November 23, 2024, 03:48:22 am *
Author Topic: Phasure NOS 1 Questions  (Read 32233 times)
« Reply #15 on: December 28, 2010, 11:58:25 am »
Of course ...
« Reply #16 on: December 28, 2010, 01:44:59 pm »
If this is the correct speed, I will eat my hat. Actually, it will be easy to check - I think 2NL have the same Beethoven track at lower res.
I've just tried this and indeed native DXD tracks from 2L definitely play at half speed with 0.9z-3... so I won't have to eat my hat Happy
Would be nice to get this sorted in 0.9z-4.
« Reply #17 on: December 29, 2010, 01:34:54 pm »
I have something strange going on. You now the moment that i had you on the phone about one speaker not working. You said that the first switch needed to be set to on (down) And that the MON setting must be on. Well if i would like to play 352800 the only way i can make it work is if i push the switch OFF (Up) I think it works on 352800. There are no message's that it do not.
So set the switch to on i can play but only one speaker is giving sound. No matter what i do with Julia.
I have IS Phasure NOS1 384 set to on. Also tried it with off.
 dntknw
EDIT: It happened after i tried foobar. Pushed XX off and than switch to up and tried to play with foobar witch i could not get to work. After that switch down does not work.
« Reply #18 on: December 29, 2010, 02:27:01 pm »
I can imagine this ...
The only thing I know is that it rarely happens that a reboot is needed to get the second channel to work. I never realized that this could be related to another player a sort of "occupying" the device. But it sure can be (I think).
But I guess you will be allright after a reboot.
« Reply #19 on: December 29, 2010, 03:36:58 pm »
Just tried it with Vista. No problem there. So back to W7 there again only one channel. So i did a reinstall of the Juli@ driver. After that again no sound on one channel. So i tried XX on the SSD and not the one on Ramdisk. That one worked!!
After deleting XX on Ramdisk and put a fresh one on it there was no problem!  wacko
« Reply #20 on: December 29, 2010, 05:55:01 pm »
Gerard, I think it was you were similar happened ... you are confusing yourself with starting from RAMDisk and not. Both use their own configurations ... (Settings).
« Reply #21 on: January 09, 2011, 06:10:45 pm »
Hello Peter,
I'm crying into a big towel since last night.
Explanations step by step
A) the first installation of the Julio@ to the PC was a piece of cake, VISTA recognized the PCIe bridge etc.
B) I had to disconnect  all cables from the PC for a  move in the room yesterday.
C) All cables connected again, the Juli@ card was not recognized. (Code 10)
D) Installed the PCIe card in the second socket of the motherboard. Same result.
E) Swichted from VISTA SP1 to W7 SP1 today. Same result.
F) Installed the PCIe card in the first socket again. Same result.
Now I'm back to Minerva and the magic is gone!
There are four possibilities for a malfunction:
1) Motherboard defect.
2) PCIe card defect.
3) Sound card in the NOS1 out of order.
4) DVI cable defect.
Any idea?
Best
« Reply #22 on: January 09, 2011, 07:57:17 pm »
Hi Joachim - I am preparing an email for you with some ideas ...
« Reply #23 on: January 10, 2011, 08:19:53 pm »
Any idea?
Try a system restore.
