April 06, 2025, 05:15:07 am *
Author Topic: XXHighEnd Model 0.9j (Pause for Engine#3 + realtime settings)  (Read 8547 times)
« on: August 28, 2007, 07:51:34 pm »
Important : When you are a first time Vista user of XXHighEnd, do NOT use this version to set your reference of the sound quality XXHighEnd is capable of. Use version 0.9d instead ! OTOH, please read this topic as well : 0.9d vs u/i 0.9j .
It puts things in a perspective, and it might well be that afterall 0.9j sounds better for you.
Changes :
  • Engine#3 now allows Pause/Continue.
  • Engine#3 now allows the dragging of the position slider.
    Please note that this repositions with an accuracy of one second.
    When the slider is put near the end (last few seconds), accuracy will be extra off, playback may stop or restart at the beginning of the track.
  • All settings logically requirering it can now be set during playback with immediate effect.
    A small dropout in sound will occur though, and the playback continues at a position rounded to the second.
Bug fix :
It only now appeared that changing the Absolute Phase (Invert) did not take effect at the start of the next track. It required stop/start. This is now solved (and takes effect immediately).
No changes on sound quality are to be expected with this version. However, do note that an earlier remark about Doubling not being the best idea from off version 0.9h actually seems legit again from off version 0.9i with the "proper" Q1 setting ("proper" is up to you).
It looks like Doubling has gotten a bit back from what it was created for : more dynamics. Please decide for yourself.
* XXHighEnd-09j.zip (821.16 KB - downloaded 692 times.)
« Last Edit: September 01, 2007, 11:29:49 am by PeterSt » Logged
