November 27, 2024, 02:04:09 pm *
Author Topic: XX Geeky hesitates and continues  (Read 26353 times)
« Reply #15 on: March 27, 2011, 07:39:54 am »
FYI (should it matter), much of the time I've been playing XX in attended mode
Yes, sure that matters ! Plus, this is not how this topic started out ...
Attended is always way more UNreliable on these matters !
If you had this real crash one time, it's okay. If you had it twice in three months, still ok. But more ? not good (and sure not intended).
On another matter, for best sound you should always use Unattended. This has nothing to do with Services (not) shutting down. Unattended has been there for almost ever, and thus for a reason.
PS: But by now I don't know whether your stalls are mostly about Attended or Unattended ... Happy
« Reply #16 on: March 27, 2011, 10:26:04 am »
Peter, Ok, finally, my sneaker net mail arrived. I'll send the file via pm.
Thank you Chriss.
But did you "re-create" it or something ? I mean, I don't see anything wrong with it. 1:29.00 and it just plays.
Tried Normalized Volume on it as well (per track), which can be "an early cause" of the error report about the header. But still all okay ...
I am not sure whether I changed things in this area for the version I use, but I don't think so.
crisnee
« Reply #17 on: April 06, 2011, 07:11:14 am »
No, I didn't change it. That's really odd, because no matter what I tried I couldn't get it to play, always got the same error.  Oh well. I'll try it again some time see if it's cured itself.
Chris
« Reply #18 on: April 06, 2011, 07:12:15 am »
I can send it to you if you need it. Happy Happy
crisnee
« Reply #19 on: April 07, 2011, 03:30:28 am »
By the way Peter, re the hesitation problem. After about a week of XX with a 20 minute hd spin down instead of 10, I've only had one minor hesitation (while I was awake that is, music puts me to sleeping a lot especially when I'm in bed going to sleeping ) and that within for about .5 seconds, a few seconds before the end of a 5 minute track.  drinks
Can't a guy have a beer by himself around here?
Chris
« Reply #20 on: April 07, 2011, 05:06:04 am »
Haha, good !
Now before you get drunk all the way, please keep in mind that it is not intended to work like this. So, or your disk(s) take ages to wake up, or the data transfer from it is way slow (meaning that in combination with the necessary normal wake-up time it is all together too slow).
If it is okay for you like this (disk keeps on spinning), then never mind of course !
crisnee
« Reply #21 on: April 10, 2011, 02:47:53 am »
Hey Peter,
I'll experiment with different spin down times to see if that really is the culprit, or it's some combination of stuff, but not any time soon.
By the way (it really is not "by the way,") that file that I sent you that played perfectly on your system but not on mine. Well it still doesn't play on mine--still get the same error. And I tried to play the very one that I sent you--sort of. In other words the file (A) I sent you I manually copied to a flash drive, then moved to laptop (which is online) and then sent a copy to you. Well I took (A) and put it back on the XX computer in a different folder and still I get the same error. What could be going on??
I ask this just because I'm curious, not because I'm particularly concerned about the absolute chaos  Tomatoes ! it is creating
on my music pc.  drinks  drinks.
I'm having a few tonight.
Chris
« Reply #22 on: April 10, 2011, 08:04:20 am »
Strange ...
But now I'm thinking of it, I may have changed a few things which indirectly maybe are related. Wait for 0.9z-5 and then try this again and let me know, ok ?
crisnee
« Reply #23 on: April 11, 2011, 06:21:36 am »
OK,
And now back to the hesitation issue. Just for a lark I decided to set the spin down time to 2 minutes. No problems. Played a couple of albums, watched the HD light, no hesitation blues. So it doesn't seem to be a spin up issue. Maybe when it hesitates it just catches the HD when it's in the process of spinning down. One usually doesn't want to spin up a disk until its come to a complete halt, maybe the disks or the OS provides for that? That would also explain the different length hesitations. And a 10 minute time is just perfect for my scenario.
So I started thinking pleasantry . Why do I want the drive to spin down and spin up after every track (unless I'm playing 60 minute + tracks exclusively)? I keep thinking. Peter wouldn't want that either he knows that's more wear and tear and bruhaha  heat on the HD. So what's the deal? Maybe he assumes my OS and music are on separate disks. Nay sir. Or maybe he assumes all my files are in wav format. Again nay sir. Why?
Because my OS and most music files (flac & mp3) all reside on the same 1Gb disk.  bye
Chris
« Reply #24 on: April 11, 2011, 11:17:10 am »
Then your problem is clear now ... you just run out of music !
byebyebye
crisnee
« Reply #25 on: April 12, 2011, 04:05:22 am »
byebyebye
You mean you don't run out of music? How many albums did Black Sabbath produce?  teasing
Chris
Page created in 0.265 seconds with 19 queries.
