April 05, 2025, 01:41:47 pm *
Pages: 1 [2] 3  All
Author Topic: 9z-5-2: Wrong pitch with 48khz at x4  (Read 40211 times)
« Reply #15 on: May 13, 2012, 04:08:18 pm »
Mmmm ? Not sure I understand your answer ?
Oop... It seems that by replying to your post, the title is back to 9z-5-2...
« Reply #16 on: May 13, 2012, 04:10:11 pm »
About my earlier search for the culprit and that I can't find anything. I can't imagine that I find something to be there (wrongly) now, but something *has* to be wrong.
That's all ...
« Reply #17 on: May 13, 2012, 04:14:09 pm »
Ah ok  Wink
I tested different parameters, but...
I would say that it does not bother me, but it seems more music is available in either 24/44.1 or 24/48...
At least I keep on buying CDs Wink I slowed down on 24/192 downloads... Too much... Cr.. ?
Regards
« Reply #18 on: June 26, 2012, 12:23:56 pm »
Alain,
I have just been finishing the Release Notes to 0.9z-7 teasingteasingteasing (which does not mean 0.9z-7 is ready to go out swoonswoonswoon) and ...
I ran into a most peculiar unresolved ToDo. So, of course your little issue is in there as well, but here I'm talking about a coincidental DAC Needs = 24 test I did only two months back with the NOS1 (which it appears to be able to do) but with 48KHz ...
TE PITCH IS TOO LOW.
scratching
Now, I never saw the relation to your issue, but strolling through the (solved/unsolved) ToDo's I suddenly saw the combination. But wait, not too fast ...
What I never saw in your posts in this topic is HOW MUCH the pitch is too low. So, imagine my logic that you could only be talking about half of the speed or so.
But what I see here with this issue on my side is a 1000Hz tone coming out at 918Hz. And I was flabbergasted, because it really looks like the clock suddenly runs too slow. Or at least I have no other explanation, while this actually is no explanation either. So in ad-hoc fashion I am typing this :
1000 / ~918 = 1.0893
48000 / 44100 = 1.0884
Tadaaa ....
But now the question : is this what you perceive indeed, or is it half the speed like I always thought ?
Assuming you too perceive that ~10% off only I sure can now mimic your situation. And, it is 24 bits related. Both seen from different angles, and in both (for me as thought completelt separated situations) I couldn't see what was going on. Your case has been an "oh well", but my case is really flabbergasting me. And of course I (now) recall to have been through all the code and found nothing. Surely, with my situation at hand I can really start trying things, but since I know that the setting of the sample rate should be out of my hands because the OS is doing that through the header data in the file, I wonder - could it be an OS bug ?
(most probably not, and most probably I will find a bug on my side now).
But, is this your situation ?
« Reply #19 on: June 27, 2012, 03:26:52 am »
You are right, I never mentionned by about what percentage the pitch was lower than normal, but it sure was not half of the speed. Maybe the x4 and x2 thing got confusing. I would say that a 10% decrease in speed is about it.
Thanks !
Alain  Fishy
« Reply #20 on: January 21, 2013, 12:45:36 pm »
It still behaves like this. Like you mentioned before, it could be 10% slower. When I upsample to x2 for the right pitch.
« Reply #21 on: January 21, 2013, 01:55:23 pm »
Call me crazy, but this should have been solved somewhere in 0.9z-7. Although, I briefly searched the Release Notes, but couldn't find anything.
Are you sure this hasn't been solved in between versions ? I am pretty sure we talked about this.
Also, this is about the back and forth working/not working of all around your DAC. Up to that situation which needed Play twice because the first (after initial playback) produced an error.
I am getting crazy of this and I guess when you can't come up with an explicit "never worked" I will give up on this. Anyway I am pretty 100% sure that some version contains Release Notes about this and I ask you politely to look that up (and when found, try that version and when it helps, try to find the version which made it stop working again).
This looks a little bacl and white, but it is a difficult problem anyway, and without clue where again it stopped working - and with the notice with all of the problems which happened in between around this - ... swoon
So please Alain, you must help me here.
PS: And let me softly say it once again ... PM and stuff about problems is really not going to help. I use one source to keep track of problems, and this is the forum. Maybe you can find things about this in emails or PMs ? I really can't with 150 "unstructured" pages in there.
« Reply #22 on: January 21, 2013, 01:58:37 pm »
After all, here : XXHighEnd Model 0.9z-7-4 (alows for more PA situations + new SQ setting). But notice the heading under which it is listen "Prior to ...".
« Reply #23 on: January 22, 2013, 02:31:24 pm »
Though you indicated me from where to start, I chose to start from 9-6 up to 9-7-5... WASAPI (to do it faster). Unless there would be a difference about this situation with KS, they all behave the same... 10% difference (about) between x2 and x4...
If you wish I can do the same again with KS ?
Thanks.
« Reply #24 on: January 22, 2013, 03:04:42 pm »
Ahum.
The solution for KS is different from WASAPI, plus in my comment it states "WASAPI not tested at this time but isn't used by anyone anyway". Haha, oh boy.
So I am sorry, but yes this matters !
IIRC what I wrote yesterday it is not necesssary to start with 0.9z-6. Somewhere 0.9z-7 it will be that I declared it solved.
Btw Alain, it will be a good idea to tell me again how you test this today, because quite a few scenario's exist. This may be different from how this topic started. Okay ?
« Reply #25 on: January 22, 2013, 03:53:00 pm »
I did the same test for each version the same:
- Decompress all in a XXHIGHEND folder on the OS disk, always emptied between versions
- Reboot between each version
- As you stated (in a PM that I started - I know, I know) that the OCX files (from setup.exe) do not require to be reinstalled between versions, I did not change them.
- Adjust minimally (WASAPI, 24/192, 24 bit [not 32, my dac does not recognize 32 bit), peack extension, arc prediction, x2 and x4 [for each test].
- I play at x1 (48khz)
- I play at x2 (96)
- I play at x4 (192)
- reboot
- clear the XXHIGHEND version to leave place for the next version.
- As for those which had an update, it was done first without, then with the replacement files (like the xxengine3 that was added for 9-7-4).
- All on the same PC (music PC) of course...
- 1ms clock resolution.
- contiguous memory
- None of them activated (...)
- All in demo mode (no minimize OS)
- SFS at 12
I wondered if it was necessary to kill xxengine3 between each upsampling but since the pitch was changing, I guessed it was not necessary.
« Reply #26 on: January 23, 2013, 01:40:41 pm »
Peter (good morning) Happy
In one of your answers about this, you mention that the routine for 48khz is the same as with 44.1 and that it shoud have the same behavior. Maybe I could copy this song and downsample it to 44.1 just to see if this will behave the same ?
« Reply #27 on: January 23, 2013, 02:18:58 pm »
Alain, help !!
You didn't tell what went wrong and where !
Unless of course you mean that it (what upsampling ?) never plays right. And since I don't (and never did) expect *that*, I don't get it.
I don't understand this either; WASAPI ? Didn't we "agree" that you should test with KS ?
And then lastly, this was about finding out out where it was right and wrong again. You say nothing about that though. And it feels wrong to have my own conclusion about it ...
Probably I said something like that, but then in some context now lacking here, and *thus* I don't understand this either.
Okay, it could be so that I don't understand anything much today ! swoon
« Reply #28 on: January 23, 2013, 04:07:09 pm »
Alain, help !!
I hope I understand your question correctly: when I started using XXHIGHEND, I was not using upsampling. After reading here in the forum, I decided to use it. At this point and from the moment I had this song, the version I was using was 9z-5-2. Then I discovered about this. I never saw it change throughout the following versions, though I admit I did not test it with each of them.
That's true. I would have guessed though that if WASAPI is a part of the code you do not really touch, it would be simpler to diagnose and correct, since WASAPI is also problematic about this... But yes, I will redo the tests in KS mode this evening...
I never said it was ok Peter, because it never happened...
The following quote is taken from a post you did in this very thread:
Still no dice.
A bit of a problem is that I have no means to test this sound wise. But I've looked in the program, and all what is done for 48000 is done for 44100 exactly the same (unless my searching capabilities are not the best). Meaning : if this happens with 48000 it should happen with 44100 just the same.
... which of course is not happening in your situation.
All I can think of is that 16/48000 hardly will be a normal audio format, and whatever it is you have there, it will be a non-common rip. This means that something could be wrong in the header, and that *this* is not covered for correctly by the software - somewhere.
On this matter, you could send me a track of this.
What also -theoretically- can be the case, is that somehow your DAC is not able to do this right. Now, however, my story really must be the other way around from above : playing 16/48 will be the most normal to a DAC (because this is video standard).
Now I think of it : I will be able to test it without sound, by measuring the track time. I mean, I do have a 24 bit device (HiFace) but no DAC for behind it. But I feel it is better if I first have an example track. Ok ?
Alcool, drugs and electric trains do not mix well  dntknw grazy grazy
« Reply #29 on: January 23, 2013, 05:24:27 pm »
Okay Alain. Retry from my side :
You HAVE to be more explicit about -I'd say- EVERYTHING. To me it looks totally impossible that up to today I apparently don't understand the problem. I myself did not read back in this topic which also feels a little useless because not everyting said may be in the topic. But I am pretty sure this was about my idea of CHANGING the sample rate. Again, please look back. And this is totally different from only playing at 4x which again is different from a pitch being off 10% and the speed being double - as how I started out responding in this topic. Again, *I* did not read back.
Do notice now that I never in my life changed something about some "absolute 4x" not being OK with 48KHz. I was just never told that, possibly similar to you actually not telling a problem in your previous longer post. Actually it is worse, because you never in the whole topic told a thing, or it has to be the confirmation from (finally ?) two days back that you had a pitch problem instread of double speed or something. This I had to guess too you know. But I do that because things don't fit.
So, am I complaining ? no, not much. But I do have to tell you that we won't be able to solve problems like this.
You may not like me by now, but to me it seems that you tested all in WASAPI again (why ?) while you should have done so with KS after my post I mentioned this in. Possibly I am as unclear as you are though.
What ? what pitch CHANGING ? Didn't I just conclude from your words that nothing was CHANGING ?
Be explicit Alain. Far more explicit.
Below you see the files you sent me to test with. You know, I solved the problem. What problem ? THAT I know don't know. So I solved a problem, but not yours. Can I still use these files for my testing of whatever is your problem ?
Do not repeat that test again. Please spend your time on explaining 100% clearly about what the problem is. I *still* don't know you know ...
haha
PS: Apologies if I sound a bit like hitting the keyboard hard. Well, I do. Can't stand that I still don't get it ! Happy
PPS: At reading back this post before posting, I suddenly see a clue (maybe) :
- You test at e.g. 2x
- You test at 4x and hear the pitch CHANGE.
Correct ? If yes, only confirm this. I don't need anything else then. Ok ?
Pages: 1 [2] 3  All
