November 23, 2024, 08:17:47 pm *
Author Topic: Engine #3.exe stopped working message  (Read 15524 times)
Gerner
« on: August 20, 2007, 11:18:44 am »
Hi Peter
From time to time when I load a folders *.vaw tracks into the playlist, MS Windows tells me that Engine#.exe has stopped to work. MS then tries to look up for a solution. Ha...
It seems to be related to a few music folders of mine and all tracks in it, as I cannot just skip the track provoking the message and go to the next neither it helps to reboot XX again.
Would you think it's related to a bad rip or?
Gerner
PS! Bert has the same problem.
Troubleless playback.
astacus21
« Reply #1 on: August 20, 2007, 12:04:27 pm »
i had the same problem until i rerip my wavs with audacity (edit the wav and save as wav again!). Everything is fine from then.
Gerner
« Reply #2 on: August 20, 2007, 03:28:08 pm »
Aha, but could you re-phrase your answer. I'm not quite sure what it is your doing.   thankyou
Gerner
astacus21
« Reply #3 on: August 20, 2007, 04:59:10 pm »
I use the freeware utility audacity (http://audacity.sourceforge.net/download ) to edit my wavs and i save them again with it. I dont know what has changed, but now xxhighend is working properly.
Gerner
« Reply #4 on: August 20, 2007, 11:04:22 pm »
Well however that works..it's a kind of medicine to a fault that appears elsewhere. There must be a way that this, however it works, could be avoided?
Gerner scratching
astacus21
« Reply #5 on: August 20, 2007, 11:17:30 pm »
If you rip your cds with eac, you should have no problem and audacity isn't necessary. It looks like not every application create the same wav file, for the same song.
Gerner
« Reply #6 on: August 21, 2007, 07:32:52 am »
I do use EAC. Always. And indeed we all have different reactions from the XX in all our set-ups around.
The program you mention (nice little thing BTW) did not cure my problem. So you are right. It is something else.
Gerner  scratching
Gerner
« Reply #7 on: August 21, 2007, 08:43:52 pm »
Gerner  scratching
Maybe this is a piece of useful information?
The tracks (Complete folders) i cannot play with XX, works very well in the MS player, Real Player and Foobar Player.
So?
Gerner
« Reply #8 on: August 21, 2007, 09:53:50 pm »
Gerner  scratching
So?
Gerner
I haven't ran into this problem.  Anything the same about the files that don't play?  Like diacritical marks, long files names??? I don't know, just guessing; look for what is similar about the tracks.  I'm still using single album wav files instead of multi song wav files.... something about them I like ... (hint).  I am happy, but will be happier once cue file support is made... but, hmm, I still listen to entire albums.
Gerner
« Reply #9 on: August 21, 2007, 10:17:03 pm »
No clue Dave.
Let's see when the Master is back from his stay in Alkatraz. Maybe he has a clue. Yes I am sure he has.... Wink
Gerner
« Reply #10 on: August 24, 2007, 04:24:43 pm »
Gerner, start reading here : http://www.phasure.com/index.php?topic=131.msg664#msg664
99% sure your problem is caused by the same.
Hasta la Vista,
Page created in 0.16 seconds with 19 queries.
