April 08, 2025, 06:24:17 pm *
Author Topic: Where can I see/learn more about this DAC  (Read 34145 times)
Par
« Reply #15 on: February 16, 2011, 12:29:08 pm »
tks for your answer!
It doesnt come with PCIe but Im considering removing the AE card and replace with PCIe card.
Since the Phasure can work as preamp and Id like to keep box count to a minimum thats the reason for the HP drivability, but
HP capability isnt a dealbreaker so Id be happy to recieve the specs.
Cheers P
digital
« Reply #16 on: February 17, 2011, 12:52:28 pm »
What kind of motherboard holds the "soundcard"
Sincerely
« Reply #17 on: February 17, 2011, 12:56:15 pm »
None ?
It's at the end of a PCIe interface.
digital
« Reply #18 on: February 17, 2011, 02:19:30 pm »
Thanks alot. I just thought it looked like a small motherboard of some sort.
Can you provide some more information regarding this pcie extender solution?
Sincerely
« Reply #19 on: February 17, 2011, 02:50:58 pm »
It extends the PCI slot to inside the DAC. But I guess you knew that.
But nothing more to say I'm afraid. Happy
digital
« Reply #20 on: February 18, 2011, 12:52:10 pm »
Thanks for quick answer. Quite clever it seems.
So this dac is basically a soundcard extender for the pc.?
Where it taps I2S from Juli@ soundcard (a modification har to be made there)  - reclocks it and sends the i2s signal to the pcm1704 based dac?
I just had to understand its basics. Hope I will have the chance to listen to it once.
Thanks again for your answer.
Best regards.
« Reply #21 on: February 18, 2011, 01:15:24 pm »
There's a little much more to it, but basically, yes.
Try to make that every night. Haha.
