November 23, 2024, 06:51:47 pm *
Author Topic: Clock Resolution Settings  (Read 5450 times)
« on: June 10, 2011, 12:39:19 pm »
Peter hi,
In my current setup I am using SPDIF out on my NOS1 quite lot and finding this quite sensitive to XX Clock Resolution settings.
I am moving between setting of;
10ms - Slightly less detailed more pronounced bass
and
5ms - clear highs and with less pronounced bottom end
I suspect the best setting is somewhere in-between these points for my configuration.
Would it be possible to change XX to allow Clock Resolution to be set in 1ms increments ?
« Reply #1 on: June 10, 2011, 07:27:36 pm »
Hi Nick,
Yes, I certainly agree with your observations, and the 5ms seems to be too fresh or snappy at my side. This is highly dependend on other tweaks though. You'll know ... Happy Happy
I always turn back to 15, might that help you.
... Because the answer is no. Impossible (this is about OS settings).
« Reply #2 on: June 10, 2011, 07:40:26 pm »
I see, so the resolution settings available are determined by the OS, meaning a 1ms increment in XX is not possible.
Good to hear that we experience the effect of the settings in a consistent way.
