November 23, 2024, 05:36:37 pm *
Author Topic: Problem with 09-Z4-0 engine 3 crashes  (Read 8222 times)
HAL9000
« on: February 01, 2011, 10:39:07 pm »
Hello Peter. This is my first post here.  I find XX the best "CD"-player around.  It makes very open focused dynamic sound coming out of my QUAD 989's very happy
I recently upgraded to 09-Z4-0 and can not get it to play.  Z2 and Z3 works still fine.  Z4 will not start engine3  unhappy
Could it be my PC specs that are too low ( only 2GB Ram )?
I tried nearly all settings possible and reinstalled several times...
Likes Z2 very much but curious to hear if z4 has improved. smile
I have tried both activated and unactivated...no luck yet
It will play with KS engine 4 but only to Juli@ wave out...not SPDIF  scratching
do you have any ideas to try?
Thanks and All the Best
HAL9000
*Windows 7 Home Premium 64bit SP1, CORE i7 2600k / Engine#4 Special Mode / Q1/2/3/4/5 = 14(4096)/1/1/1 (Dev.Buffer = 4096)/*ClockRes = 15ms*/*adaptive*/*SFS = 0.40*/ not Invert Phase / Arc predict / Peak Extend / Playerprio = Low / ThreadPrio = Real Time / Scheme 3-5 / 2x Upsampling / MOTU 2408mkIII SPDIF to Metrum Octave DAC -> Abrahamsen main amps -> DALI MEGALINE
« Reply #1 on: February 02, 2011, 02:37:54 am »
Well, a first post sometimes incurs for a Welcome !
But what can you do with that ?
Ok, at this moment I can tell you that I have exactly one user telling (offline) a sort of the same. Of course I told him "user error", but only because it seemed a single occasion, and without a year of experience nothing may work with 0.9z-4-0.
But when long time hidden users start to complain, I must put my attention to the other user and offer some apologies I guess.
More importantly, maybe I can make up something out of the two of you (similarities).
What do you mean by this exactly ? Error messages ?
Obviously you tried "Mixed" for memory. But to be sure, did you ?
Meaning ? ... different compared to earlier versions ?
Let me know.
« Reply #2 on: February 02, 2011, 09:51:42 am »
Hi Hal9000,
Just a week ago i helped a friend with his new Juli@ soundcard. The problem looks a bit a like and if you read these topics maybe that wil help.
http://www.phasure.com/index.php?topic=1332.msg12140#msg12140
http://www.phasure.com/index.php?topic=1063.0
Succes
HAL9000
« Reply #3 on: February 02, 2011, 09:04:21 pm »
Hi Again Peter.
thanks for taking time to respond.
I installed the older 0.978 Juli@ driver which gave me channel 3-4 for KS so now I have sound.  Thx Gerard for advise on that. very happy
Still with engine 3 it will not work. It shows an error message that engine 3 did not start.  Here the text from that window (sorry for the Danish Happy  and yes I have tried Mixed and Mixed Contig no difference...But at least I now have sound to play with.
Note though that Engine3 works fine with versions 09-z2 and 09-z3 ...
Problemsignatur:
  Navn på problemhændelse:   APPCRASH
  Programnavn:   XXEngine3.exe
  Programversion:   0.0.0.0
  Tidsstempel for program:   4d35c88f
  Fejlmodulnavn:   StackHash_0a9e
« Reply #4 on: February 05, 2011, 04:48:42 pm »
Ok, thank you for the help. It was an error - actually because I never tested Engine#3 for 0.9z-4-0 (well, as it appeared). Everybody will have had it, but not many people use Engine#3 anymore.
It will be solved for 0.9z-4-1.
Page created in 0.167 seconds with 19 queries.
