November 23, 2024, 11:20:18 pm *
Pages: 1 2 [3]  All
Author Topic: Windows W7 SP1 RC runs to its end ...  (Read 39755 times)
christoffe01
« Reply #30 on: August 31, 2011, 11:32:48 am »
I don´t have that W7 problem, maybe just because I use my computer only for the NOS1 and it´s not connected to internet, so no updates either.
This is the only practical solution for a highend system and a replacement of a CD-PLAYER!!!!!!!
September 02., 2011 (due 0.9z-6)
Plain Windows 7 Prof 64bit on SATAII spinning disk, / Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *6*/0/0/0/0 (Dev.Buffer = *512*)/ClockRes = *10ms*/Mixed/SFS = 200/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended (Just Start) /All Services Off + No Running Time / / 4x Arc Prediction Upsampling /-> WEISS Minerva -> main amp
Flecko
« Reply #31 on: August 31, 2011, 11:36:48 am »
Does - or did anyone else see this ?
My W7 is running out too. There is a program called DAZ loader that should solve the problem (at least if you do not have the RC update).
I can not tell you if the program will work because I didn't reboot my pc yet. But according to what the people say it should.
« Reply #32 on: August 31, 2011, 12:07:23 pm »
Adrian, thank you. But I wasn't asking about that ...
(this has been covered for earlier in the topic)
nik.d
« Reply #33 on: August 31, 2011, 02:17:09 pm »
I'm not PC expert however I installed / tried several W7 vesions on XXHE dedicated PC. I'm a bit confused why
you perform OS uninstall? Each new installation will create "Windows" folder/directory and old one will remain
as "Windows.old" With several installs you would have "Windows.old", "Windows.old01" and so on. XXHE related
folders (AutoHK as well) remain, OCX files need re-install.
You can delete ".old" folder(s) anytime.
Re SP1 RC ending, perhaps you could try SP1 RC workaround - similar to original W7 RC, where updates were disabled.
This is described at How-To Geek web site:  There is 'cversion.ini'  file on W7 install DVD.  Copy entire DVD to HDD
and edit 'cversion.ini' to read MinClient version number lesser or same with MinServer version. My W7SP1x64U 'cversion.ini'
reads the same version, "7601". After editing, install OS directly from HDD, or burn new DVD if you like. I dont have SP1 RC
to try it here, sorry. HTH
Brgds
« Reply #34 on: August 31, 2011, 02:56:34 pm »
Thank you Nik. But not the subject again. I will repeat it in full (with a new addition at the end).
1. Ever back installed W7 SP1 RC, which expires today;
2. Uninstalled that RC yesterday because there is no other way (upgrade or something over that is not possible, nor is installing SP1 RTM upon it);
3. My system now tells me that my "eval version" expires in 4 days. This must be about the official W7 RTM (no SP) which is just a legal and activated version.
4. (new) I now installed SP1 RTM over it, and it STILL tells me that the eval will expire in 4 days.
So, now - since all is back to normal - do others see this too ? (see today's earlier screenshot from a few posts back) ?
« Reply #35 on: August 31, 2011, 04:04:10 pm »
I had two days ago the expiration message in a little laptop with W7 premier with SP1, I asked to a technician here and he told me that forget it, nothing is going to happen. The only way to know it is wait and see, that´s what I´m going to do.
« Reply #36 on: August 31, 2011, 04:57:28 pm »
Ok. I suddenly noticed that this screen can also show obsolete entries. Which lead me to this :
http://www.ghacks.net/2010/02/09/remove-old-notification-icons-in-windows-7/
I applied what is in there, and now the entry has gone ...
(others as well)
Stupid stuff.
Maybe this helps someone.
« Reply #37 on: September 01, 2011, 03:21:15 am »
Yesterday I decided to rebuild my music server O/S from scratch. I figured everyone was going to be on the RTM release of SP1 anyway, so from a conformity point of view it makes sense. I rebuilt using a copy of my W7 X64 Ultimate with SP1 slipstreamed into it.
It didn't take ALL that long in reality, maybe 3 hours in total. I had previously taken screen dumps of all the services I disabled/amended, and I made sure I copied  the current AutoHK, XXHE and Data folders to another drive, in preparation to copying back to the new C: drive.
As a dedicated XXHE only music server, nothing else was applied, or needed, other than Acrobat reader, ExcelViewer2007, and an initial load of PowerStrip, which I used to create a custom screen res for my CRT monitor (Sony GDM-FW900) of 1280 x 834 pixels @ 75 Hz.
Firing up XXHE on the new build resulted in sound that I was familiar with, however I did notice occassional ticks and clicks midway through some tracks which was unexpected. I still need to disable the system logging functions discussed in the epic system tweaking post, so hopefully that will resolve the clicks.
« Reply #38 on: September 01, 2011, 08:03:58 am »
Don't make too much fuzz about this Russ. It could be a waste of time. I have a topic coming up later ...
PS: Didn't you have SP1 on that machine yet ?
« Reply #39 on: September 01, 2011, 10:01:03 am »
I did, but it was the RC release, which has been discussed and was causing all the angst about expiring.
Regs,
« Reply #40 on: September 01, 2011, 10:02:09 am »
That's a good thing (for me).
Lalalalaaalala
Pages: 1 2 [3]  All
Page created in 0.945 seconds with 19 queries.
