November 22, 2024, 09:13:07 pm *
Author Topic: Inverted Phase is not good  (Read 25600 times)
edward
« Reply #15 on: October 10, 2007, 09:14:16 am »
Hey Peter - you haven't replied to my last response, so I was just wondering where you stand on this. I just tried version 0.9m and you have done good things here. However, the SQ with Invert checked is still different than 0.9k. In some ways I like it (0.9m) better, and in other ways it lacks the detail of 0.9k. (Of course, when playing 0.9k, I have manually set the priorities and affinites the same as 0.9m achieves automatically.)
So I was wondering, is the Invert function in 0.9m the same as it was with 0.9lb, or did you make further modifications?
BTW, with 0.9m and Invert checked, there is no crackling and gapless works. Success.
April 19, 2008
« Reply #16 on: October 10, 2007, 09:45:30 am »
True Edward ... had to find an appropriate answer ... or in fact, I have/had one, but you may not like it that much. Wink
In the later versions -which exactly I can't tell- had slipped in some debug code for this matter. So, this was active in production unintendedly. blush1 This debug code did just *not* activate Invert, but the math to correct a 2 byte positive integer (as what is used in Redbook) while half of it represents negative (volts), was still active but now wrongly applied. In fact, with Invert the lot was DSPd a bit ... and certainly did not invert the phase.  blush2
Now it is working properly, and what you might perceive from it is untouched data, whereas before it was mangled with (though unintended). So now the phase is just inverted, nothing else. So what you are dealing with now is that maybe you have to learn how to hear the difference.
But careful now ...
The Phase Inversion, though originally setup to satisfy those who are disturbed by wrong absolute phase, when finished was not officially implemented at first because of the perceived idea of it not being useful because it hardly occurs that a whole song is recorded with wrong absolute phase, and merely individual elements (singer, guitar, the snare drum) are. However :
When the Q1 was introduced, it occurred that at certain "levels" of Q1, now Invert suddenly could make the difference of the world. Btw, this was when the bug as described above did not get into the production version yet.
Moral : When Q1 starts to be, say, nasty, it is exactly the point where Phase Invert will drop your jaw. That is, it looks like the general experience from people; not only my own. This phenomenon by itself implies that there are also Q1 settings where Invert hardly makes a difference (think of +90 vs. -90 degrees).
Phase is the most important phenomenon within audio IMO. Not so much to the sense of "proper phase" but far more in the area of properly aligned.
« Reply #17 on: October 10, 2007, 09:49:33 am »
I doubt that ... although you could have done it technically. Happy
edward
« Reply #18 on: October 10, 2007, 10:06:57 am »
I think I mentioned this before. I also felt that the detail I was experiencing (with 0.9k) might have been inaccurate (or crazy exaggerated in certain frequencies) and it did sound (dare I say) a bit too digital (or maybe what you refer to as squary).
...there are also Q1 settings where Invert hardly makes a difference (think of +90 vs. -90 degrees).
That's exactly the impression I was getting while playing around with 0.9m. Phew! I thought maybe you forgot to activate it or something.
OK, well, thanks for the explanation. All makes sense now.
April 19, 2008
