November 23, 2024, 08:35:36 am *
Author Topic: Need help for best route to Benchmark DAC1 Pre  (Read 7911 times)
praphan
« on: January 03, 2011, 05:59:25 pm »
Hello all,
Does anyone has any experience running XXHE on Benchmark DAC 1 Pre? I usually feed my Benchmark with digital signal (coax) from Oppo DVD player. I tried switching the player input to XX using stock USB cable. Lots of hiccup and stop interval. Then I tried SPDIF (coax) output from HT Omega game soundcard to DAC. Did not work eventhough I checked 24 bit only in the DAC setting area of XX.
Do I need interface like Hiface or similar to run XX to Benchmark?
Appreciate you help.
Thanks in advance.
Praphan
Flecko
« Reply #1 on: January 04, 2011, 02:51:31 pm »
Try ThreadPrio = realtime and PlayerPrio = low. It should work without problems. tell me if it not. And if it works... how does the oppo compare to xx?
praphan
« Reply #2 on: January 04, 2011, 05:01:06 pm »
Thanks a lot Flecko. It works fine with your recommended setting.
As to Oppo digital out vs XX, uhmmm very good questions. I haven't got a chance to do the A-B test a lot. I used Benchmark in my bedroom while XX is in a dedicated listening room (XX to Berkeley Alpha DAC) . I will do the A-B comparison and report back later.
Thanks again.
Praphan
Flecko
« Reply #3 on: January 04, 2011, 05:13:05 pm »
Great!
Oppo against lynx would also or even more interesting. Thanks a lot!
