phantomax
« Reply #150 on: July 05, 2012, 01:14:57 am » |
Hi all, Checked again with DPC and XXHighend running in attended mode. There are several peaks when the music starts to play and then zero.
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
« Reply #151 on: July 05, 2012, 09:01:48 am » |
Crazy ...
« Reply #152 on: July 05, 2012, 09:07:17 am » |
Crazy, especially because I already dare say that from these very few obervations (observators) - and despite it would be statistically illegal to draw conclusions - ... that what people heard before, is confirmed by looking at the graphs now. (boleary might like to post some)
Coen seems to be off, but maybe he is not at all. So, sound is best at 1333 and latency is quite high. But how does the latency show at 1066 when sound is worse. Higher ? (suring playback I mean)
« Reply #153 on: July 05, 2012, 10:43:36 am » |
Latency when playing is a little lower with 1066Mhz than with either 1333 or 800.
Right or wrong, i dunno. I much prefer the more focussed and dynamic and "musical" sound when in 1333.
How to manage the latency? Practically no mobo tweaks applied (graphics to 400 Mhz). I allways got the impression this board is a little slow. Gonna update some drivers soon.
Regards, Coen
Regards, Coen
stefanobilliani
« Reply #154 on: July 05, 2012, 10:50:59 am » |
How to manage the latency? Regards, Coen
Oh look , I did it : this is obtained by the means of tweaking the MOBO , in some ways .... Without the setfsb software .
May 27 -2013 , 0.9z-9
W8 pro 64bit, UEFI sata ahci mode . i7 (8 cores ) 2600k RAM : 16Gig XXHE on OS disk Music on OS disk Playback drive on USB3 to 4Gig Pendrive Mobo USB 3 to Oversampling dac at 2X KS adaptive , ArcPredict , dev buffer 1024 Q1=8 , Q5=3 , res 1msec Minimized OS , stop all services X-tweaks : 45,100,1,1,1, stable , optimal Disk Utilization : Split File Size: 120 ,max the same as SFS Memory Organization : Straight Contiguous
stefanobilliani
« Reply #155 on: July 05, 2012, 12:53:26 pm » |
Also , the graph seen in the previous post remains the same regarding RAM speed . If select 1066 or 1333 is the same , and it remains so playing music .
« Reply #156 on: July 05, 2012, 01:50:35 pm » |
Are these world records ? I don't follow this kind of stuff (at least not for a longer time now) but I never saw something like this ...
stefanobilliani
« Reply #157 on: July 05, 2012, 01:53:28 pm » |
this is done in a simple way . It's not a record , but the sound is gorgeous .
« Reply #158 on: July 05, 2012, 02:13:55 pm » |
this is done in a simple way . It's not a record , but the sound is gorgeous . How did you do this? I was unable to get any significant change in latency by changing the memory frequency. Results below; 824 Mhz; 8-15 at idle, 18-35 with XX playing 1373 Mhz: 8-15 idle, 12-22 with xx playing 1648 Mhz: 9-13 (very occasional spike to 17-19), 14-20 with xx playing (very occasional spike to 50+)
stefanobilliani
« Reply #159 on: July 05, 2012, 02:44:25 pm » |
OK , this is mainly a little work of tweak , and precisely is ..... ready? Fine tuning the BUS speed . It is allowed by the ( very nice ) MSI mobo via software . The Bus speed is set by default at 100Mhz or so ; lowering that speed by a couple of Mhz do the magic , and I say magic becouse it is listenable ... So take a look also at the CPU-Z picture attached ; If I can have the exclusive to say what I feel about the music ( which I have been playing for over 15 years ) in this tweak well , it is like suddenly an heavy tapestry has been raised , or like when I go to a live concert and feel all the air and freedom around the instruments . This is good .
phantomax
« Reply #160 on: July 05, 2012, 03:15:32 pm » |
Hi, Stefano! Nice to see you've notice the same kind of improvement in the sound. It's seems that we have reach the same spot in different ways. But I have a doubt, What were your core frequency before the change? I've notice that is higher that one specified in the CPU: 3,89 vs 3,40. Maybe I am wrong but I thing it is overclocked. If so, you must check your temperatures with RealTemp or something like that. Another difference with my settings is the multiplier: yours is ¡x40! and mine x7,5. I think I'm getting lost  Maxi
stefanobilliani
« Reply #161 on: July 05, 2012, 03:23:28 pm » |
Hi, Stefano! Nice to see you've notice the same kind of improvement in the sound. It's seems that we have reach the same spot in different ways. But I have a doubt, What were your core frequency before the change? I've notice that is higher that one specified in the CPU: 3,89 vs 3,40. Maybe I am wrong but I thing it is overclocked. If so, you must check your temperatures with RealTemp or something like that. Another difference with my settings are the multiplier: yours is ¡x40! and mine x7,5. I think I'm getting lost  Maxi Ha-ha  Maxi yeah it is a 40times instead that the default 34 ( from which the 3.4 GHz comes ) . Following some Peter suggestions between the writing , I also like my PC Fast !!! (yeah ) . So let's go to 4GHz . Of course everything is under my control . Temperatures are around 38 degrees .To answer your question , CPU Freq. before the "tweak" was just about 100MHz faster or so . s
phantomax
« Reply #162 on: July 05, 2012, 03:34:46 pm » |
Ok! I see.  The core speed is the Bus speed x multiplier. My bus speed is a lot higher than yours: 275 Mhz vs. 95 Mhz. Obviously I am not an expert in this stuff.  regards Maxi
stefanobilliani
« Reply #163 on: July 05, 2012, 03:43:53 pm » |
Ok! I see.  The core speed is the Bus speed x multiplier. My bus speed is a lot higher than yours: 275 Mhz vs. 95 Mhz. Obviously I am not an expert in this stuff.  regards Maxi Thanks God I decided to buy a Big PC ( lol ) , that said we are all learning ...
« Reply #164 on: July 05, 2012, 03:47:58 pm » |
Everybody has different dacs and xx settings. Wasn't special mode all about low latency?
