April 06, 2025, 01:39:37 am *
Pages: 1 [2] 3  All
Author Topic: Will SQ between HDD VS SSD VS RAM be measurable for digital audio?  (Read 40750 times)
Windows X
« Reply #15 on: February 11, 2011, 11:35:58 am »
That's weird to me too. Maybe it's ASIO under MME name lol.
« Reply #16 on: February 11, 2011, 11:37:22 am »
Hey, nice. Didn't know that. Thanks.
(DLing the first one now Happy)
« Reply #17 on: February 11, 2011, 11:40:36 am »
Btw, you may not think of it, but I like to have the original file also. Not only for when things differ, but merely because I will be able to eliminate *that one* for having some offset (while your recordings always will have).
Windows X
« Reply #18 on: February 11, 2011, 12:28:36 pm »
Sent. It seems someone's trying to measure this by using floating point rounding error in http://twitpic.com/3ylv70/full. What do you think?
« Reply #19 on: February 11, 2011, 01:17:46 pm »
Was this last one the original ? (it has the same name as the first one).
Will this be all, or do you have more ? (this seems the "hdd" test)
Looking at the link now ...
Windows X
« Reply #20 on: February 11, 2011, 01:26:33 pm »
nah. I included original file in so it'll be bigger. Anyway, about posted pic, it's between HDD and RAM. I don't understand why he did floating point rounding error comparison. It's fixed 16 bit wav which sounds irrelevant to me.
« Reply #21 on: February 11, 2011, 01:41:11 pm »
I've been staring at it, but I can't think of a clue.
Sorry, I confused you with this; I didn't unpack things, and now I did I see what's all in there.
But now I don't understand ...
You sent me two RARs. Should I only use the second ? (you just sent that again, but now including the original ?)
Windows X
« Reply #22 on: February 11, 2011, 02:15:39 pm »
Use the second. It has original file and you can read radme.txt inside for more information.
From excel chart, all I could think was dithering floating point bit to fixed bit ones. Dithering sounds kinda strange for measurements no matter how hard I think about it. It ruined my effort for using high quality audio interfaces and direct recording at very low latency.
« Reply #23 on: February 11, 2011, 02:27:06 pm »
Sorry, I didn't see the readme. Still not. Happy
Ok, I compared the original to the hdd one. They are NOT equal.
All I can say at this moment is that it looks like dither to me (totally unrelated to your dither from your last post btw).
The off-values are the minimum (decimal 1).
So, or this wasn't bit perfect playback, or this wasn't dithered recording. So please think about the latter (check for Audacity settings) IF :
... If you are 100% sure that MME for W7 is bit perfect in the fisrt place. So, back to that subject, although I didn't know MME could exist for W7 (Vista), I'd sure say that it won't be bit perfect. That is, when something like DS is used for playback. Vista/W7 just can't, no matter MME does it ... for XP. Just my opinion because I don't know anthing better.
About that dither : it is also good to know maybe, that no soul on the globe ever came up with the "dither" XP applies, when all should be as bit perfect as could be, but still is not. But, I did, and I am fairly sure I am right. Btw, notice that right in the middle of Amir what's his name, I *suggested* it to be dither, and he never denied it, or just doesn't know (he was from Vista Audio dev., maybe not XP).
Well, it is this what I'm seeing here.
Can you tell me, what is the problem (or "your" problem) with using XX for playback here ? I mean, I don't think you do ...
Quite some suggestions, and I could be wrong on a few of them.
If you are fed up with it at this moment, just tired, slammed by disappointment, just hop off for now. We can proceed with it later. But let me know. I am not long here myself as well for today (one more hour maybe).
Windows X
« Reply #24 on: February 11, 2011, 02:32:05 pm »
As my machine is optimized for J River now so I'm using it with WASAPI Event Style (Exclusive). It should be bit-perfect so my guess is recording program that didn't record it right. I'll try your Gold Wave next week so please give me screenshots of your recommended settings to test.
« Reply #25 on: February 11, 2011, 02:43:53 pm »
Nice one ... but I'd have to set it up myself for that. What I recall of it, all is ok by default. Only when you want to record in higher than 16/44.1 things have to be done.
But why wouldn't Audacity be able to do it ? I have it but hardly ever use it. Just look for some dither setting. If you found it, and it's not on, then start wondering what may be happening.
Lastly, I think I can tell you that JR is not "bit perfect" by default (or "always"), but, not sure. Foobar is. XX is too.
IOW, don't think WASAPI is "bit perfect". It is hardly related. It's the Exclusive Mode doing that, and you won't be able to tell so easily. So, I sorted it out, and only from Foobar I dare to tell that it is so in ALL cases, or otherwise it won't play.
Notice that already the fact that your are recording at the same time, can imply that Exclusive Mode can not be used. You could check forever, and get crazy. Foobar will just give you the message it can't play. As will XX.
Don't get mad.
« Reply #26 on: February 11, 2011, 02:45:58 pm »
WASAPI Event Style
Totally unrelated. But, for JR guys it may say something. Similar to me calling something "straight contiguous" while you will know what I mean with that. JR guys won't.
But "event style" normally is just some opposite of a timer and "polling".
Flecko
« Reply #27 on: February 11, 2011, 09:29:43 pm »
Do you know how this was created? The measured error seems more ore less the same. 0.000031, and 0.00003 (with different signs and addition of them). So, it is systematic but looks very strange. Why should the data being rounded? Just if the bandwidth is limited or not? and also that rounding is strange. 0.000024->0.000028?
« Reply #28 on: February 12, 2011, 12:12:51 am »
Hi Adrian,
This was my first thinking too. But there is no error there. Look at the right side of that spread sheet, notice the offset mentioned, and then look at the error. There is none ...
ipats
« Reply #29 on: February 12, 2011, 05:11:49 am »
Hi, i'm who make the spreadsheet. let me explain.
First,
It's binary rounding, not decimal. I guess that the audio softwares work in floating-point, and may also the sound hardware. So, when it convert sample to PCM integer, it need rounding and also dithering. I didn't round any sample, I used the original sample value from files I got. So, I have no clue which process the rounding take place. All I did is find the offset and compare those files.
I also make another comparison, in hex editor. You can see it here: http://twitpic.com/3ymmoy/full (see the highlight in each window)
They're bitstream from files I got, I didn't alter any of them. As you can see, there're offsets, so the files are difference when compare with foobar2000 or something like that. But when the samples were shifted to be the same offset, they're almost the same.
You can see that the difference between sample values in files occur only +/-1 or +/-2. So, I think it's must be a rounding & dithering. As I mention above, I have no clue which process did this because I didn't the one recorded these files. Maybe the player, recorder, hardware, driver or anything else...
PS: You can check my comparison with the files you have, I didn't edit them.
Pages: 1 [2] 3  All
