November 23, 2024, 04:37:29 am *
Author Topic: How to disable Hyperthreading?  (Read 9381 times)
« on: January 20, 2011, 09:53:54 am »
Hi Guys,
Can anyone guide me on how to disable Hyperthreading.
« Reply #1 on: January 20, 2011, 10:00:35 am »
Hey Arvind,
In the BIOS there should be something called "HT". Or "HT Technology". Or otherwise just Hyperthreading.
It may be near to the place where you can set the number of cores active. Like "1", "2", or "All".
When you succeeded you will see 4 cores in TaskManager (now 8 ).
Hope this helps !
Page created in 0.104 seconds with 19 queries.
