April 02, 2025, 09:49:14 am *
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18  All
Author Topic: HOW I´VE BUILT MY NEW PC FOR XXHIGHEND AND WHY I´VE CHOSEN THE COMPONENTS  (Read 523415 times)
« Reply #75 on: May 07, 2012, 04:21:50 pm »
On off is managed by the motherboard via the large multi pin ATX connector. You can only plug one in the mobo so only one psu can be controlled. It shouldn't be hard to figure out which of those pins actually controls the on-off state of the psu... You can fool the other supply in being set by the motherboard by proving the right pin(s?) with probably 5V. This is tappable from a molex on the connected psu.
Am I ranting?
regards, Coen
stefanobilliani
« Reply #76 on: May 07, 2012, 04:22:44 pm »
Probably because the the PS need to be connected to the mobo to be turned on . This is my guess .
s
Edit ; we should take a look at a generic PS schematic and find out what is the circuitry that provides the turn on and see if we can do a little mod to do that from the MB or a molex itself .
Here is an example :  http://www.pavouk.org/hw/en_atxps.html
and this also should help a bit : http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #77 on: May 07, 2012, 04:40:07 pm »
My PC for XXHighend:
Hi there Harald. I see this is your first post in here. Well, great post. Thanks !
« Reply #78 on: May 07, 2012, 04:45:42 pm »
I see this is your first post in here...
Missed that. And you're a NOS1 owner. Welcome. Looking at your sig it looks like you've got everything working well already. Cool.
« Reply #79 on: May 07, 2012, 04:51:15 pm »
Hey Coen, Stefano, thanks for the ideas. I'll look into this when I can. Meanwhile let me know if you come up with anything else.
Cheers, Mani.
stefanobilliani
« Reply #80 on: May 07, 2012, 05:21:16 pm »
OK  let me present  my Pc for High End  Happy :
Processor :
Intel i7 2600k at 3,4 Ghz , 4 cores , Hyperthreading , Sandy Bridge , Socket 1155
Motherboard :
MSI Z68A-G43 (G3) with USB3 ( Renesas driver )
Memory : Kingston KVR1333DN9K2 16GB (easy to overclock and looks stable ) .
CPU Cooler : Cooler Master Hyper 212 Plus (set to minimum speed fan )
Disks : 2X Seagate Momentus Laptop ( OS and XXHighEnd ), 1X Samsung Laptop(Music)  . Sata . Will upgrade to new and better Disks later.
Case and PS (400watt ) are generic but good . Later will upgrade PS to a silent one probably from Corsair .
Graphics : Internal , no overclock .
OS: W7 , sp1 from updates ; It still gives the 15msec resolution .
Wireless mouse and keyboard by Logitech .
Well I am very happy for now with the set up , which was all in a look to save some money ( thank you Peter for suggestions of the CPU ) .
The only problem I encoutered initially was the impossibility to go into Minize OS correctly . After some trial and error with the BIOS settings  , it works very well again . I did disable the UEFI boot over other things .
Another thing I did noticed is the DRAM timings ( and overclock ): they seem to produce different sound presentation .
For now I am not overclocking the RAM , and use a timing like 8-8-8-20 . Also the timing suggested by the MSI memory-z works very well ( and it is rather defined with 10 values to set ) .
Some spare tests with the Latency checker , shows values as low as 8micro seconds , and overall the PC is very very smooth at use .
Great , thank you all around !
Stefano
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #81 on: May 07, 2012, 06:46:31 pm »
Stefano hi,
I also noticed this, on my old pc I used to get the front side bus going as quickly as possible and work on timings. Generally faster was better. My new pc build was carefully specified to give quite fast memory performance. Good to know that others are getting similar effects from memory speed.
Best,
« Reply #82 on: May 07, 2012, 07:50:41 pm »
I am not so sure Stefano said that ?
And actually I'd think it is the other way around (theory only !)
Edit : FWIW I have mine running at 833Mhz (can do 2100).
stefanobilliani
« Reply #83 on: May 07, 2012, 08:43:57 pm »
It's  a matter of bandwith probably ; so then the refined timings lend to a more relaxed listening .
I like to reason in analogy to my amplifiers , which ar both very large bandwith , fast yes , but also particular in topology and super enjoyable .
So instead of overcloking we could *infact* think of underclocking .... at times . lol
S
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #84 on: May 07, 2012, 08:57:25 pm »
Sorry I should read more carefully !
Will be trying under clocking later me thinks  Happy
Stanray
« Reply #85 on: May 07, 2012, 10:15:26 pm »
Hi all,
OK, now it’s my turn to show you my PC. I recently got my Phasure NOS1 and I build a PC for XXHighend exclusively.
Thanks to all the valuable information on this site I borrowed ideas and knowledge and brew my own specs. The goal was a simple PC, with low noise levels and an audio-component appearance.
PC case: Modu MD11
Processor: Intel i7-2600S for low power consumption (65W)
Mb: Asus P8H67-V
RAM: Kingston DDR3 16GB
HDD 1: WD Velociraptor 300Gb (for XXHighEnd and Windows 7 Ultimate 64bits)
HDD 2: WD 2Tb Caviar Green
DVD drive: Plextor
USB 3.0 PCIe: ASRock
PSU: Silentmaxx FanlessII. With 500 Watt it is oversized, but one of the best fanless PSU’s
I used no casefans, only 1 NoiseBlocker 120mm fan on a Thermalright AXP-140RT low profile CPU cooler. Later I will experiment with the fan disabled.
For the XXHG settings please see my profile below.
And the SQ? I’m very impressed and pleased. It surpasses all the DAC’s I tried here (DCS Debussy, Audionote 4, PSAudio, Bryston, etc).
Finally I’m released of that hard to describe digital fog nea that many people don’t seem to notice, but of which I became allergic for the past 25 years.
Thanks Peter and other forum members.
(How do I downsize this pic??)
[I've done it for you - Peter]
« Last Edit: May 11, 2012, 08:00:45 pm by stanray » Logged
« Reply #86 on: May 08, 2012, 12:51:44 am »
Hi stanray, congratulations for that great system including the rack and the Purepower conditioner, the NOS1 in black looks great although I almost can´t imagine it other than blue.
My working pc is almost like yours, maybe I´ll try it with the NOS1 to see how it sounds, the mb that I use in that pc is a P8H67-M EVO, with a i7 2.600 and 16Gb kingstone, a pasive GPU and it is very silent also. Making some arrangements I could make almost a clone of yours. I´ll follow your changes to see if I can apply it to my computer and compare it with the one that I have now dedicated to music.
The Modu MD1 looks very nice, where did you buy it, in Italy?
« Reply #87 on: May 08, 2012, 08:04:08 am »
Cool Stanley. You really made a nice job of it. Thanks for sharing.
Now, what about something like Coverart showing in that right leg of the NOS1 eh ? ... oh, oops. Yea, so stupid. Let me promise that for the next version after 0.9z-7 (and not ages after it).
praphan
« Reply #88 on: May 08, 2012, 08:14:47 am »
The Resorator comes as standard with two water cooling "blocks" one for the CPU and one for a graphics card. You don't have to use the Graphics cooling block but I did for fun. The standard heat sink on the card can easily be removed and replaced with the secong cooling block. The return water from the CPU cooling block is then routed into and out of the Graphics cooling block on its way back to the radiator.
Hello Everyone,
Just a gentle warning for anyone who will attempt to use water cooling system in a city which has regular black out like Bangkok. You tend to use UPS to feed power to your audio PC. In my case, I use true on line UPS. Please make sure that you power the water cooling pump from the UPS source too. Otherwise, when power fails, cooling system will stop while CPU is still running. Of course, mobo will do the shut down work automatically. But it is safer to run cooling pump from UPS source.
Please see more details in my post last year with some photos. It has been almost 2 years that I use Reserator 1. It is sturdy and very reliable.
http://www.phasure.com/index.php?topic=1662.msg16787#msg16787
Praphan
praphan
« Reply #89 on: May 08, 2012, 08:20:07 am »
Well Peter, it is my speculation that you will fire up the screen on the right leg from the long waiting 0.9z-7 onward ! But we can wait.
regards,
Praphan
