April 05, 2025, 02:30:43 pm *
Pages: 1 [2] 3 4 5 6 7  All
Author Topic: 0.9z-4-0  (Read 108919 times)
« Reply #15 on: January 20, 2011, 05:45:02 am »
I found mixed contiguous better than mixed, but was unable to get contiguous to work. When I played mixed contiguous the first time the "privileges" message appeared and I had to reboot. I probably need to reduce the size of my ramdisc to get contiguous working, maybe tomorrow.
It sounds really, really good....a step closer, maybe, to a "fat Z2/transparent Z3" sound. Need to give it some time to be sure. Other settings: ramdisc, SFS 40, clock resolution "nothing", and Q1@-1, everything else as in my signature.
Leo
« Reply #16 on: January 20, 2011, 09:01:07 am »
Finding the 'right setting' is quite important, as Peter said. I changed the settings  from 'default'to Peters signature setting, SFS (from 60 to 40) and memory setting (mixed to straight) and by mistake changed the player mode from special to normal. And then I was wondering for some time where the magic had gone and the harshness was coming from.
Now the magic is there again for me. pfff
Just 3150 hours to try all possibilties in a systematic way. I will report back in autumn !
« Reply #17 on: January 20, 2011, 09:18:25 am »
Haha. And then to think that when I was a young kid (think 5 or so) my father thought me that in a good hi-fi system no bass and treble knobs should be there. I wonder what would have happened to the man would he still live today. innocent
« Reply #18 on: January 20, 2011, 10:17:43 am »
But, peter can you manage a button that prevents the explorer to be shut off in the final version? I normaly use my computer while listening to xx Wink
Wouldn't that be just making "Stop Services" inactive ? I think so ...
Not if you use Unattended and *then* still use the PC of course !
Let me know if the latter is your case.
PS: Let's not mix up this topic with stuff other than SQ this time, please.
« Reply #19 on: January 20, 2011, 10:32:23 am »
Sorry to say but I use Win 7 SP1 for some time, forgot to change the profile...
(And in unattended the Windows-key don't work anymore, was so convenient before...)
No ramdisk, rest like before, will try more tonight.
« Reply #20 on: January 20, 2011, 10:42:23 am »
Ah Gerard, ok ! very good to know.
Well, then I won't attempt to try to talk into things, and just observe instead.
But the (not) RAMDisk might be key here.
Thanks again.
Suteetat
« Reply #21 on: January 20, 2011, 11:20:42 am »
Hmmm... I just installed Z04. Right now I still have not experimented much with setting but clock resolution is at minimum for system (whatever that is) straight contigous thing, SFS60, power scheme 1, buffer 256, I am not sure if I hear any significant difference from 03, perhaps a bit more clarity. It sounds bigger,
more fluid. At least all the change seems to be positive Happy
This 04 version comes at the most inopportune time as I just switched out my old Synergistic Research Accelerator with Stealth Sakra IC and installed my new Stealth Sextet digital cable ( was using my dealer's well broken in Sextet before) yesterday but I could not resist. Anyhow, z03 is still in my RAMdisk as well so I will be making some comparisons soon but want to burn in my cable for a few days and experiment with various settings first before going back to 03 for comparison.
Flecko
« Reply #22 on: January 20, 2011, 01:52:48 pm »
ok, next time there will be a new topic. Deactivate stop services prevent xx from shutting down the explorere. But maybe there could be a button, like z3, when you activate stop sevices it just stops services, that are not needed for using the pc in a normal way. And a second button that makes the explorer inactive like unattended. With the actual setting, attended is like unattended if stop services is activated. In both the pc is audio only.
Suteetat
« Reply #23 on: January 20, 2011, 03:02:03 pm »
Something strange. I am still in adaptive mode for now. I find that I prefer straight contiguous mode over mixed contiguous as music seems to flow better, more lively and better clarity. However, suddenly I kept getting error message about memory allocation error 03, lower SFS, reboot or change mode. Currently, I am down to SFS 10 with straight contiguous mode. However, when I lower SFS, music also becomes leaner, seems to emphasize treble more. I like the slightly darker, richer sound in mixed contiguous mode with SFS 100 but like the pacing and music flow/detail of straight contiguous. I wonder what I would have to do to run bigger SFS in straight contiguous mode?
Suteetat
« Reply #24 on: January 20, 2011, 03:55:15 pm »
Slight update, after rebooting the computer, now striaght contiguous seems to work ok with 100 SFS which seems to be best sound
I can achieve right now and it is, I think, a significant improvement over 03 version, much more dynamic and much bigger soundstage both
width and depth. JUst hope 100 SFS will be stable with straight contiguous memory management.
« Reply #25 on: January 20, 2011, 04:35:43 pm »
I receive that error only when i like to play with Ramisk.
« Reply #26 on: January 20, 2011, 04:37:45 pm »
Oh, I thought I had told sufficiently enough about this ? (Release Notes and ToolTip).
Start playback again as soon as possible, etc. ... yes
Or, in Unattended Mode, pick your next album during the beginning of the last track playing, and just press Play. Not 100% reliable (may start at the second track), but it *is* a means for now.
Btw, an SFS of 100 is asking for problems with Straight Contiguous. But it can work, as you have seen.
« Reply #27 on: January 20, 2011, 04:39:02 pm »
Because that ate your memory (and not enough contiguous space is left for the amount you're asking for).
« Reply #28 on: January 20, 2011, 04:53:36 pm »
Well you did but please it is so much information and all new that my head is a bit  wacko at the moment...
This all needs a bit time....
Playing your setting there is something real real different and good at the same time. Yesterday though after a while it started to irritate me a bit. But than it could be my mood from yesterday wich was not all the best.
But there a lot of air wich is totally new.. Like it!!
« Reply #29 on: January 20, 2011, 05:01:12 pm »
More beer Gerard, more beer.
But more seriously, take your time for it, and possibly report per setting you tried. I already told I couldn't do it alone and I guess it is true. But us all together ? hopefully Yes.
