November 23, 2024, 12:13:16 pm *
Author Topic: XXHE large files problem  (Read 9397 times)
pistollero
« on: January 16, 2011, 05:39:59 pm »
I every one!! iīve been testing the demo version but i canīt play files from podcasts in mp3 that have 50 minutes...
simple does not play. any one have the same problem?????
i like the sound a lot and iīm considering buy the player but i need to play larger files....
can anyone helpme??? tks  Wink
Windows 7 home premium 64bit SP1 / asus n61v laptop / Engine#3 / Dev.Buffer = 1024 /*ClockRes = no*/Straight Contiguous/*SFS = 240*/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 /-> audiophilleo2 -> dacmagic DAC -> active adam audio A8X monitors
« Reply #1 on: January 16, 2011, 05:56:21 pm »
Hi there, and welcome !
Ok, you imply that a smaller MP3 does work, right ? Now, find one of e.g. 10 minutes, and notice what time it takes on your system before it starts playing. When 10 minutes indeed, your 50 minute podcast should take 5 times longer than that before it starts playing.
So ... I can't tell how long it will take on your system, but did you wait long enough ?
I don't know of any reason otherwise at this moment.
Let me know !
pistollero
« Reply #2 on: January 16, 2011, 07:01:00 pm »
ok iīve tested a music with 8 minutes and it takes about 8 to 10 seconds to play. then a played a mp3 with 70 minutes...
and about 50 seconds... apear the logo thak says the bit rate (in this case - 160 mp3) but.... after that a still donīt ear nothing...
is very strange...  first i though that was the demo version... but than i realised not.
than i tried a mp3 file with 32 minutes and it played. than i tried another with 37 minutes and does nīt played...
so i think i canīt play music with more than 30 minutes....
my config  is a asus n61 laptop>spdf optical>dac> amplified monitores
« Reply #3 on: January 16, 2011, 07:15:25 pm »
Ok, thanks. I will try to find a larger file myself and try.
In any case, this is not on purpose, nor was it known ...
I'll let you know when I know more.
pistollero
« Reply #4 on: January 16, 2011, 07:24:55 pm »
in respect to sound it sounds perfect... and iīm doing some comparative test with j river... and i think the sound of  XXHE is
better but i canīt say why... the j river is playing wasapi.
« Reply #5 on: January 16, 2011, 07:47:26 pm »
Hi
I nodiced that sometimes i have to push 2 time's on the play button when playing large mp3 file's. And indeed it take's long before playback starts...
« Reply #6 on: January 16, 2011, 07:48:50 pm »
Hey ... but *that* I recognize too !
Can it be that ?
(sorry, I hardly ever play MP3s)
« Reply #7 on: March 22, 2011, 08:33:50 am »
Just to let you know : this will be solved for 0.9z-5.
Not 100% sure because I don't have these large files plus it depends a bit on combinations of things. So please test it once 0.9z-5 is there.
Page created in 0.081 seconds with 19 queries.
