April 05, 2025, 02:45:59 pm *
Author Topic: XXHighEnd Model 0.9i-1 (bugfixes)  (Read 8626 times)
« on: August 14, 2007, 06:05:32 pm »
A few bugfixes opposed to 0.9i :
  • RealTime priority could not be selected for Engine#3.
    Note : It seems that not all Vista systems support this properly. Check Taskmanager ! (the program reports it works, but it really is not with some (?) Vista systems).
  • Player Priority could not be selected.
  • Changed wrong wording "Highest" and "Lowest" into High and Low for priority settings.
  • Possible error message at startup about an illegal 0 value.
    A new value 0 was added to the Q1 Parameter because of this (actually works one tad lower than 1 which was lowest before).
  • Built in messages for presumed faulty Absolute Phase twist calculation (causing loud cracks during playback). If you have the loud (very brief) cracks at Inverted Phase, please check whether they are there with not Inverted Phase. If so, please report.
    Edit : ... which does not help !? : http://www.phasure.com/index.php?board=2.0
  • It was intended that Vista would start with Engine#3 as default when not selected earlier otherwise. This did not work (checking this is a tough job, so I hope it now works).
* XXHighEnd-09i-1.zip (820.63 KB - downloaded 785 times.)
