November 22, 2024, 10:45:57 pm *
Pages: 1 2 [3] 4  All
Author Topic: Remote Desktop connection with iPad  (Read 71306 times)
TimDH
« Reply #30 on: October 07, 2011, 01:35:59 pm »
I was wondering if you could go by pad to USB to the PC, with the pad acting like a terminal. Of course this would tether you to the computer, but you can get a long USB cable.
Tim
« Reply #31 on: October 07, 2011, 02:08:36 pm »
Litterally this would work, yes (not with an iPad because it doesn't have a USB connection). This is what I have as the "solution" for when all other fails (which, mind you, is only about PC reources (e.g. WiFi), because it would work anyway). Don't tell anyone.
But next step up could be some cheap wireless USB connection ...
Also please notice : I didn't mention this, because it would not be iPad compatible ...
« Reply #32 on: October 07, 2011, 02:27:24 pm »
hey Peter ....
don't forget the Android fanboi's amongst us Happy
Android is now the dominant force in tablets and only set to get moreso with the likes of announcements from Amazon with their Kindle Fire ( http://www.amazon.com/Kindle-Fire-Color/dp/B0051VVOB2 ).
I think you will have a far bigger uptake of users going for remote control if you cater for Android based tablets (and phones).
« Reply #33 on: December 04, 2011, 12:55:07 pm »
Hey,
Its possible to make a webremote.
Using .html script to make a webpage on C drive (remote.html)
together with browser (browser.html) (for searching xx gallery)
Then using jquery Java for nice UI layout
http://jqueryui.com/
Adres on Phone/IPad browser for eg:
http:// IP-adres: port / remote.html
Roy
Up to the job Peter??
« Reply #34 on: December 04, 2011, 01:07:09 pm »
Hey Roy,
If you mean : is this a good solution ?
... maybe not. That is, where would be the difference with RDC (assumed that works (bug worked around), which I still didn't look into because I don't like it for a solution, SQ wise).
But thanks of course.
« Reply #35 on: December 04, 2011, 01:15:23 pm »
hmm,
I dont dare to say right now, but you are probably right
and it remains the same as RDC.
« Reply #36 on: December 04, 2011, 01:36:42 pm »
I tried everything with the iPad to let it work as I want it, but it fails. With a 3G it will work, but many (at least in Europe) won't have that (and I myself don't).
My own solution will do exactly what I want, but from that solution is the sad thing that it doesn't use the iPad (which so many people own).
Maybe it just needs more time. Maybe I must Jailbreak my iPad and see what that brings ...
PS:
Well, that's the point. If I would have liked that (for myself, for you all), I would be using that right from the start. Everybody would by now (ok, let alone that W7 bug, but as implied earlier, I think I can work around that).
« Reply #37 on: December 07, 2011, 12:41:45 pm »
Did you test it with iPad IOS 5?
Is it a known Microsoft Windows 7 BUG?
Johan
« Reply #38 on: December 07, 2011, 01:50:20 pm »
Yes.
No; The bug is obviously unknown because of what we do with it all. Remember, it just goes wrong at changing the processor affinity. I guess there's explicit (MS) code about this somewhere; If you'd only know how much is done with this with Windows Terminal Server / Citrix (which is a form of RDC), then you'd understand that it might not even be a bug but merely some kind of "control".
(this is about load balancing)
« Reply #39 on: February 26, 2012, 06:09:26 pm »
Update on this one :
It may sound unbelievable to you, or totally stupid otherwise, but the disappearing Remote Desktop Connection after playback starts is a BUG ON MY SIDE.
swoon
Luckily for me it is not that simple, because deep down MS is related too. So, the provlem exhibits when the Processor Affinity changes alright, but, only when some needed Service is not running. And, I kill that Service unintentionally ...
Solved for the due 0.9z-7.
« Reply #40 on: May 22, 2012, 10:51:57 pm »
When? We still need to buy something to controle XXH
E. Please give us a clue.
Regards johan
« Reply #41 on: May 23, 2012, 06:56:00 am »
Mooost probably around the upcoming weekend.
PS: That's what I thought about the last weekend. swoon
PPS: I must be careful somewhat, because I now recall that I solved that oproblem alright, but it still needs work on reactivating the audio PC. So, the current status is that when you need to control the audio PC directly again (and actually take over the screen from the remote PC), the remote PC won't work anymore (for control), unless the audio PC is rebooted. Now, when this needs to be solved, I can easily say that next weekend will be out of order. So I guess I will leave it at this for the upcoming version ... and who needs to use the audio PC's screen ?
Yea, me myself. And for sure others too.
« Reply #42 on: May 23, 2012, 07:03:20 am »
I've got my Galaxy Tab 7.7 charged up and ready Happy
« Reply #43 on: May 23, 2012, 07:13:27 am »
But do you have the gorgeous weather we have overhere ?
nea
« Reply #44 on: May 23, 2012, 07:29:51 am »
nea
A quick look at your weather forecast shows a nice Spring day for yourself and a nice week ahead. It's a little cool over near now running out Autumn, but the last few days have been sunny and clear.
I reckon it will take a full day to read the release notes for z-7, so hopefully the weather with turn cold by then and I can devote an afternoon to that task while sitting in front of a cosy fire Happy
