November 23, 2024, 08:43:56 am *
Author Topic: cannot select Engine#4 with Lynx new driver (WaveRT support)  (Read 4961 times)
didierG
« on: December 21, 2010, 04:18:48 pm »
Hi Peter
After installing the new driver for the Lynx AES16e sound card on Vista (Build 18j Beta, which brings support for WaveRT) , the KS: drivers are not longer available in XXHighEnd (neither in foobar), whereas it worked with the previous Lynx Driver. I can use the installed driver with Engine#3 only.
Do you think that Engine#4 should work with WaveRT drivers, or that there is something wrong in the Lynx installation which prevent me from using the KS: drivers ?
Kind regards
Didier
« Reply #1 on: December 22, 2010, 09:50:55 am »
Hello Didier,
I'm afraid that if nothing shows from the Kernel Streaming driver(s), it's just not supported anymore by Lynx. Nothing to do about that I guess (but use older ones Happy).
Kernel Streaming doesn't particulalrly use "devices" hence it never has been official. That is why you don't see them in the normal devices list (Vista/W7) anywhere. So, that list with KS: devices is created by myself. The other way around : there is no such thing as "KS being able to make use of any other device you see". I know you said (WaveRT) "drivers" but even that is no formal thing for KS. It's a fairly complex enumaration consisting of diverse steps, and you end up with something which will make sound. Happy Hard to explain ...
