April 20, 2025, 04:29:02 am *
Author Topic: No Engine#3 with Lynx ?  (Read 14804 times)
minzyman
« on: August 28, 2011, 03:46:10 am »
I just installed Windows 7 and my old activation code doesn't seem to work either. Why would this be and how can I resolve? I decided to upgrade (finally) from XP.
Also, I am using the P5Q-EM motherboard with 16 GB RAM and a Lynx AES16 card (for now). Is KS mode the only option for me with this card?
Please, help?
/Lee
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
crisnee
« Reply #1 on: August 28, 2011, 04:01:30 am »
Hi Lee,
Peter will send you a new code when he gets up. Whenever you install a new OS, XX needs a new code. I've gotten quite a few.
As to KS. That's really your best sound option so if it works I wouldn't worry about anything else. But Peter will tell you more.
-Chris
« Reply #2 on: August 28, 2011, 08:48:55 am »
Hi Lee,
The email about the activation has been sent by now, so that will be allright.
Re the Lynx, I'm not sure ...
All I recall is some other way around ... that the AES16 is not able to work with KS (Engine#4). But maybe I'm wrong.
I also wonder whether you may be confusing yourself (or rather me) with a difference between XP and W7. I'm sure there is "something" with the Lynx to this respect, but I forgot.
So, what Devices can you select from in XXHighEnd ?
Notice that those prefixed with KS: are Kernel Streaming devices (#4) like in XP, the others (not available in XP) are WASAPI (#3) devices.
Let me know ...
minzyman
« Reply #3 on: September 04, 2011, 03:33:48 am »
So regarding the above, I finally rolled back the Lynx driver to previous version (18c) and was able to get Engine #4 with KS options for the Lynx.
The problem now is with Memory Organization. I can only get tracks to play when using Mixed mode. When using Straight Continuous or even Mixed Continuous mode, I get that nasty window popup telling me "Necessary privileges have been set. Reboot to make them effective!
I cannot get this thing to go away under straight continuous. Have played with the SFS size and still nothing.
My machine has a Lynx AES16 and 16 GB of RAM, Mem buff set to 4096. Q1 to 30, 0,0,0,0.
I could also use another activation code, as I had to rebuild my Win 7 build yet again. The one you gave me the other day no longer works.
Thanks.
/Lee
« Reply #4 on: September 04, 2011, 04:12:26 am »
Hi Lee, can you see here whether this helps : Mixed / Contiguous Memory ?
See your email about the Activation !
minzyman
« Reply #5 on: September 04, 2011, 04:20:39 am »
Ah yes, I think I disabled a few security settings, so do not see Local security Policy options in Administrative Tools.
Will have to play more.
/Lee
« Reply #6 on: September 04, 2011, 04:23:23 am »
And shut off your UAC ! (User Account Control). Slider to the bottom.
minzyman
« Reply #7 on: September 04, 2011, 04:29:21 am »
This is what I disabled:
➢BitLocker Drive Encryption
➢Certificate Propogation
➢Diagnostic Policy/Service/System
➢Distributed Link Tracking Client Elements
➢Encrypting File System from page 5
➢Function Discovery Provider/Resource
➢Health Key and Certificate Management
➢Internet Connection Sharing
➢IP Helper
➢Offline Files
➢PnP-X IP Bus Enumerator
➢Quality Windows Audio Video Experience
➢Secure Socket Tunneling Protocol
➢Themes
➢Windows Media Center Receiver/ Schedule
➢Windows Media Player Network Sharing
➢Security Center
➢Windows Defender
➢Windows Firewall
➢Windows Updates
« Reply #8 on: September 04, 2011, 04:35:41 am »
If my earlier link doesn't help, try switching on Diagnostic Policy/Service/System. Looks suspicious to have that off in this case.
Once that helped and it works, you can turn it off again.
minzyman
« Reply #9 on: September 04, 2011, 05:23:43 am »
There is no Local Security Policy in Windows 7 Home Premium, according to Microsoft help. Only in Ultimate. That perhaps is why I don't see it listed.
Maybe if I run secpol.msc, perhaps I can access something like Local Security Policy? Not sure.
I have Mixed mode working. But still cannot get straight continuous mem organization to allow me to play. Still getting permissions issues. SFS at 430, but I did play with it at 2. Still no go. UAC slider is all the way down.
Any other thoughts?
Thanks.
/Lee
« Reply #10 on: September 04, 2011, 08:04:10 am »
Home Premium ... Look here : Re: how to start MC and XC?
In the mean time I will dig up that ntrights program for you and attach it in this post when I found it.
Ok. Rename to .exe
* ntrights.xxx (31.5 KB - downloaded 556 times.)
minzyman
« Reply #11 on: September 04, 2011, 06:42:55 pm »
I'll try this Ntrights.exe app, but Coen was using Win 7 32bit. I have 64bit running. Will this matter?
/Lee
minzyman
« Reply #12 on: September 04, 2011, 07:29:06 pm »
Success! Ntrights.exe worked great. All set now.
Here is the process: need to download ntrights.exe first.
"I used a little trick to enforce the lock pages privilege for the administrator role. I stumbled upon a tool that is part of the win2003 toolkit: ntrights.exe. With this tool placed in the windows\system32\ directory I ran it form the command prompt:> Ntrights +r SeLockMemoryPrivilege  -u Administrators (this command is case sensitive)."
Thanks.
/Lee
