November 23, 2024, 05:50:50 am *
Author Topic: now what happened  (Read 11644 times)
pistollero
« on: January 17, 2011, 01:28:21 pm »
hello everyone again.. iīm under windows 7 64 on a asus n61 laptop...
iīm testing the demo but strange things happened... besides i canīt play large files above 30 minutes..
than a canīt drag and drop the files do the interface... and now the program doesnīt start at all...
iīve already dowloaded again... but the program dont start.. i see the icon but i donīt see the interface...
can anyone helpme...??? tks a lot. unhappy
Windows 7 home premium 64bit SP1 / asus n61v laptop / Engine#3 / Dev.Buffer = 1024 /*ClockRes = no*/Straight Contiguous/*SFS = 240*/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 /-> audiophilleo2 -> dacmagic DAC -> active adam audio A8X monitors
« Reply #1 on: January 17, 2011, 02:10:41 pm »
Try going into: control panel/system/advanced system settings, then click on settings in the "Performance" box and then select "adjust for best performance". What you describe here has happened to me after I've had XX playing and I try to access the gui after playing in "unattended" mode. After adjusting for "best performance" the gui always "shows up". Hope this helps.
ps: you really should spend the few bucks for the XXplayer, most issues will go away and you won't ever again get a better upgrade in your sound quality for such a small amount of $.
pistollero
« Reply #2 on: January 17, 2011, 02:19:00 pm »
i like the sound boleary...a lot but...
do you play files longer than 30 minutes??
« Reply #3 on: January 17, 2011, 02:34:37 pm »
Can't say that I can recall playing anything quite that long. I'm fairly sure Peter will be able to address this issue for you. Here's a 26 minute, 36 second file that works fine here:
« Reply #4 on: January 17, 2011, 03:22:48 pm »
Oh, but in general files can be infintely long, and for WAV/FLAC this sure works (looking at the .wav example from boleary). Try Amarok. That's one 60 minute track and this 100% sure works.
So, we can only talk about MP3 here. What about maling be such a file ? (sales at the rest).
« Reply #5 on: January 17, 2011, 03:26:57 pm »
I'm afraid you must spend a little effort to make clear better what your problem is here. Is this one problem, two or three ? If more than one, please decribe it separately in a post. Never mind the language, although I know this is sort of a problem too (I heard that quite some times, haha Happy).
pistollero
« Reply #6 on: January 17, 2011, 04:36:32 pm »
Hi peter and all,
good news.. now iīm feeling better because i tried another version: 0.9z-2 and it works ok, iīve played longer files (200 minutes).
and the sound seems perfect from my adam audio monitors. but i have one question:
i only can start the program in normal mode, when i run it as an administrator does nīt work.
is bad donīt run as admin?????
tks for you patience... by the way i was attempted do buy j river 15 and... i found XXHE and the sound is better...
Flecko
« Reply #7 on: January 17, 2011, 04:54:33 pm »
Try disable UAC
« Reply #8 on: January 17, 2011, 04:55:24 pm »
Thank you, nice to hear !
Also great that you found 0.9z-2 to be working for the longer files. This makes it much easier to find the problem !
A bit depending on what you further did to let this work (also see Vista Users ... prepare yourselves ...   and cannot run as administrator anymore, today it is best when you shut off UAC (User Account Control). For W7 : slide the slider down as much as possible.
Leaving it to "run as administrator" can also still work (see second lnk above), but it is hard to tell myself what it takes, because first some (defender ?) upgrade "destroyed" things. But with UAC off there shouldn't be a problem.
PS: Flecko just said it (thanks)
pistollero
« Reply #9 on: January 17, 2011, 05:25:43 pm »
hi Peter, but my question is:
is there any problem running the XXHE without setting it to admnistrator??
« Reply #10 on: January 17, 2011, 05:41:17 pm »
With UAC being On ? yes, all over the place.
