November 23, 2024, 10:22:48 am *
Author Topic: 0.9z52 problem with more than 100 minutes files...  (Read 6616 times)
pistollero
« on: June 16, 2011, 06:39:59 pm »
Hi, i having problems on playing files with more than 100 minutes, only gives-me 8 minutes of music than stops...
in another file it only play about 19 minutes than stop....
need help...
one example file for download:
http://soundcloud.com/electro-mix-memory/yostek-2011-04-11-electro-mix
tks... in other players i have no problem with this files..
Windows 7 home premium 64bit SP1 / asus n61v laptop / Engine#3 / Dev.Buffer = 1024 /*ClockRes = no*/Straight Contiguous/*SFS = 240*/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 /-> audiophilleo2 -> dacmagic DAC -> active adam audio A8X monitors
« Reply #1 on: June 16, 2011, 07:15:50 pm »
Ok, I'm downloading it right now.
Is this with Attended or Unattended Playback ?
(with the latter there's no GUI during playing)
pistollero
« Reply #2 on: June 16, 2011, 11:58:50 pm »
is with the interface open when playing, i have other files with, 80 minutes and i don´t have problems....
i don´t know if because the length of the file or if is the type of the mp3. i had the same issue with another mp3 above 100 minutes...
tks Peter
« Reply #3 on: July 07, 2011, 07:54:58 pm »
Yep, I see the problem. Simple ... Tracks of an hour or more discard the hour with all kind of anomalies coming from that.
Solved in the next version.
