April 05, 2025, 12:59:09 pm *
Pages: [1] 2 3  All
Author Topic: 9z-5-2: Wrong pitch with 48khz at x4  (Read 40201 times)
« on: September 04, 2011, 04:37:44 am »
I normally leave the output sample rate at 4x, but when I have a song is initially sampled at 48khz, the pitch is not right.
It only happens at 4x (I can't go higher).
Thanks.
« Reply #1 on: September 04, 2011, 04:47:58 am »
Ehm  ... 9z-5-2 pitch problem with 16/48 combined with 4X upsampling ??
Amnesia ?
« Reply #2 on: September 07, 2011, 06:51:28 am »
Amnesia... ? Is it a keyword to trigger something ? ;-)
« Reply #3 on: September 07, 2011, 06:54:07 am »
Ah ! I got it now... Sorry for this... Sorry for this (I have to write it twice) ;-)
Alain  grazy
« Reply #4 on: September 08, 2011, 05:53:01 pm »
Hey Alain - Small problem; I can't copy this behaviour. It just works ok.
Is that 24 bits you are having there ?
Do you use Arc Prediction ?
« Reply #5 on: September 10, 2011, 12:49:09 am »
The song is natively at 16 bits 48 khz... I tried with and without Arc Prediction. My DAC is working with 24 bits (not 32)...
« Reply #6 on: September 10, 2011, 11:45:18 am »
Still no dice.
A bit of a problem is that I have no means to test this sound wise. But I've looked in the program, and all what is done for 48000 is done for 44100 exactly the same (unless my searching capabilities are not the best). Meaning : if this happens with 48000 it should happen with 44100 just the same.
... which of course is not happening in your situation.
All I can think of is that 16/48000 hardly will be a normal audio format, and whatever it is you have there, it will be a non-common rip. This means that something could be wrong in the header, and that *this* is not covered for correctly by the software - somewhere.
On this matter, you could send me a track of this.
What also -theoretically- can be the case, is that somehow your DAC is not able to do this right. Now, however, my story really must be the other way around from above : playing 16/48 will be the most normal to a DAC (because this is video standard).
Now I think of it : I will be able to test it without sound, by measuring the track time. I mean, I do have a 24 bit device (HiFace) but no DAC for behind it. But I feel it is better if I first have an example track. Ok ?
« Reply #7 on: September 10, 2011, 02:25:14 pm »
Hi Peter, I have sent the "suspicious" file ;-) I downloaded this file again and though I bought the whole album one year ago, this song seems to be the only one recorded at this weird format (16/48)...
When I reduce de X factor from 4 to 2 (x 2), everything is OK... Maybe it is related to either the USB -> SPDIF I have (Audiophilleo 2) or my DAC (Bryston BDA-1) ?
I forgot to say that this is not of real importance for me. I just thought it would be useful to you, but if it is related to my USB -> SPDIF or my DAC, there is not much to do...
Thanks anyway,
« Reply #8 on: September 10, 2011, 02:55:02 pm »
Thank you Alain. But we really must hop over to plan B (IOW, all still ok here).
Ok, if this is not of big importance for you, I better let it be for now.
Not for later ...
Thank you for your help !
« Reply #9 on: March 05, 2012, 02:45:43 am »
I just downloaded an album today (Rodrigo y Gabriela and C.U.B.A: Area 52). It is 24/48... And I use KS, adaptative, 2.5ms, SFS 50 (I am waiting for Lenovo memory banks), Q1 = 7. I have Windows 7 pro SP1, 64 bit, 2 GB of RAM... CPU is Intel G620, 2.6 ghz, 2 cores.
When I use the multiplier (x 4) to get 192 khz, the pitch is slower. At x 2, the pitch is OK...
I don't have a clue. I have tested this with and without Minimize OS. I have tried it with WASAPI and the same symptoms are happening...
It was doing this on my laptop, now on my recent PC... I did try on my main PC and no problem... But the difference is that the laptop and the new PC are connected to my audio chain, while my PC is standalone...
Alain  scratching
« Reply #10 on: March 05, 2012, 08:47:48 am »
Yo Alain,
I had already read this twice before I saw the (my) emphasis. So ...
WHAT ?
Now I'm floored.
The difference should be your DAC (??).
But this is not 100% true, because the difference also will be that 24 bit output. So, in-PC that is 32 bit I suppose ? (please check the DAC Needs setting on your main PC)
It now also seems clear that it is not bit depth related ... am I correct ? so, both 16 and 24 bit files don't work.
Btw, earlier in the topic I said that 16/48 is a rare format, but it is not at all of course. This is just what is ripped from DVDs (which in there will be 16/44 although in lossy "MP3" format).
Please confirm the few things from this post, and when you do, I guess I *have* to find some bug somewhere. As you will remember, I already checked everything, but I must do it again. It's a bit stupid that I can't test it. Or ... hmm ... I think I can with the analyser (and the HiFace I have, which allows for the DAC Needs 24 bit setting).
« Reply #11 on: March 05, 2012, 02:01:09 pm »
To prevent any confusion:
- Lenovo is the desktop connected to my audio system.
- Asus is my general purpose desktop. It is more powerful than Lenovo.
Yes, Internal DAC has to get 32 bits on Asus.
As for the audio system (Lenovo), outboard DAC has to get 24 bit...
I forgot to mention that I got an Audiophilleo2 USB to SPDIF converter on my audio system... :-( I have corrected my signature a few minutes ago...
I ran some tests...
Lenovo: first, I indicated to XXHE that I would use the integrated soundcard. It works at 24 and 32 bit, but sampling rate is limited to 96khz. Not useful since x4 upsamble 48khz to 192khz.
Lenovo: I switch to the audio system.
Lenovo -> USB -> Audiophilleo (24 bit) -> SPDIF -> Bryston DAC (24 bit). I select "DAC is: 24 bit/192 khz". As for the  "At 16 bit, the DAC needs", I have to choose 24 bit. (pitch is then slower at x4).
Now I turn to my general purpose desktop...
Asus is a little confusing: I can either select "DAC is: 24/192" or "DAC is: 32/192". As for the "At 16 bit, the DAC needs", It has to be 32 bit (pitch is ok at x4).
I could connect Asus to the audio system to check if it will behave the same as Lenovo... I can do it if it can be of some help ?
As for this situation, there is no rush. I am only worried that I could forget what is happening at x4 for 48khz songs ;-)
I started computer programming at 30 for 15 years. I still do some programming from time to time, but it is not as stressful as it used to be. I know how it can be...
« Reply #12 on: March 05, 2012, 03:44:14 pm »
Alain, if that is easy for you - Yes please.
(and the same problem is to be expected)
« Reply #13 on: May 13, 2012, 03:38:46 pm »
It took me a while (...) to do the test with my ASUS computer, but I did it this morning and... Yes, the pitch has the same symptoms as with the 2 other PCs (HP laptop and Lenovo desktop).
Since I did not experiment this problem with my ASUS soundcard, my guess would be that with a 24 bit DAC (or with the Audiophilleo), there could be something wrong happening.
If you need more precision, please feel free to ask ?
PS: I changed the title, since I changed the XXHE version when it came available...
« Reply #14 on: May 13, 2012, 04:03:50 pm »
Ok Alain, thanks. So I *have* so find something eh ?
yes
Pages: [1] 2 3  All
