November 23, 2024, 09:59:34 am *
Author Topic: XXEngine3 message  (Read 4751 times)
Eric
« on: June 03, 2011, 08:33:44 am »
after starting up my PC and starting XXHE, the following message appears:
XXEngine3 werkt niet meer.
Er wordt naar een oplossing gezocht.
After a few seconds, the message disappears and the startup sequence continues.
Everything runs fine from that point. When I close XXHE and start again: no message.
Only after rebooting, the message is there (once).
Cheers and thanks!
Eric
« Reply #1 on: June 03, 2011, 09:09:25 am »
Thank you Eric.
I suspect some strange (and conflicting) sound device being in your PC somewhere. I'm not sure how to find it, but you could start with Disabling all sound devices you see in the normal sound device list starting at the speaker icon.
If that doesn't help it will be a kernel streaming device, and maybe you can find it via Device Manager.
More easy for just now would be showing the X3PB log file after you played a little piece of track. Maybe I can see something in there.
