April 06, 2025, 03:18:49 am *
Pages: 1 2 [3]  All
Author Topic: 9z-5-2: Wrong pitch with 48khz at x4  (Read 40226 times)
« Reply #30 on: January 23, 2013, 05:39:13 pm »
One more thing to add, for your better undertanding (hopefully) :
Suppose you say, Yes Peter, of course that is the problem !
Well, then you have to know that there is no logic in this for me, because I see no way it can happen. What can (and did) happen is that the pitch is wrong at going from 44.1 based to 48 based.
So yes, if your problem is as I think you try to tell it to me (all the time), it is easy to see when reading back. But first I'd have to know it because otherwise I would never guess it.
Never.
A PS again : It sure is good that I can regard this as a new problem (which has been there forevere). This is far more easy than finding code which changed and causes it.
If this is your problem now (change from 2x to 4x and the pitch changes). And before I can't mimic this problem : it can be your DAC which is not able to cope with the bandwidth. Try Foobar please.
« Reply #31 on: January 23, 2013, 06:44:18 pm »
So there we are ...
That first file in the list I showed is a 96KHz (the other one is a 44.1Khz). Not 48KHz. Should not matter by itself I guess, if you only KNOW that there is no way you will have been able to play this file at 4x. Can we agree ? Ok, we can.
Next, I just played it (with KS !) at 1x, 2x and 4x and at 32 bits *and* your used 24 bits, and the 4x with 24 bits is two times  slow. Could be 220% but somethig like that.
This isn't 10% off you know.
So, tell me that there is a problem somewhere and maybe I will find one. Haha.
But is it your problem ?
So I found myself an 48KHz and you know what ? 10% too slow at 4x and 24 bits.
One thing left : I never can have used your 96KHz file to test that 10%. I did solve something with it, but not this of course.
But as you see, I get (to Happy) you anyway !
Well, finally. Now solve it.
No further response needed. Yea, later please, when I announce it solved in some Release Note.
yahoo
« Reply #32 on: January 23, 2013, 07:29:39 pm »
Maybe I am confusing, but you are going too fast ! I am at work, so can't verify certain things here... We're on a different time zone Happy It is 13H24 here... When I will be at home, I will make the proper verifications, then come back to you.
« Reply #33 on: January 23, 2013, 07:52:54 pm »
Well I at least can try to "un" confuse 2 things.
1. This thread is about ONE song that, played alone, does have a -10% pitch variation when I upsample it at x4, as opposed to x2 or nothing. This problem has been consistently here since 9z-5-2, that happened to be the first time I discovered this. Though I admit that I did not test this song with each and every version that followed, but each time I did, the same was happening. That is why I followed your suggestion to try to redo each version up to the actual. I did, but with WASAPI. I will do it with KS this evening.
2. There was also a situation where 2 songs, each with a different format (song 1 = 16/44.1, song 2 = 24/96) were behaving strangely (this is the one I have to check when I will be back home this evening). But I don't recall creating a thread about this. Maybe I did that through PM  wacko
About problem 1: I did this test with JRiver (it did not create any problem with upsampling). I will do also with foobar as requested.
PS: You know like I know that these are the kind of situations where it's like looking for a needle in a haystack. My life does not depend on this (I learned that last summer). Ok ? Happy
« Reply #34 on: January 23, 2013, 08:25:28 pm »
Alain, by now and since my last post, please, when you get home spend time with the family instead of this. I have found a sufficient amount of problems to solve, and "undoubtedly" (ehm) yours is amongst it.
Maybe I can tell you : it is only praiseworthy that you really are the only one coming up with this.
What I saw will be easy to find and solve. No need for Foolbar anymore either. Really. And hey, if you dare post again about this I will delete that post(s) anyway. Does that help ?
Peter (reaaaaly pushing the keyboard keys softley this time)
« Reply #35 on: January 23, 2013, 10:34:49 pm »
Don't tell me you want this through PM ? I am so tired of using PMs
 Grin innocent yes whistle bye
Alain Happy
« Reply #36 on: January 24, 2013, 05:02:58 pm »
Hey Alain - you are mean. You sent a PM and I can't delete PMs. Ok, I can, but what's the use.
Ok, solved the problem but didn't listen to it. All was a matter of forgetting one small = somewhere. Yep, that's how it works in C.
Might you want to try it (and don't you dare to do not - actually you should be playing 48KHz files for the rest of your life from now on ... okay, kidding), paste the below (XXEngine3.exe) over your current 0.9z-8-1a folder (or other 0.9z-8 folder, but not nothing else !!).
And hey, thanks for being persistent !
* XXEngine3-09-z81b-x.rar (309.78 KB - downloaded 535 times.)
« Reply #37 on: January 24, 2013, 06:41:15 pm »
 Grin Hey... Thanks for your patience Peter yes I am eager to go back home Happy I know how those small things can be stealthy when you look for them. They say that a good programmer is also a good debugger  dancing
WoooooHoooo  yahoo
Alain Happy
« Reply #38 on: January 24, 2013, 07:41:39 pm »
Haha, I'd say a good programmer doesn't need to be a good debugger.
Anyway debugging is more difficult than good programming (time wise).
My opinion of course.
« Reply #39 on: January 24, 2013, 08:32:37 pm »
Also true, but nobody's perfect  Gotya !
Happy innocent
« Reply #40 on: January 25, 2013, 02:11:09 am »
I came back home, downloaded the file and... (drums rolling)... Tada ! It works ! I does !!!!
Now I am sad... What to find next, except good music with SSQ (Super SQ)...  drinks
AHA - A Happy Alain Happy
Pages: 1 2 [3]  All
