April 05, 2025, 12:36:22 pm *
Pages: 1 [2] 3 4  All
Author Topic: NOS1 to the next level ?  (Read 55155 times)
« Reply #15 on: April 19, 2011, 06:49:02 pm »
1000 euros comes first then. scratching
But I can't imagine how a better copper cable could ever help here. This is the most data as data can be, and if that fails, well, then all fails (in the midst of the OS).
« Reply #16 on: April 19, 2011, 07:21:04 pm »
Oh, I'm not going to try this. I'm saving my pennies for future 'official' NOS1 upgrades...
BrianG
« Reply #17 on: April 20, 2011, 12:44:26 am »
I have stumbled across a way to make the NOS1 significantly even more fantastic than it already is
...its not a new paint colour is it  innocent
Suteetat
« Reply #18 on: April 20, 2011, 04:43:58 pm »
This is one of those things,you should not expect cables carrying digital data to be that important but digital cables, Lynx breakout cables, USB and firewire cables, heck even Toslink optical cables are not all made equal (in their respective group) some do sound significantly better than stocked cables by a big margin so why not cable from computer to NOS1 Happy
praphan
« Reply #19 on: April 20, 2011, 06:29:29 pm »
Yeah, I fully align with Doc.
This is some of the woodoo stuff that I don't understand. Digital signal is supposed  to be either 0 or 1. But I can guarantee you that my Lynx digital cable yield different SQ than Doc's Cardas Clear custom made one.
Woodoo !
« Reply #20 on: April 20, 2011, 07:46:05 pm »
Hi guys,
I'm proberbly as interested as anyone to see what Peter makes of this. It's not a passive component or cable upgrade.
I have had more time to form an opinion and play about with lower buffer levels than are the norm to compliment the change to the DAC, I'm convinced there is something very good here. What I have in my setup is a long way from a productised solution though, this is Peters domain if he likes what the change delivers enough to think it worthwhile.
There are a couple more things that might help  :)but I want to compare notes with Peter on these.
« Reply #21 on: April 21, 2011, 04:31:42 pm »
All the cables in the "SPDIF" domain are about audio. This is not "data" as such. So, all what transports audio does matter.
If you think that the remainder mettrs too, better start exchaning all your ATX cabling.
Who knows ! haha
Suteetat
« Reply #22 on: April 21, 2011, 04:53:54 pm »
Who knows ! haha
Did that Happy
My Seatronic power supply has detachable power cords so out went the stocked cords and came in cardas wire Happy
Now I am using Weiss INT202 firewire/AES-EBU converter and I also find firewire does matter as well, for whatever it worth.
Even just disconnecting power lead in stocked firewire cable helps quite a bit. Don't ask me why though Happy
praphan
« Reply #23 on: April 21, 2011, 06:20:31 pm »
Who knows ! haha
May be you can help clarify. I am not quite sure if I understand correctly. But S/PDIF  interface is used to carry compressed digital audio. The electrical signal in the chain is still digital not analog. How digital audio and digital data are different?
Thanks
« Reply #24 on: April 22, 2011, 04:47:40 am »
Suteetat, I was talking about connectors for data cables, not power cables. Regarding power I guess all may matter again. Happy
Praphan, digital "audio data" as such is subject to the timing of it (data bytes (actually words or samples) must arrive at precise intervals). Normal data is totally unrelated to timing. It just must arrive correctly; if tomorrow, then tomorrow. yes
If it's not clear, ask ahead.
praphan
« Reply #25 on: April 22, 2011, 05:08:33 am »
Thanks Peter, crystal clear.
Praphan
Suteetat
« Reply #26 on: April 22, 2011, 06:38:53 am »
ah, I see, kind of done that too Happy Apparently, at least in the DIY and mod market here, Oppo DVD/Blu ray is quite popular item for third party modification and there is a eSata cable that some people swear by that makes a different to the picture. I have no idea why there is an eSata cable in a blu ray player, probably from transport, I suppose. Anyhow, so I switched all the internal esata cable as well just in case Happy since it does not cost very much anyhow. So, whatelse can I change that would not involve blow torch or soldering iron Happy
Changing cap on mobo sounds like fun but not something I want to try for now Happy
« Reply #27 on: April 23, 2011, 02:22:06 pm »
Update
The post started with the tile "NOS1 to the next level ?" the "?" was there for a reason  unhappy. I have applied a second change now and IMHO it's time to drop the "?" Happy (at least in terms of NOS1 potential).
What has changed ? very little (physically) and a great deal (sound) ... after the second change (very small change really and related to the first) the sound has just improved by another big step all over again  Happy Happy Happy. More hash gone (I didn't think there was any left after the 1st change !), better bass performance (just listening to the hinges and doors in my house rattle as I write), improved dynamics and slam, sound more separated from the speakers etc etc.
You can really hear the differences that XX software settings make much more with the changes in place so it took a while to get to the sweet spot but its defiantly there now holiday
I will send the details of change 2 to Peter to look at as well.
« Reply #28 on: April 23, 2011, 02:32:23 pm »
Update
WTF !  oops Are you doing.....
  swoon
« Reply #29 on: April 23, 2011, 03:00:02 pm »
  swoon
Gerard hi,
Just the stuff I have always done with DACs but the results here are bigger than usual. I think it is a function of how well designed the NOS1 is. If you stumble on a slight bottle neck and address it lots "gets through". I'm very interested to see what Peter makes of the changes how they measure etc. I'm always a bit cautious of posting claimed improvements just in case they don’t work elsewhere.
Hope your enjoying the sunshine !
