April 05, 2025, 02:18:14 pm *
Pages: 1 2 3 [4] 5 6 7  All
Author Topic: 0.9z-4-0  (Read 108918 times)
Suteetat
« Reply #45 on: January 24, 2011, 02:28:19 pm »
I tried special mode vs adaptive mode in z4 today. SC, SFS100,  power scheme 1, minimum clock. In special mode, with Weiss INT202, I could only go down on
Q1 to 4 with 256 samples. Anything below gave me a lot of distortion. I also I could not go down lower than 256 on buffer on both Weiss/XXHighend in special mode (in Z3, I also happen to find buffer 256 to be optimal for my setup). Adaptive mode, Q1 right now is at -1.
Anyhow, I find special mode has a bit more sparkle but also string sounds slightly more metalic and brittle. Adaptive mode sounds more creamy in comparison. Bass is a bit stronger with special mode. Adaptive also give me a lot more detail. In the Eagle's Hell Freezes Over, Hotel California track, I never noticed so much audience noises. The audiences' whistle and clapping extended well behind the speakers and almost wall to wall, adaptive more so than special mode but in my room, this is the first time I hear something like this.
I have not listened to this album in a long time so quite a few things are changed since then so I don't know how much is from Z04 and how much is from the rest of the system.
« Reply #46 on: January 24, 2011, 05:12:55 pm »
you just hear each instrument and every instrument is made of metal Wink.
There is a lot i like with the new Z4 SC version. Went back to Z3 and i miss the clarity. But i have the same going on like Flecko says. Its just a bit to much  and do not now yet how to get rid of it.
Really curious what Bert comes up with with his SSD/HDD test.
easternlethal
« Reply #47 on: January 24, 2011, 06:08:12 pm »
I feel that 09z 4.0 has a much more 'forward' character to it, in that solo instruments really jump out. As a result of this I am also playing music at about 10% lower volume than before. I would not describe the sound as particularly full-bodied even in adaptive mode (and don't believe that any of the previous versions ever were) and despite the fact that it's the most transparent sound with the blackest background and widest dynamic range we have managed to get out of our system to date. The only criticism I have is that it has a tendency to sound too crystal-like or clinical. I think I won't be the only one who thinks that manishandler's assessment of the NOS DAC1 could apply to the software. If there was a way that 'warmth' could be brought to the sound, it would be perfect.
That said it's still the best player.
By the way I switched from SSD to HDD and I have to say I found it difficult to cope with how long it took things to boot up etc. I haven't been able to compare the 2 however, as the SSD is 32 bit and the HDD is 64.
[PC: Win7Ultimate 64 bit - SP1 Spinning Disk (no SSD)/Intel dual core/XXver.09Z-4-00 Settings: Adaptive/1024/Q1:1024/Arc Prediction + Peak Extension/Quad/SFS=2/Mixed/Unattended/12ms/Scheme 3] [Audio Chain: Weiss Dac 2 (via firewire) - Holfi 1.5.1 & NB1 - JBL 4428]
« Reply #48 on: January 24, 2011, 06:38:53 pm »
I know it might sound crazy, but I had a significant increase of warmth and width (fatter?) playing Z4 in Special Mode, when I unticked "Stop Services". Almost took me back to Z2.
« Reply #49 on: January 24, 2011, 07:32:51 pm »
For your notice, or later reference perhaps, the screen I/O has a very different "priority" from other OS versions. For example, VU meters won't work as usual at all. It's just not updated fast enough.
This is in the "Stop Services" realm. It will still matter, but less than before W7-SP1.
One thing I did which goes along with it : kill the deskop as a whole (with Stop Services = Yes).
« Reply #50 on: January 25, 2011, 10:49:13 am »
That will take a few weeks as my present system to review the difference (I'll need some basic reference first) is not completed yet...
« Reply #51 on: January 25, 2011, 11:44:09 am »
Continuing my findings on XP, I have found upping the Q1 setting (adaptive) improves SQ without sacrificing the well appreciated timing. With this knowledge I went back to RAMDISC and enjoy a very good sound with perfect timing at the moment. Though some technical aspects could be better, I find it very engaging with excellent clarity (purity?) and dynamics. You can almost drown in female voices Happy!
Like Peter said the position of the cursor does make quite a difference. Never noticed this before, since it is allways on the XX window. When the cursor is on the outside, the sound looses focus (much more fluffy) and a lot of the special magic is lost. Very important to keep in mind where you leave it when optimising XX!
Though the relevancy may be low on this forum, my settings for v4 are at this stage:
-VSuiteRamdisc, adaptive, 512 buffer, attended, Timeres = 4msec, mixed, garbage collect, services off, SFS=20,Q1=6, cursor on XX (!), music and OS on SCSI HDD
(note, not a complaint: special mode does not work, mixed contiguous does not work, unattended sounds flat as a pancake, have to make a bigger RAMdisc for temporarily storing music)
regards, Coen
Flecko
« Reply #52 on: January 25, 2011, 04:28:47 pm »
Today I receifed my Digital Interface from Audio-GD,  that has now replaced my stock Hiface. I will tell more about it in another thread but want to post z4 related news. First interesting thing was, that I found, as I played with the settings of z3, that now with the DI, the the sound changes different if I change sfs. I would now say, it changes in the opposite direction. Means, smaler sfs -> better sound (How crazy is this?). Then, of course, the next thought was to try z4 again and...Yes it works! Now the balance is there, the DI seems to keep the same tonality no matter what settings I use, it is more the quality that changes. With SC sfs=1,0 z4 sounds very beautyfull. It is MUCH cleaner than z3. All the "metal" has gone. Crazy, but I like it to be like this Happy At the moment my impresseion is, z4 is MUCH better than z3.  love this
« Reply #53 on: January 25, 2011, 07:51:15 pm »
All the "metal" has gone, z4 is MUCH better than z3.  love this
Flecko,
Well what can i say!  Good job !
You are totally right!
Thanx!!  Happy
BrianG
« Reply #54 on: January 26, 2011, 11:51:34 am »
What type of mouse does this apply to?  USB and/or the dedicated mouse/keyboard port?  I have the USB mouse/keyboard and don't find any difference at the moment.
Brian
« Reply #55 on: January 26, 2011, 12:20:26 pm »
Ah, careful. I think an USB mouse may incur for other activities than I thought of. But I'm not sure.
So this also works the other way around : it may be just those other activities you can perceive (not Brian, he has a sterilised mouse).
« Reply #56 on: January 27, 2011, 01:15:56 pm »
 rofl
Flecko
« Reply #57 on: January 27, 2011, 08:03:56 pm »
I am using z4 without ramdisk and I think it is better like this. Ramdisk does a smothing that limits the dynamics. I think it is better without. The sound is so great, it is unbelievable. Even old records like judas priest has such a depths and punch... wow....chicken skin  (if you can say that in english like that) Happy
« Reply #58 on: January 27, 2011, 08:21:45 pm »
You shouldn't have said that !
Now *I* want to get that going ... Happy
But I think I have mentioned it before, especially the normally rough sounds like a distortion guitar can contain so much air when good.
When you come back on it, let me know ! swoon
Flecko
« Reply #59 on: January 27, 2011, 08:36:56 pm »
Happy It sounds also great with ramdisk. But I found that without the sound has more precission and bite. I will check ramdisk later again!
