 23, 2024, 08:27:20 am *
Author Topic: RECOMMENDATIONS FOR A GOOD MONITOR  (Read 19671 times)
« on: September 08, 2011, 01:33:29 pm »
I´d like some recommendations for a good monitor of around 22/23" with USB ports to connect the mouse and keyboard to the monitor and this way have the PC with the less possible connections.
Would be a good idea a multi-touch monitor?.
What would be the best way to connect the monitor to the PC looking for the less interaction possible with XXHighEnd and the new NOS1 USB?
« Reply #1 on: September 08, 2011, 01:36:19 pm »
Using 0.9z-6 maybe. With that, the monitor will be off anyway.
Well, if you want.
« Reply #2 on: September 08, 2011, 02:07:26 pm »
the monitor will be off.
Sounds exciting!!  Happy
@ Juan
I have been using monitors from Ag Neovo. The have a glas front and i have made one in my dressoir. There is a picture in this topic. http://www.phasure.com/index.php?topic=1491.0
It are profi monitors and they almost never get broken.
« Reply #3 on: September 08, 2011, 03:39:42 pm »
Well, if you want.
Peter, could you explain it a little further please?.
I know also that with the NOS1 USB we won´t need the monitor because of the screen in the Dac. But even in such a case a monitor near the listening place could be more comfortable.
Gerard, thanks for your recommendation, your monitor looks very interesting but I´d like one in a vertical position near the listening place, I can´t find your model though. Could the multi-touch technology have some inconvenience in relation to XXHighEnd /Nos1 USB?.
« Reply #4 on: September 08, 2011, 04:03:20 pm »
Well, if you want.
http://us.agneovo.com/us/content/products.asp
They are vertical and the plastic protection caps can be removed. Last question i do not know.
http://www.agneovo.com/nl/content/p-17.asp
This one i have for my normal PC.
« Reply #5 on: September 08, 2011, 06:15:29 pm »
By using remote desktop? Wink
« Reply #6 on: September 09, 2011, 12:12:26 pm »
Well, if you want.
Hi Peter, I don´t understand that well, please explain it a little further. Thanks
praphan
« Reply #7 on: September 09, 2011, 04:24:39 pm »
Hello Juan,
Let's do an educated guess !
Take a look at the right leg of your NOS1. What do you think of that screen will be for ?  A tiny screen to be used as I/O device for your music PC. I guess Peter incorporates the code to fire up this feature in z-6 after it slept for a long time.
Just a guess
Praphan
« Reply #8 on: September 09, 2011, 04:43:33 pm »
Sadly, no Praphan. But 0.9z-6 will be up soon. All will be in the Relase Notes.
« Reply #9 on: September 09, 2011, 10:12:02 pm »
Thanks Praphan but...let´s wait to see what´s going on.
I´ll wait to see it before I buy a new monitor.
« Reply #10 on: September 10, 2011, 09:13:29 am »
Juan,
I see no functionality in "multi touch". At least not at this moment.
About USB vs. a normal video card (which is undoubtedly your consideration) ... I really don't know. I think you really should dive into this (you could say that I should ... yes);
With 0.9z-6 you can order to shut off the monitor during playback. Regardless OS activities for sending out data to a monitor, this means that the video card will electrically do less (up to nothing, but this depends). For USB ? I'm not sure. But undoubtedly there will be differences.
When the monitor is ON, I wonder whether USB would be the best choice. I tend to think not.
This is not important assuming the monitor will be Off during playback, but which may not be your choice.
Might you want to compare (listening) always do this with the Desktop Services being shut off. Otherwise all is moot.
« Reply #11 on: September 10, 2011, 09:47:25 pm »
Juan,
I usually turn off the monitor after selecting the tracks I´m going to listen, I really can´t tell if that has any influence in the sound. I just do it in an instinctive way thinking that as less work for OS the better for the sound
But:
- If I have the mouse and keyboard connected to an USB port in the monitor, how can I bring XXHighEnd alive, in case I want to, if the monitor is shut off?.
- If I have the mouse and keyboard connected to an USB port in the mb, would this have any influence on the NOS1 USB?. Are the different USB ports in the mb totally independent from each other?.
Page created in 0.254 seconds with 19 queries.
