April 09, 2025, 01:22:27 am *
Pages: [1] 2 3  All
Author Topic: Problem with Unattended 0.9z4-1  (Read 31984 times)
SlickenSmooth
« on: February 22, 2011, 07:06:21 pm »
When I go for unattended playback I get the message that it's stopping my services and that "when done this message dissapears". Problem is it does not dissapear and Alt-x won't bring my xxhighend back so I have to hit the power switch to reboot.
My Autohotkeys DO work when I use them at attended.
What am I doing wrong?
Thanks
Laptop (8gb RAM) with Windows 7 Ultimate 64bit on HDD, XX0.9z-6 on HDD, music on HDD, i5-460 -->
Engine#4 Adaptivel Mode / Q1 = 1 * 2/3/4/5 = 0/0/0/0 (Dev.Buffer = 512)/*ClockRes = 15ms*/*Straight Contiguous*/*SFS = 430*/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ UnAttended (Do Not Start) /Services Off + No Running Time --> Jkeny Modded Hiface 2.0 -> Devialet D-Premier -> (soon) Kaiser Kawero
« Reply #1 on: February 22, 2011, 07:15:35 pm »
Hi there !
Maybe it's time to fill out your signature ... because, sorry, I really forgot what system you have. I recall a laptop though ?
Question is : how long are you waiting ?
But to answer all questions, just go to TaskManager, Services and sort them on Running/Stopped (running on top). There you can see if Services are still disappearing, or whether nothing happens anymore.
Don't forget to also watch your Processes. So, once all Services have gone the Processes are in turn.
I hope this will get you (ok, us) somewhere ...
SlickenSmooth
« Reply #2 on: February 22, 2011, 08:19:38 pm »
Just put up my signature!
When I try to get to my taskmanager when the unattended process is going, it gives me an error message. My OS is not responding and it says I need to press ESC or reboot. I''ve waited lik 7-8 minutes and it starts shutting down my virusscanner, Wifi, then the desktop gets empty and I wait and wait and wait but nothing happens.
« Reply #3 on: February 22, 2011, 08:42:58 pm »
What about starting TaskManager in advance ? that should work. Or at least that is not killed ...
Please try to find what's happening, just so I can solve it.
And, as the ToolTips show, once we know what's causing this (which just may be one thing killed too much for your laptop), you can include it to not stop. Btw, this includes your virus scanner, when you think this is necessary (but with your LAN shut off ... why).
Also notice that you can easily copy-paste *everything* in the exclude lists - from the XX log file. And (ToolTips), anything is easily to exclude for trials by just putting an asterisk behind it Like (MyVirusScanner*) <- this now again *will* stop, but when causing anomalies it's back in no-time by removing the * again.
I am not saying this is all intended, but the only way to get our fingers behind what's happening. At least I tried all to make this as convenient as possible (like the copy-paste thing).
« Reply #4 on: February 22, 2011, 09:12:22 pm »
While the message "please wait" is showing, and after having waited a good minute or two, hit the "Okay" tab on the message and it will disappear. Then hit alt x and XX should reappear. Hit play again and this time the "please wait" message will disappear on its own. That's the way it worked for me when I first tried it last night.
 Then, if you ticked the "do not start" button in the setup, don't forget to hit "alt p" to get the music to start. Last night, several times, I was staring at the screen waiting for music before remembering to hit "alt P".
« Reply #5 on: February 22, 2011, 09:31:48 pm »
If all is right, this works a little differently :
At OK, the message just disappears. Don't ask me why I made it like that ...
At Cancel the whole process will be aborted and XXHighEnd comes back.
When the message has gone, XXHighEnd has gone, ready for Alt-P.
When the Message is still there, Alt-X won't work (because XXHighEnd is actually still there), BUT, it will come back when the message disappeared if only this is within some time (IIRC 20 seconds). In such a case anomalies may occur when you did *not* set "Do not start playback at all). Not sure. It could be treated as just a normal Alt-X when music is playing.
So, clicking OK followed by Alt-X - XXHighEnd coming up again, is or coincidence because it just was finished, or it happened after these 20 seconds ...
wacko
SlickenSmooth
« Reply #6 on: February 22, 2011, 09:54:04 pm »
Okay, I just saw in taskmanager that 24 processes and 24 services cannot be stopped somehow. Does this mean I can only use attended playback ony my laptop?  unhappy
« Reply #7 on: February 22, 2011, 11:11:58 pm »
No, not at all.
For sure Services and Processes will remain, so this is not the - or a problem. The problem will be that something will be "crahsing" inside and next blows up your laptop. That is, *if* that happens in the first place. So, with TaskManager just being there - you looking at it. Does all stop to respond or move (like in the Performance Tab) ?
Or will the lot be hanging on the shutdown of any of the Services/ Processes ?
Btw, why don't you post your XX log file ?
Activate Logging (bottom of Settings), try it again, and at a next boot (assuming that is necessary) just grab the newest log file (in the TemporaryData subfolder to your XX folder). I may see something there ...
PS:
Which is ?
SlickenSmooth
« Reply #8 on: February 23, 2011, 12:28:32 am »
No, taskmanager is not freezing. It keeps on working, including the other tabs.
When I try crtl-alt-del it says: De opties voor beveiliging en afsluiten zijn niet weergegeven. De opties voor beveiliging en aanmelden zijn niet weergegeven nadat op Ctrl-Alt-DEL is gedrukt. Duk op ESC o start de computer opnieuw op met behulp va de aan-/uitknop als het besturingssysteem niet reageert.
I will post the logfile next which is on my other laptop.
SlickenSmooth
« Reply #9 on: February 23, 2011, 12:32:43 am »
Here's the logfile
* XX-20110222-224622.log (115.6 KB - downloaded 540 times.)
« Reply #10 on: February 23, 2011, 12:35:40 am »
Ah. I think that would be normal. Ctrl-Alt-Del is still from the old ages, and anticipates on you wanting to shut down the system (reboot actually). Never mind options "just are" to start TaskMannager.
Use Ctrl-shift-Esc instead ...
(which I didn't try in this stage, but I think it will work, and just will start TaskManager).
Ok, awaitening the log file.
But you have this on two laptops, right ?
« Reply #11 on: February 23, 2011, 12:41:09 am »
Here's the logfile
Thanks.
Well, it seems clear that the mcshield Service won't allow to let kill itself. This is mcAfee stuff. So, put it in the exclude list (the left one) like :
(mcshield)
and try again.
Or shut it off in the first place. That is, I don't know of any virus scanner which doesn't hold up your system everywhere, and mcAfee is no exception. But that is up to you.
Let me know what happens,
SlickenSmooth
« Reply #12 on: February 23, 2011, 12:43:05 am »
I just posted the logfile see  naughty
Ok, I guess my computer knowledge is from the stone ages hahaha.
« Reply #13 on: February 23, 2011, 12:48:18 am »
Put (mfevtp) there too. Also part of mcAfee. If it works, remove this one again. Ok ? done. Doesn't work again, put it back.
SlickenSmooth
« Reply #14 on: February 23, 2011, 01:08:20 am »
Nope, still doesn't work when I fill in the brackets.
See logfile.
* XX-20110223-005151.log (58.99 KB - downloaded 539 times.)
Pages: [1] 2 3  All
