November 23, 2024, 04:05:10 am *
Author Topic: Phasure NOS 1 Questions  (Read 32239 times)
« on: December 19, 2010, 06:23:34 pm »
Few questions.
1: Can you explain further about the On\Off thing. You wrote about it but it is not quit clear enough. If i remember correct you also mention it in relation with te warranty. I alway's turn everything off just for my good feeling that is. (Fire when i am not home or in bed)
Does the Off setting harm the dac? Meaning are parts warn out sooner?
2: When i push the On\Off button Off the red light next to the connector stay's on. Not quit as bright as when the button is on but still the light is red.
3: The latency in the Julia Console is at 256 at the moment. Is that the correct setting? what do you use?
Thanx  Happy
« Reply #1 on: December 19, 2010, 09:18:30 pm »
This tells me the PC is still On ? ... which is not allowed. That is, it is not allowed to switch off the DAC when the PC is still On. You can perfectly boot the PC without the DAC being On though.
Anyway ... what you see from the red light is the small voltage which is on the PCIe buss. This is just how the light (led) is connected, and harmless.
The latency ... Well, there is no such thing as a correct setting. It is the same as all the stories you read in here and very personal I guess.
I myself use 2048 (and Q1 = 1) with KS Adaptive Mode. For KS Special Mode I always used 512 and Q1 = 64. The latter was merely because I couldn't go lower (for 384) while now I can. But I never really examined it for SQ, plus I never liked Special Mode. That may be a matter of finding the right settings though.
Not much help, but hopefully sufficient for now. Happy
« Reply #2 on: December 19, 2010, 09:32:35 pm »
Ok.
The latency in XX i understand but this question was about the latency in the Julia console. The one where i had to push MON.
You forgot my number one question.
 Wink
« Reply #3 on: December 19, 2010, 09:58:19 pm »
It was answered by #2. scratching Otherwise I have nothing to add ... (but read the "guide" about it).
That's what I answered to ... scratchingscratching (but don't get confused by me mentioning Q1 also ... because that's related).
I am now starting with your "quadrupule", but as you know I have only one. How many did you have ? hahaha
« Reply #4 on: December 19, 2010, 10:30:15 pm »
Yes i see it now. Thanx sorry
« Reply #5 on: December 19, 2010, 10:52:49 pm »
If you're only serious with that. When not, try to ask more direct questions ... I mean, there's not much use in copying the text from the guide, but whether that is clear enough ? ...
This is why you are a trial for just that (the guide). prankster
« Reply #6 on: December 19, 2010, 10:58:58 pm »
Did not want to bother you further. But ok what will (can) happen when a mistake is made? And why is it ok during a boot and not when it is on?
quadrupule.... Haha answer as quick as possible than. (Btw that explains a lot you allready had the dubbel)  rofl
« Reply #7 on: December 20, 2010, 12:12:44 am »
I don't understand ... ?
Nothing much. But or the DAC won't be availale, or the PC may hang.
« Reply #8 on: December 27, 2010, 11:55:47 am »
Peter had 4 tracks provided by 2NL (i think), I chose a sonata of Beethoven and we played it... it showed the true potential of the DAC, but it also showed a bug in the software that played it at HALF SPEED :D
Peter, I'm assuming this is an easy fix, no? I know there are only a handful of native DXD tracks around, but from a marketing point of view, I think it would be good if the the NOS1 could play them back correctly.
And as Telstar intimated in quoted post, they should sound spectacular through the NOS1.
« Reply #9 on: December 27, 2010, 12:41:27 pm »
I think this was fixed for 0.9z-3 ?
I can't be sure though, because I planned 0.9z-4 before the first NOS1 deliveries and that didn't happen. In any case it is solved here (and it is not in the 0.9z-3 release notes).
Did you try it ?
Leo
« Reply #10 on: December 27, 2010, 12:43:56 pm »
I tried a 2L 384 file
and it works
at the right speed
I think
Leo
« Reply #11 on: December 27, 2010, 01:25:42 pm »
Hey Leo, when it appears to be not so, you are not to be blamed. It took me 10 minutes to be fairly sure, next it took 20 minutes to convince Telstar (who wanted to be 100% sure and clocked it -> 20 minutes for a 10 minute track isn't quite right), and next fooled Roy by telling we had a nice track to listen to. With violins it should be fairly easy, but with the piano (-only) piece, it's difficult.
« Reply #12 on: December 27, 2010, 02:05:36 pm »
Yes, I've tried it. If this is the correct speed, I will eat my hat. Actually, it will be easy to check - I think 2NL have the same Beethoven track at lower res.
Mani
« Reply #13 on: December 27, 2010, 08:59:26 pm »
and next TRIED to fool Roy, haha Tongue
It sounded very good at half-speed because the higher notes were not there (well not as "normally" being distorded)
Thats why RAMDisk is so great, its makes de higher piano notes much cleaner.
2c
I hope you all enjoy nos1....... (with 16/44 material)
« Reply #14 on: December 28, 2010, 10:21:44 am »
Pedal said he loaded a full playlist to speed up te burning time that is needed. Is it ok to push the main amps off during playback?
