November 23, 2024, 05:28:49 am *
Author Topic: 0.9Z-5  (Read 30176 times)
Suteetat
« Reply #15 on: April 26, 2011, 02:39:42 pm »
I have not had much chance to listen to 05 version just yet but I had a lot of problem installing it initially. Since I was being lazy, I did not upgrade the beta version of SP1 when official SP1 became available last month. ...
Chaps,
Just to get this right, I have to upgrade to the official SP1 before I can go to 0.9Z-5 and then switch HT back on?
Wasn't there some issue with the sound of the official SP1 or did that get sorted?
Sorry for not keeping up  blush1
Brian
hmmm... I am the nnly person so far that reported problem installing z05 with RC1. I am not sure if anyone else is having any problem.
As far as SP1, I think it sounds great, as long as clock resolution is kept high. At least now I don't have any urge to remove SP1 and go
back to RC1, but that's just me Happy
« Reply #16 on: April 26, 2011, 02:55:41 pm »
Discussion of SP1 is here: http://www.phasure.com/index.php?topic=1668.0
BrianG
« Reply #17 on: April 27, 2011, 10:21:44 am »
Ok so the procedure is to try 0.9Z-5 with RC1 first and if that doesn't work go to SP1, with SP1 roll back all the auto update except SP1, remember to turn HT on and I should be good...  thankyou
« Reply #18 on: April 27, 2011, 03:05:31 pm »
Maybe I haven't been following what is going on, but whatever it is you think that may, it can't be related to any SP1 etc. on XX matters. Except for SQ of course, and there you shouldn't gamble. That is, I'll stick to my RC as long as it lasts and will see what happens after that (which should be November/December this year).
Sorry if I missed what this really is about !
BrianG
« Reply #19 on: April 28, 2011, 04:32:31 pm »
Thanks Peter for clearing this up....  smile
ivo
Music lover
View Profile WWW
« Reply #20 on: May 02, 2011, 11:37:37 pm »
Hello all,
I have been out of here for some time, now back again.
Moved from z3 to z5:
z5: agree it is more detailed and blacker at my system. Bass is more cloudy I guess, but in specific cases only. This all is WITHOUT ramdisk. Compared z3 on RAMDISK vs z5 on SATA drive. Almost no difference. I would say SATA case is more lively?
One problem: whenever I change dev buffer, Q1 jumps to 14 always? I set it to any other value, but next time I launch XX it is again 14. I am running w7 RC.
Ivo
« Reply #21 on: May 03, 2011, 01:28:09 am »
Thank you Ivo.
The Q1 thing has been reported, but seems to bother a few only. Will be solved !
