November 22, 2024, 03:04:01 pm *
Pages: 1 [2] 3 4  All
Author Topic: And then there was W7 SP1 (RC) ...  (Read 62995 times)
« Reply #15 on: December 29, 2010, 11:51:35 am »
Windows X, I certainly agree with the latter you told. We could also say, at last I agree with something you say. But before this is judged as super positive, this doesn't imply that Marcin or anyone should stop with exploring *that* or any other means which in my book can have lower priorities. In the end it is not much different from what I say myself about a DAC etc. etc., or that tweaking software is far less efficient than tweaking hardware (at DAC level) where possible. I know, this may be a discussion within itself, but we also must take into account that not everybody is able to "tweak" at the level e.g. I can. Or you with a relative good DAC and again relative poor software which destroys.
But I beg you, stop talking about the impossibilities of the software side, no matter you are right or not. And especially stop repeating your statement about it. We know it now, and some may be with you while others are not. Your point is well made, and by now it only comes over as non-constructive, while we want to be on the constructive side of the matters.
I will allow myself to delete posts which only contain repetetive data (you may have learned why I don't talk about "information") which in the mean time look destructive to me. Or for what we are trying to achieve here.
I am sure you will understand.
« Reply #16 on: December 29, 2010, 12:15:49 pm »
Played Ambient as well as a few other genres. All at 64 samples of internal latency (512 device's) and heard no single click or tick.
Does this also means Peter that you need to set the Latency from the soundcard to 512? Or can that stay at 2048?
« Reply #17 on: December 29, 2010, 01:01:46 pm »
Must be set to 512 (and Q1 = 1).
Btw, notice that this settings is just my former setting for Special Mode. I know I can go lower now, but don't want to compare apples with oranges at this time.
« Reply #18 on: December 29, 2010, 01:07:36 pm »
Yes i understand that it is your Special Mode setting.  Happy I just wanted to be sure that the buffer size must be the same as the latency on the soundcard. And than offcourse play with Q1 setting.
Never could play SM so it's a bit confussing. Tried to read the tooltips but that made it not clear to me.
« Reply #19 on: December 29, 2010, 01:18:14 pm »
Never could play SM
But can you now ?
« Reply #20 on: December 29, 2010, 01:23:33 pm »
Never could play SM
But can you now ?
Yes i can even very low latency.  Happy
Flecko
« Reply #21 on: December 29, 2010, 01:43:57 pm »
....There is such a naturalness, and what I didn't dare say earlier in response to Mani's first listening experience with the NOS1 : I guess this brings exactly what might be lacking when listening to Vista. It can always go deeper, and it can always go "brown café" browner" (we call a "brown café a cosey bar with not too much light and damn good atmosphere and music)....
I know what you mean and what you are talking about. I hear that too but to be honest, that is what W7 always sounded like. I now heard the differnces between Vista and W7. They were there but it was still not a question of absolute quality. More a matter of taste, music and mood. Some things were better with vista and some were better with w7. And that was without SP1. If there is a difference from w7 to w7sp1, it is small. Same sound character as before. Clean and transparent. I appreciate, that you like to develope on W7 again. But maybe we could agree, to use a more neutral language to describe what we hear. We have no reference hardware and music to what we can compare. Nobody realy knows what is going on and what makes the difference. It is kind of going round in a circles. One day you like one side of the circle and next day the other. Than you go to the other side and it sounds great. You hear, what you have missed all the time but it is still the same circle.
« Reply #22 on: December 29, 2010, 02:23:15 pm »
I sure tend to agree with that. But there's a difference between something you missed (mainly the bass in this case) and something which disturbs all the time. For Vista this is a too "weak" bass to my likings and for Native W7 this is the roughness (the On/Off thing). From both it is fairly easy to decide for Vista.
Now with W7 SP1 the disturbing roughness is not there. This logically makes the decision towards W7 SP1.
But as said, I may come back on it. Didn't adjust my sig yet either ...
Marcin_gps
« Reply #23 on: December 29, 2010, 02:59:20 pm »
Adrian, your DAC must be jitter-resistant if you're saying that there is a small difference between W7 and W7 Sp1 or you have to have sth wrong in your system. I don't even need to listen to it, the difference is so obvious.
Flecko
« Reply #24 on: December 29, 2010, 05:00:37 pm »
My DAC has a DSP that uses some sort of parallel processing. According to Kingwa, in theory this should reduce jitter to 0. But of course in the real world, it is not like this. Maybe because of this,  I am  not as sensitive to hear some sort of things. But differences in the settings of xx I can hear.
I just try to be care full...
[ BTW... I will upgrade my digital source Happy order is out!]
Flecko
« Reply #25 on: December 29, 2010, 05:08:33 pm »
It can be, that this is better with w7. I can not do A/B testing because I installed SP1 over my former W7. But this roughness you mentioned...since z3, I have the problem that it doesn't sound as relaxed as with z2. z3 gives more details and is overall better but I can never forget about it, like I could do with z2. This roughness in my case, has something to do with sfs.ini. With 10, it seems that the sound has become more enjoyable than with 01 (man this is confusing...). How does the roughness change if you use 10 in your current system?
« Reply #26 on: December 29, 2010, 05:57:49 pm »
I didn't try that yet, but have a fresh Native W7 waiting. I have so few time ...
Josef
« Reply #27 on: December 30, 2010, 01:27:08 am »
Installing 'raw' W7 is the best way to really appreciate how much SP1 RC improves on things.
'Normal' W7 (Windows Update turned on) already contains a number of fixes so difference is less...
Flecko
« Reply #28 on: December 30, 2010, 12:59:19 pm »
Yep, that is true. SP1 is a collection of updates according to Microsoft.
« Reply #29 on: December 30, 2010, 07:52:11 pm »
I "hear" the updates here too.
Not installed SP1 RC1 yet !
