April 06, 2025, 11:49:48 pm *
Pages: 1 [2] 3  All
Author Topic: Questions on EAC  (Read 47135 times)
Boggie
« Reply #15 on: August 07, 2007, 10:12:17 pm »
Hi Chris,
In case of Cache issue i completely agree. I have all the CD/DVD Devices checked and configured properly, and i use the EAC Profiles for reading. The only thing i used to change, was that i didn't leave it to my DVD device to report C2 Errors, i unchecked only that thing against EAC's proposition.
My problem is that I don't feel all files with so called "Track Quality 100%" read by different devices sound the same. One of the promising things of PC/Hifi seemed to be having my music bit-by-bit at least on the HDD.
Now even *that* seems to be compromised or at least reeeaaally difficult. Earlier on in this thread I also learned, that EAC saying "Track Quality 100%" doesn't necessarily mean i've got all my music absolutely right, running through the EAC-FAQ then confirmed that it's more of an "how easy was the reading process of this cd" than a real statement about having bitperfect copies.  grazy
What is or who can give a statement on what we have on HDD then? scratching
Very well possible that i misunderstood Peters post, but i thought he was even questioning the "simple" bitcomparation tools. At that point i would have to set up EAC best i can and simply live with the results instead of wearing an all-day smile because of my bitperfect copies...
That is acceptable at least, but in the beginning it all started with that "perfect" attitude... Grin
So, do you feel that it's not a problem if you read your CDs with different devices and speeds?
Do you think bitcomparing is obsolete or does it tell everything about the track?
Really having to listen to the reading results of different devices is a thing i preferably wouldn't want to do.
One step ahead of fumbling with tonearms, vtas and cartridges - and back again... nea
Boggie
EAC secure -> Win2000 SP4 -> USB -> M-Audio USB Audiophile DAC
EAC secure -> Win2000 SP4 -> PCI -> Audigy 2ZS (KXproject Drivers)
« Reply #16 on: August 08, 2007, 12:27:36 am »
Boggie, no ...
Maybe I'm a bit short of time to respond to everything, but let's start with the comparing thing anyway ...
The reason I said it's not easy, was from my perspective of having a "raw" file comparer tool, that's not intelligent.
With the latter I mean that it should leave out the leading (and trailing) bytes, which already would be off because of the CDRom drive not being able to find the exact beginning of the track. Or better, you may have not calibrated it for that (which by itself is a feature of EAC, but which might fail because it needs reference CDs you might not have). So, if the first 100 bytes are off, and the comparer is not inteligent, all will be off.
If you compare the things yourself like with WaveLab, you'd have to find the common denominator of the start, and chop off the bytes from the track that has the additional bytes. For more complicated looking waves it can turn out to be undoable.
So that's what I meant. And I don't know about the bit comparer from Foobar. It might be "intelligent".
Btw Chris, thanks for pointing out the ToolTips. I was already wondering how I came to my choices myself (a few years ago), today not understanding the plain labels on the form. The means of arranging for it all looks still strange to me, but ok ...
Anyway, yes, it is ridiculous that we can't seem to read audio from a CD error free, but that's life for now. Btw, there was a thread on bd-design once where all this was worked out to some extend, and although this thread has been deleted by the owner, I still have it myself, and there sure are means to improve the reliability. I have to make something for it though, and somehow I can't do everything at the same time. no
My conclusion for today in that thread was : If you have the opportunity to have two drives and both calibrate them properly, and they both always produce the same data, you're okay with either drive. BUT, you'd have to be very careful in watching the performance of the drive you use; Once the performance degrades (gerenally : it takes longer to rip), do the comparison with the other drive again. You *will* be behind things though, because you'll always decide to check when you ripped several CDs wrongly. But it's a means ...
Oh, and please note that with more poor CDs there's hardly a chance that both drives will read the same data. So on that matter ... have three drives.
Quite awkward ...
The least you will have relatively soon is a means from within XX to check the tracks on "realistic audio data" ... I could say, that if you just can hear the difference from two different rips, 100% sure my checking for realistic audio data will come up with something.
Generally spoken "that you can immediatly hear the difference" would be rare. Or maybe not, but don't make too much fuzz about it until yuo just have proven it (somehow) to yourself.
Oh, and to be clear on things : once the track is on the HDD, it can't be readout wrongly (better : differently) from there.
Even if the CD/DVD Drive supports C2 Error detection, i used to uncheck the option because i *want* EAC
to re-read the data and look for these errors.
Looking the way EAC is setup (or presented) this might not be a bad approach. I mean, look how the procedure goes (or how it comes to me) :
You can check the box for "drive supports CRC", and in some later stage you can upload the "findings" from your drive to whereever it is for the next person. So you judge or do wrong, and the next one is in trouble.
As a sidenote, I mention that the best means of ripping (which is not necessarily "insane" mode), often is undoable. I mean, the rip of one CD could take hours and hours, just because EAC wants to make something of something that will fail anyway. Never noticed it ? as soon as it takes 10 minutes to read 5 seconds, you will have a glitch, no matter what. Solution ? rip less secure, so you'd at least have ripped 30 CDs for the night ...
nea
Actually it all IMHO s*cks. No matter how good intentions are.
Might it help somewhat for now : Plextors always have been the best.
Boggie
« Reply #17 on: August 09, 2007, 01:03:08 am »
Phew,  Happy
thanks for the reply Peter, a number of questions has been answered now...
Having comparable Wav Files on HDD which can't be readout wrongly is some good point to start from! clapping
I don't know how "intelligent" the foo_bitcompare is, but i didn't have to alter or find anything in the music files manually and i still was able to produce some tons of files which seem to be identical, as the tool says, though i used all-brakes-on secure mode as well as e.g. burst mode test & copy.
Seems to work, another good thing then.  Happy
So, for now I'll just keep an eye on my Plextor and give the guy something to do.
Thanks again,
Boggie
« Reply #18 on: February 12, 2008, 03:19:49 pm »
(If i remember correctly) there was a day that you wrote .. That there could be 100 things that can and will go wrong even ripping with EAC. (cannot find the post  at the moment)
Why than use EAC and not b.v. MediaMonkey... ?  Meaning that long reading in EAC wil result in glitches but when i do it in MM it wil not give these glitches.  And when i have a "bad" cd now i don't rip it further.
Grtzzz
andy74
« Reply #19 on: February 12, 2008, 03:22:55 pm »
Ava12
Headphone Audiophile
« Reply #20 on: February 12, 2008, 04:27:14 pm »
Or PlexTools Professional if you have a Plextor drive?
« Reply #21 on: February 12, 2008, 04:28:43 pm »
no nea
Ava12
« Reply #22 on: February 12, 2008, 04:41:30 pm »
Öhm, ok scratching
Thanx^^
that's clear now Wink
« Reply #23 on: February 12, 2008, 05:13:34 pm »
Öhm, ok scratching
Thanx^^
Haha
Sorry had to leave and did the answer a bit quick....  unhappy Wink
I Have a Nec if am correct... Next will be a Plextor if that is one of the best for audio ripping?
grtz
Ava12
« Reply #24 on: February 12, 2008, 05:28:28 pm »
I hope so. I recently got a Plextor Premium 2 and I can say that it is good.
It burns CD with less Jitter. But I sadly can't proof if it is very good at ripping. I just ripped my CD collection again with it. But I've no tool to verify my wavs.
So can't answer it.
I mainly got it to burn nice CDs with MFSL Ultradiscs and AMQR and all those things this draive supports.
« Reply #25 on: February 12, 2008, 05:38:17 pm »
So can't answer it.
Ok... Happy
I will remember that.... And ask you again when i am ready for it....
Thanx... Happy
soundcheck
« Reply #26 on: February 13, 2008, 01:29:02 pm »
Hi folks.
I'd recomend to use Acuraterip.(A feature within EAC)
You need to set the right drive-offset of course. You can rip at much higher speeds.
You'll get a checksum verification afterwards. This makes sure that the rip is OK.
80% of all my  discs do deliver 100% results. That saves hell lot of time.
A program I actually prefer over EAC is dbpoweramp.
Klaus
« Reply #27 on: February 13, 2008, 02:45:26 pm »
Hi folks.
Klaus
Hi Klaus,
Why do you prefer this?  Happy
And i would like to say that the new Mediamonkey has a rip possibility with a Jitter correction function ( Whatever they mean by that? ).
Grtz....
soundcheck
« Reply #28 on: February 13, 2008, 03:01:01 pm »
They have much better integrated  security features. I also think they have a much nicer UI.
MediaMonkey:
What kind of jitter reduction is that supposed to be? The only time you'll get jitter on the CD is while
you record it or if you do realtime playback from CD.
There is no jitter involved while you write the data to a file.
« Reply #29 on: February 13, 2008, 03:27:12 pm »
MediaMonkey:
Well i think they mixed up a few things and named it wrong... When EAC found a bad spot on a cd they find it also but than they say that they found several Jitter mistakes and that probably the audio data is damaged.
Grtz
Pages: 1 [2] 3  All
