November 23, 2024, 12:34:28 pm *
Author Topic: how to start MC and XC?  (Read 20488 times)
minzyman
« Reply #15 on: September 04, 2011, 07:26:43 pm »
Yes, great find Coen! This worked for me too. I couldn't play Straight Continuous or MC because of the privileges problem, and ran this:
I used a little trick to enforce the lock pages privilege for the administrator role. I stumbled upon a tool that is part of the win2003 toolkit: ntrights.exe. With this tool placed in the windows\system32\ directory I ran it form the command prompt:> Ntrights +r SeLockMemoryPrivilege  -u Administrators (this command is case sensitive).
Works great. All set.
Thanks!
/Lee
W8 = Jan 10, 2013 (1.186a)
Zalman (Fanless) Chassis with ZUMA Design: Intel DH77EB MB and Intel i7 3770s (quad core) CPU / 16GB RAM / Win 8 Pro SP1 from OCZ SSD / second (Playback) drive OCZ SSD / music on 3 TB eSata HD / XX on OS disk SSD Engine#4 Adaptive Mode / Q1/-/3/4/5 = *6*/-/*1*/*1*/*1* / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4.0* (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = *Core1-2* / UnAttended (Just Start) / All Services Off  / No Running Time / Minimize OS / NO XTweaks / 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 at *8ms* -> main amps -> speakers. No remote, screen off at unattend playback, cd rom unplugged, ethernet cable unplugged, max core temp 117 degrees F.
