November 23, 2024, 01:41:21 am *
Author Topic: A few more thoughts on an unpleasant subject  (Read 30180 times)
« Reply #15 on: March 06, 2011, 07:47:31 pm »
but making decent linear PSU for at least 200w is almost impossible from size and heat
I talked about it long ago, but if all is right within a couple of months I may have a 350W linear PSU - matchbox size ...
Do you mean a PSU for the pc Peter? And can whe buy it too?
« Reply #16 on: March 06, 2011, 08:04:38 pm »
Sure and sure.
Btw, matchbox-size is the size of a match box. 6x4x2cm or so. Includes all ATX output voltages.
« Reply #17 on: March 06, 2011, 08:12:06 pm »
Sure and sure.
Ok and is that any difference than my Winmate things? Or is it simulair? Small it is. And can you use more than one to give each there own PSU. Or doesn't that make any differences.
« Reply #18 on: March 06, 2011, 08:54:00 pm »
No no, it is nothing of the kind (and much smaller). And just meant to officially mount inside.
Yes, you can use more of them I guess, but I sure wouldn't do that in one and the same PC.
I guess that's all I want to say about it now. Took too long already ... Wink
« Reply #19 on: March 07, 2011, 06:44:31 am »
Ok Thank you!! We will wait for further development posts ;-)
crisnee
« Reply #20 on: March 15, 2011, 04:55:30 pm »
Boleary,
I think you misunderstood things here. The reason behind me not taking part in discussions anymore is because I hardly use XXHighEnd.
Marcin
Hi Marcin, if you're still around here somewhere,
I'm just curious why you no longer use XX. Particularly as you've always been so interested in bettering it (tweaks etc) and it now seems to be at it's very best, and much more stable contrary to Peter's trepidations.
In the past I'd been fed up with the tweaks (not anyone's in particular and only because it meant too much time to invest to implement them) and endless versions and also endless "WOW the sound is Sooooo much better," every version and tweak--how much better can very good initial sound really get, over and over again? Same kind of stuff as "crazed" audiophiles of The Absolute Sound and such--they've been improving audio starting at the best ever and gone up from there in leaps and bounds since before the beginning of Quad, never mind Quantz and Mozart--but don't get me started--sorry not my fault I'm in the hands of--just ignore the earlier parts of this sentence, I really curious to know why XX is out of your life (for the most part) at this point in its development.
So anyway re pre rant, I'd stop using XX or go to an old version for a while. But now, it really does seem better and stable, XX-Geeky that is. So just curious, if you have the time and inkling to reply, after the rant in a frenzied Db minor.
Chris
BrianG
« Reply #21 on: March 15, 2011, 06:36:22 pm »
Not to offend anyone here, but in my experience of working with IT people, "they" can be difficult to communicate with.  I would say, take an engineer and then remove any sense of perspective and this doesn't come close.   Wink
They don't suffer fools gladly that is for sure unhappy
The whole IT business is layered between users and the chaps that produce the goods and those layers are simply in place to allow "simple folk" to communicate with "the ones that know".
The effort and concentration to get stuff to work is very fatiguing so if they lack the social graces who cares as long as they deliver?
