April 19, 2025, 03:57:31 pm *
Author Topic: 0.9Z-5 AutoHotkey starts the old version  (Read 10496 times)
hwk
« on: April 24, 2011, 06:46:25 pm »
Hi there,
I'd like to have some help here: everything works, but the AutoHK. The HK button gave the message that the older XXHe version was still the path. I removed everything about AutoHK, rebooted and followed the thread nabout installing AutoHK. I copied the 2 mentioned files from the 0.9Z-5 map to a new made AutoHK map and made the suggested adjustments in the "properties". But, pressing the AutoHK (after starting 0-9Z-5) still gives the message that the directed map is 0.9Z-4-1. When trying to play unattended, the music doesn't start after a while. Also, hence I presume, when I stop XXHe and use the Alt-X combination, the older XXHe starts up. I'm a bit frustrated.
Furthermore: I recently opened the settings from my soundcard. It gives some settings for "Latency (sample number)". The standardsetting was 256. I set it to its highest setting 1024. I chose this to have more headroom in settings for Q1. Am I right? And am I right, that I have to put the setting for Engine#4/Adaptive Mode the same 1024? What is the best Q1-setting with this? No samples are given anymore in the new version. Or is it part of the hobby to stumble here to a "right" setting? Happy
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #1 on: April 25, 2011, 06:41:26 am »
Hi there,
Your problem seems to be that you are actually starting the old version indeed;
I can't tell whether you installed 0.9z-5 over (in) the folder of the old version, but in any case I'd say the shortcut you us to start XX just points to the old version (hence xxhighend.exe in the old folder). So, try to imagine that AutoHotkey just tells you the truth, and you will be able to solve the remainder.
About your latency settings ... There must be a misunderstanding somewhere;
Samples are shown for Special Mode only, and that never changed.
More headroom for Q1 ? hmm ... You can set it to 1024, and what you will do is, well, set the device buffer to 1024. What can I say ?
Somehow (and again) this is mixed with Special Mode by you (remember, you are taking Adaptive Mode here), where indeed it would be true to speak about more headroom as such (just more available settings). But not so for Adaptive, where any chosen Device Buffer Size must equal the real Soundcard's buffer (which you changed from 256 to 1024) and next Q1 must be set to 1 optimally. 2 is allowed as well, but you would be doubling the internal buffer size, which then won't match the real soundcard's buffer size anymore. Not wrong per se, but let's say "strange".
hwk
« Reply #2 on: April 25, 2011, 09:44:17 am »
Hello Peter,
Thanks for your reply.
I made in the C Root a Main Folder named XXHe. In there I made a subfolder with 0.9Z4-1. Next to that folder, I made a new folder with 0.9z-5. I copied the AutoHK.exe and XX.ahk from there to a new (I threw away the old version of it) AutoHK Folder placed in the root. I don't see, what I did wrong here. Still I get these wrong settings. Is there no script somewhere in Auto HK that tells it the right direction?
About the "right" Q1 settings: I understand my misunderstanding, now, finally  sign0144qp7 (sort of)
« Reply #3 on: April 25, 2011, 01:08:33 pm »
Ok, I can't follow precisely what you can do all (automatically !) wrong at working this way (copy the ahk files like this), but this is not in any prescription that I know of. But at this time I'd say that you start the wrong ahk from the wrong folder (because the shortcut (or auto-startup) to *that* is the wrong (old) one) and I really can't oversee what will be happenng then.
I know you told it's a little different from what I just suggested (because you deleted the old one etc.) but things are not what they seem in Vista/W7 and shadow copies may float around.
Edit the xx.ahk file (Notepad), adjust the message in there, and cause your new message to show up at starting ahk. It does not ? then you are using the old version somehow somewhere. Try to undo that.
PS: There's another thing I can't oversee from where I am at the moment, and this is whether there could be a real culprit somewhere. So if one person could confirm that for him it really works as usual, I would be very happy about that (I always use ahk in a different way, and a real culprit would go unnoticed for me).
« Reply #4 on: April 25, 2011, 02:16:19 pm »
When I installed z5 I had a similar problem so after some study I found out that AHK gets its path from a systemparameter that is set at the first start of XXHighEnd. I also had to remove the temporary data from Z4 and make the new directory C:\XXData.
I don't know if this is the complete answer to your problem but maybe it will help.
(I also had the additional problem that Z5 was in a wrong directory)
« Reply #5 on: April 25, 2011, 02:17:34 pm »
Don't know if this will help cause I'm not sure i follow everything that's been said here but: if the autohotkey icon is showing up in the lower right taskbar right click on it and select exit to turn it off. Now go to your new 9z-5 folder and start XX from there by double clicking the exe file. Now restart autohotkey and all should work.
hwk
« Reply #6 on: April 26, 2011, 12:44:30 am »
Hello Peter,
my pal JohanZ was here tonight and he sorted it out for me: I had a main folder named XXHe with subfolders for the subsequent versions of XXHighEnd. This worked fine with only one version of it, but clearly not with more. He placed the two versions in the root and after filling in the settings of the two programs everything works just fine.
Enjoin' Jan Akkerman live (10000 clowns on a rainy day) now. Almost heavenly sound.....
Page created in 5.1 seconds with 19 queries.
