April 19, 2025, 08:53:13 pm *
Pages: [1] 2 3 4  All
Author Topic: Remote Desktop connection with iPad  (Read 72600 times)
« on: June 19, 2011, 04:46:46 pm »
I think you don't like my question about making a remote connection to take over a HTPC Windows 7 machine to controle XXHE from a lazy chair in a WiFi network. But ill give it a try.
I have done some tests with three RDP programs on my iPad : RDP iTAP, 2X Client and RDP Lite. All RDP's give the same problems after i have start XXHE. When I have the controle of the Host I'm loosing the connection after I have start XXHE. When I try to logon again I get an error. "The server denied to logon ...." When I reboot the Host and make a new connection and I start other programs all works ok. I can close and reopen the session succesfully with an active program. But when I do the same after I have start XXHE I am not able to close and reopen the session. I have disabled all the services settings in XXHE but that doesn't make any difference. Any suggestions to make the Remote Desktop connection with the iPad succesfull?
Regards Johan
« Reply #1 on: June 19, 2011, 05:17:24 pm »
Why wouldn't I like your question ? ... (I can guess something of course, but if you want it Happy)
But first things first;
Does it work with a normal RDC client (a normal other PC) ?
PS: I wouldn't know of anything not working because of XX, if you only let all the Services running ...
« Reply #2 on: June 19, 2011, 06:42:50 pm »
Hi Johan,
interesting timing your post, as it was only last evening that I revisited using my phone (Samsung Galaxy S) to control XXHE using RealVNC as the interface. Playing XXHE on my video server PC, I set the screen size to 800x480 (the same as my phones resolution) and it looked quite good actually. OPerating in attended mode was a breeze but I want to nail down the services/processes in use for VNC so I can use unattended mode. It's something I will continue with this week hopefully.
In essence I will only likely use the remote function while working around the house doing other things, and I'm sure it will be handy then.
I'll keep you posted.
« Reply #3 on: June 19, 2011, 08:32:29 pm »
That shouldn't be too hard for me here.
But anyway, the question first is : does normal RDC work. Because if not something else is the matter. Also, I don't know better than that it works here. And FYI (Johan) : the timing again is good because I want to let work my own iPad(2) work as well. But most probably I'll do this via the "Second monitor" option (and the AirDisplay app). But as usual, it takes some time ...
« Reply #4 on: June 19, 2011, 08:47:04 pm »
I have some trouble to get it working on a Vista and a XP machine. For the ipad2 it was working within a minute! Grrrrrrrrrrrrrrrrrrrr.
« Reply #5 on: June 19, 2011, 10:28:25 pm »
I succeeded with the XP machine to realise a Remote Desktop Connection with the same result as the iPad. I can start an application on the host and close and reopen this session. But when I start XXHE and I closed the session I cannot reopen this session. No response on this XP machine. The system need a restart to let the RDC work again.
« Reply #6 on: June 19, 2011, 11:22:42 pm »
Strange ... IIRC for Vista (as the audio PC) this was no problem. For W7 it was. And now I don't know whether for W7 SP1 the problem is solved again.
Boleary may know ...
« Reply #7 on: June 20, 2011, 04:03:03 am »
Wish I knew, RDC is not something I've ever used.
« Reply #8 on: June 20, 2011, 12:41:37 pm »
Apologizes, I have been confusing you with DannyD. Here is the topic about it : RDP and XXHE aren’t compatible on my Win 7 PC.
So, it is just W7 creating the problem, and I don't know whether SP1 solved it.
I guess I am going to try it myself. The normal situation first. Could be via VNC.
« Reply #9 on: June 20, 2011, 04:25:45 pm »
Why do you call this the normal situation?
« Reply #10 on: June 20, 2011, 10:05:00 pm »
From  the post "RDP and XXHE aren’t compatible on my Win 7 PC"
......So I wondered, if you can test something for me ... It must be in this exact sequence though ...
0. Do NOT have the RDC (RDP) connection (not even once after a reboot).
1. Set the Appointment scheme in XXHighEnd to what you like (preferrably the Scheme you used before when all didn't work);
2. Be prepared for Unattended, but set Stop Services Not active, and Show Wallpaper also Not active (this will give you access to the deskptop lateron - see below).
3. Click Play.
4. Establish the RDC connection. Notice that maybe already now you can't get it to work. In that case here it stops, but let me know.
When I try to establish a RDC connection (step 4) with iTap from the iPad I get the message "The server denied to logon with reason 3489660976"
« Reply #11 on: June 23, 2011, 02:07:31 pm »
Do you make any progress testing a remote connection with XXHE with your iPad2 in a Windows 7 SP1 configuration?
Johan
« Reply #12 on: June 23, 2011, 02:52:49 pm »
I am sorry - I have missed your previous two posts ...
Because of the general issues (see the link I referred to). Thus, if any "normal" means does not work (and an iPad is not much of a normal means), the "special" means will not work either.
So, I don't think you have tested the normal means, because you should use a normal PC (or laptop) for this little test.
Also notice that the "issue" as referred to in that link, does *not* occur at normally attaching to your audio PC (with RDC). Instead, this happens when the affinity to the processor changes, and this does not happen before playback. Next I am 100% sure that making an RDC connection to the audio PC where only XXHighEnd has been started (no playback yet during this boot session !) just works. So I don't need to try that. But does that work with you ?
If not, there's first another problem to be solved ...
« Reply #13 on: June 23, 2011, 03:36:07 pm »
.......because you should use a normal PC (or laptop) for this little test.
I have done this little test see: http://www.phasure.com/index.php?topic=1728.msg17307#msg17307
...Next I am 100% sure that making an RDC connection to the audio PC where only XXHighEnd has been started (no playback yet during this boot session !) just works. So I don't need to try that. But does that work with you ?
Making a RDC connection from a XP machine is no problem. After starting playback i am not able to re-open a closed session from this normal XP machine.
So when I switch affinity off will RDC work for XXHE?
« Reply #14 on: June 25, 2011, 12:00:03 am »
When I use the following Processor Settings in XXHE 09z-5-2:
core appointment = no appointment
player Prio = Nothing
Tread Prio = Nothing
AND don't switch Services off!
Then the Remote Desktop Connection between the audio PC and the iPad works ok. Close and re-open the session works ok.
But I hope that there is a solution for this problem so that I can change the above Processor settings in XXHE.
