crisnee
« Reply #45 on: July 23, 2011, 06:50:43 am » |
So Peter, guess what. I am German, that would be Deutsch to you. Ya ich bin ein Deutscher. Ich bin nach der USA als kind.
So why did I say Dutchland? Because I'm goofy, sarchastic, silly and facetious, here, there and everywhere. So of course I know all the stuff you so elaborately put forth. I hope said is well absorbed by someone in need of it; I didn't mean to create yet another subject for you to write about. It's probably not fair of me to do this kind of stuff with language in emails and especially to non-native speakers, but I can't help myself. If I can't have fun writing I end up not writing at all. (And it's no better when I'm speaking, except that critics like Mani can't tell which form of 2 or yer I'm using).
As to the music and American-Japanese Subarus. This buggy had a good sound system in it, not uber good, but very good.
The other night, just after my note about the Get Yer Ya Ya's and loudness issue, I listened to a Wilco album (not in the Subaru). And lo and behold a section started playing that sounded like it had to be turned up to be enjoyed. It sounded cramped and small, insignificant (hard to put into words). But it was only this one part of the album. I couldn't turn it up to test it, as it was early in the morning. The rest of the album sounded fine, big, spacious, nice spread out soundstage at that relatively quiet level.
-Chris
Win7 Vanilla 64bit 4gb Dual Core E5200, 2.5ghz, offline audio only pc > 0.9z-6, Eng #4, Adaptive, MixedCon SFS 300, 10 ms, Buffer 2048, Scheme 3, Q1 1, 0s, > Audio-GD DI > Scott Nixon TD2 NOS Dac/MS V-Dac.
crisnee
« Reply #46 on: July 23, 2011, 07:00:28 am » |
Peter said "Chris, take Oh Well. I recall that as the back side of a vinyl single, but here I'm talking about the 9 minute version. Try to imagine that I am telling you that the Spanish Guitar played on there sounds better than your live Spanish Guitar ... Of course this can't be, but so good it actually is."
Ok, so I listened to Oh Well. I agree with you in part. The classical guitar sounded really really good, but only for about 30 seconds to a minute at about the 7 minute mark. At about the 5.5 minute mark it sounded lousy, slightly out of tune, and the way it sounds when I'm playing and thinking I can't get this thing in tune today, and it sounds like sh*t. But for some reason at 7 minutes it sounded great. It must have been added in later or something.
The track for the most part sounds like it was recorded in mono. The instruments are right on top of each other.
-Chris
« Reply #47 on: July 23, 2011, 07:07:34 am » |
Are Amish allowed to have Internet then ?
Nah, I suppose they don't live in appartments.
haha
Great story Chris.
« Reply #48 on: July 23, 2011, 07:22:32 am » |
Oh Well ...
I am doing this by recalling the track from memory :
Yes, I guess you are right that you can hear "overdubbing". But (again, from memory !), what about such a thing being audible *that way* is a characteristic of recording from that time ? Maybe that is part of the "honesty" I dedicate to the music of that era ? But it is still the most difficult to communicate over, because I only recognize this "honesty" thing lately. Not two years back or something.
I need to play much more music from back then to recognize what it really is about. And an again better playback chain maybe. I mean, I tried a.o. a few Muddy Waters, but that doesn't sound good at all. But then this is a characteristic of blues I think (who needs good recordings to express blues). Reggae even worse (visit Jamaica and you'll know why).
crisnee
« Reply #49 on: July 25, 2011, 12:03:10 am » |
That's probably true ...who needs good recordings..., however I don't know whether to credit the music or blame the recording engineer for giving me the blues when I listen. -Chris
crisnee
« Reply #50 on: July 25, 2011, 12:15:22 am » |
Hey Nick, are you there ? before people think a Subaru is anything of a car ... Do you have a stereo in your supercar ? (     ) The Chevy V8 sound track rivals listening to a NOS1 though when i'm in the right mood The sound system haha  Uploaded with ImageShack.usIt's sound systems like yours (and those big logging truck versions) that are causing me to have to mess around with floating my system, putting it on rollers and hoping it doesn't jiggle its way off and crush me while I sleep  , I'd just like you to know.  -Chris
« Reply #51 on: July 25, 2011, 12:18:52 am » |
Looking at this picture once again ... doesn't it say "Standard Definition" somewhere ? nah ...
crisnee
« Reply #52 on: July 29, 2011, 04:06:01 am » |
Peter you said "PS: By now I know that Pink Floyd's The Wall (normal studio version) sounds way better in MFSL Gold Disc."
Are you serious? If so, how so, i.e. how does it sound better. The version I have already sounds very good. I happen to really like some of "The Wall," very much. Also was one of the best concerts I ever went to, in part due to some unexpected circumstances, and of the course the great overwhelming music/sound/show, "Welcome to the Show."
-Chris
« Reply #53 on: July 29, 2011, 08:19:35 am » |
It will be nit picking, but the MFSL Gold version sounds more full. This will be because the original sounds more harsh. Too sharp or something.
crisnee
« Reply #54 on: July 29, 2011, 08:28:40 am » |
I was just looking at Amazon for "The Wall," out of curiousity. I can't believe how many versions there are, including a remaster which will be out in September. Even the Israel Symphony Orchestra and the Ninja Turtles do "The Wall." Ok, maybe not the Ninja Turtles but we do have Pink Floyd En Bossa Nova. I bet they've got a hi-res version too.
-Chris
« Reply #55 on: July 29, 2011, 09:17:47 am » |
I think Roy (AUDIODIDAKT) dug op 9 or 11 different versions of Dark Side of The Moon. It's somewhere in this forum.
« Reply #56 on: July 30, 2011, 10:29:46 am » |
Hey Nick, are you there ? before people think a Subaru is anything of  a car ... Do you have a stereo in your supercar ? (     ) The Chevy V8 sound track rivals listening to a NOS1 though when i'm in the right mood The sound system haha It's sound systems like yours (and those big logging truck versions) that are causing me to have to mess around with floating my system, putting it on rollers and hoping it doesn't jiggle its way off and crush me while I sleep  , I'd just like you to know.  -Chris Chris hi, I feel your pain or should that be vibration . At least were not neighbours, I say this only because the spark system on the car used to make so much RF when I bought it that it would freez the picture on any televisions nearby. I wouldn't have wanted to add RF problems to the truck related wows of a fellow audio enthusiast.
crisnee
« Reply #57 on: July 31, 2011, 06:19:05 am » |
Nick said, "I feel your pain or should that be vibration . At least were not neighbours, I say this only because the spark system on the car used to make so much RF when I bought it that it would freez the picture on any televisions nearby. I wouldn't have wanted to add RF problems to the truck related wows of a fellow audio enthusiast."
Freeze the picture? Really, are you serious? And don't mention wow to this audio enthusiast. Ok, you can, I don't have a turntable anymore.
By the way, as much as I've gotten over cars (and trucks) through the years, I was really impressed by your sound system. And as much as those systems irritate when I'm listening to Astrid Gilberto or Sade, I love the sound of the just barely turning over bass burble of a 407 or Harley, or the sounds of street racing as in "American Graffiti."
-Chris
« Reply #58 on: July 31, 2011, 10:49:19 am » |
Nick said,
Freeze the picture? Really, are you serious ?
-Chris
Hi Chris, Yes, in the UK we are on digital tv now and the RF just stopped the picture as I drove past - neat feature. I could live with the feature (not watching tv at the time  ) but the problem was that the engine ECU wasn't too happy with the RF either. I put in a new spark system and its fixed now. I am defiantly with you regarding the 407 and Harley "sources".... sweat music. Nick
« Reply #59 on: August 21, 2011, 07:26:30 am » |
Btw Chris, did you recognize that the (your) flute is a typicle instrument for beginning 70's (psychedelic) music ?
I don't know how they got that in, but at some stage (don't know what year) it disappeared again too. It doesn't seem to fit the type of music; too classical. But it was profound. Some verry explicit (like Focus, or Back Home from the Golden Earring).
