hal3101
« on: August 06, 2007, 06:54:28 pm » |
Not able to control the xxhighend player from a pda - terminal service client. Program stops and gives error message. Device not support/allow exclusive use.
TorH
Home build pc, Intel Dual core 4300 1.8 GHz , Vista Business, 2 GB RAM, one 500 GB harddisk, Q1 -3 with checked invert, appoint processor cores checked, Engine 3 checked, Double and upsamp NOT checked -> USB DDDAC -> TVC -> 300B -> Oris 200
« Reply #1 on: August 06, 2007, 08:44:51 pm » |
I don't know about "client" PDA's, but did you apply the setting "Leave audio at the remote PC" ?
If this setting is not available at the PDA (for RDP settings), that's your problem I guess ...
hal3101
« Reply #2 on: August 07, 2007, 10:54:48 pm » |
Can not do that on the pdb but I think that the real problem is that the remote playback is started and the speakers (2-USB Audio Dac) is replaced by the Microsoft RDT Audio Transport. I can get Foobar to play via the pda and a terminal service but that only applies when I am using kernel streaming in foobar and not usb audio dac.
« Reply #3 on: August 07, 2007, 11:50:06 pm » |
So you don't have this (topmost) setting in there ...  Is that CE 5.0 ? If 4.2, you could try to get 5.0 or find out whether that helps ... (or Google for registry hacks in the PDA -> not the most simple thing to do, but it can be done)
hal3101
« Reply #4 on: August 08, 2007, 06:58:01 pm » |
Nope. The pda has pocket pc 2003. No option for the remote playback. In fact there is no selection at all just the ip-adress. TorH
« Reply #5 on: August 08, 2007, 08:27:54 pm » |
I can get Foobar to play via the pda and a terminal service but that only applies when I am using kernel streaming in foobar and not usb audio dac. Actually this is strange ... But now I think of it ... maybe you're running XP on the remote ? I mean, Vista/Engine#3 would only be more direct than anything else. It goes through about every OS thing. This is not the case with XP (and Engine #1/#2). PS: You are running XXHighEnd on the remote, do you ? ... you could run it on the PDA, but then it would never work ... ?
hal3101
« Reply #6 on: August 08, 2007, 08:31:25 pm » |
Gave up on the terminal service and added WinVNC instead. No problems to control the player but the response is slower than the terminal service. Maby a tip for others who wants to remote control the xxhighend player from a pda or maby a cell phone. TorH
hal3101
« Reply #7 on: August 08, 2007, 08:43:31 pm » |
Vista baby.
Once the remote desktop is started the usb-dac is magically transformed into a remote playback on the xxhighend computer. I have not been able to find a way to disable this feature. This remote audio playback is new in Vista (I think) and not part of xp system. TorH
« Reply #8 on: August 08, 2007, 09:18:35 pm » |
This remote audio playback is new in Vista (I think) and not part of xp system. Must be so, because that's when it occurred to me the first time (as a choice). What about the latest RDP client for the PDA ? I really don't know how to help you here
