November 22, 2024, 09:52:12 pm *
Pages: 1 [2] 3 4  All
Author Topic: Remote Desktop connection with iPad  (Read 71291 times)
« Reply #15 on: June 25, 2011, 05:53:21 am »
Something is strange with this topic, because again I missed your before last post. That you already tested it with XP I must have overlooked.
Ok, so that is clear then. But not the best either. How to solve that ...
Thank you for your information,
« Reply #16 on: June 29, 2011, 12:52:30 am »
I guess I am going to try it myself.
Do you make any progress testing a remote connection with XXHE with your iPad2 in a Windows 7 SP1 configuration?
Any progress?
P.S. When I give a reply in this forum and I do a Preview I see one line. How to change this?
« Reply #17 on: June 29, 2011, 10:55:56 am »
I have been preparing a little already. But notice how difficult it is, already because of lacking services at some stage. This, besides the plain W7 bug ...
It won't go faster, nevermind I'm eager to use it myself.
Side note, but really important :
For maybe a year already I threw out my IR remote because of its so poor influence on SQ. I never told this so explicitly, but it is so. This opens the road to finding RDC (and the like) possibly better, while before it was the first thing not to do. But, this was theory.
Keep in mind Johan ... This could be working out similarly bad as WiFi does, which you already accepted to be right in your Audio PC. This all does not imply that I will spend forver ages on something like this, when SQ clearly degrades of it. So, for this moment I nice thought because it can workout (if it works techically in the first place), but as soon as it works out for the worse, I will not proceed on it. IOW, don't count on this, but I *will* try.
Can you make a screen copy of this ?
Which browser do you use ?
(I'm fairly sure I have seen this myself ! ... something with a virus on a laptop IIRC ...)
« Reply #18 on: July 03, 2011, 12:03:41 am »
......I threw out my IR remote .......similarly bad as WiFi does........
I'm using both in my system from the beginning of XXHE and I am still very happy with the sound. I will eliminate the IR remote next days.
On this System I'm using Google Chrome Browser.
« Reply #19 on: July 03, 2011, 10:24:37 am »
We will check out Google Chrome. Thanks.
« Reply #20 on: July 05, 2011, 09:56:02 am »
This seems quite unsolveable. Sorry ...
One can get crazy of all the applied "standards" in all the browsers.
Btw, if I see how Google's Gmail works ... I would exactly never want to use Google Chrome ...
« Reply #21 on: September 02, 2011, 11:40:50 am »
There's a topic (or posts) somewhere else about this. This has the iPad as a target. In brief : the real problem with this is a W7 bug, which I (by now) might be able to tackle.
Point is : no time for it so far ...
Good to know that you can solve this problem..you are great! I was hoping to use the remote desktop function for the iPad in the next version of XX.
« Reply #22 on: October 06, 2011, 11:53:07 am »
Ok ...
I guess this will be a soon popping up next subject. And let's say I am sure this is going to work. However ...
(and this will look like a commercial; it probably is)
Before everybody starts buying iPads for this reason only, maybe wait a little; Did you want to buy an iPad anyway, go for it. It's a versatile thing. But if you are reluctant to spend quite a lot of money on it because it may be such a nice remote ...
We are in the process of creating a general Windows remote "pad". If it goes like I want, it should be there in January. Price will be something like 200 euros; can be used like a general remote (wireless of course), but it will be XXHighEnd-dedicated in the mean time. Or NOS1 dedicated.
Multi-touch of course and *not* obtaining any unnecessary resources (like RDC obtains too much).
Somewhere in November we can have a first sample running. Only then I can be sure what it really will bring.
In the mean time I will be working on the iPad solution just the same.
praphan
« Reply #23 on: October 06, 2011, 03:07:14 pm »
Exciting ! I hate using my wireless keyboard as a remote for the time being.
It would be nice if you can develop a nice and easy touch screen interface.
Cheers!
Praphan
« Reply #24 on: October 06, 2011, 03:59:46 pm »
please do not forget to update and manufacture all the NOS1 USB in your order book in the meantime.  PLEEAASEEE!!!!!
« Reply #25 on: October 06, 2011, 06:42:59 pm »
Christmass, Christmass ...
haha
« Reply #26 on: October 06, 2011, 07:05:22 pm »
I would like to purchase a remote solution too.
A solution working with Android OS would be better from my perspective. (But if it will be only iPad I'll join anyway).
But the Hi-Fi democrat in me says "no hurry". Let the others get their NOS1 USB first.
 smile
s_chris
« Reply #27 on: October 07, 2011, 12:02:22 pm »
Good Idea peter. I thought about to buy an Ipad, but only for remote control of xxhe. 200€ is also ok for me.
But how do you connect to xxhe pc: wifi or another connection IR?
regards chris
« Reply #28 on: October 07, 2011, 01:14:20 pm »
This is a good question Chris. Very good ...
The most logical one is WiFi, but WiFi is not "allowed" in the audio PC.
So, move the WiFi to another PC, that one network connected to the audio PC - Done.
... Until it is clear that the Network connection is not there either. swoon
So, what I plan to do, is creating "some" WiFi connection from the PC which *is* allowed. Could be Blue Tooth at that end maybe - I am not sure yet what will be achieveable.
The more logical solution could (!) be to create a very leightweight network connection. Something which isn't seen by Windows, but which can be seen by Remote-PC communication. Think of socket-socket connection.
Next, all sorts of connections can be thought of, going from a WiFi receptable to the PC.
Let's sat that quite many options are there and that it comes down to the best one to be chosen. Which one that is has to be sorted out though.
FYI : Your XX folder also contains a TCP/IP listener which actually works and can be used for remote control (XXTCPSrv.exe, the one with the gray X). Its config data (XXWifiRemote.cfg, made for a Philips Pronto as an example) will be a bit out date though.
s_chris
« Reply #29 on: October 07, 2011, 01:33:21 pm »
Thank you, i hopped for this reply. So i am confident, you will find a consequent way for a remote control with minimised windows/ hardware influence to sound.
regards chris
