April 06, 2025, 11:59:50 pm *
Author Topic: 0.9z-3 - "naming" bug when using the A-B repeat function  (Read 5409 times)
« on: December 08, 2010, 02:27:35 pm »
G'day Peter, it's the bug hunter from down under here Happy
There appears to be a "naming" glitch when using the A-B repeat function in unattended mode.
Load up a track and let it play in unattended mode for a while then go back to the GUI with Alt-X and stop playback. (or just let it complete and allow the GUI to come up normally).
Clear the playlist.
Load up another ( different ) track.
Click on the A button to activate it.
Move the slider along ( 20 seconds will do ), then click on the B button to activate it.
Click on PLAY.
When the GUI disappears and the coverart appears, the ALBUM & TRACK names from that previous track you played are written on the coverart rather that the actual track playing. The correct coverart is shown.
I have tested this several times and the bug is consistent.
If you then disable the A-B repeat function and press PLAY again the ALBUM/TRACK name is then correct ( until the next time you use the A-B repeat).
I looked through the release notes for 0.9z-3 to see if this issue was mentioned and perhaps item 2 in the Known Major issues covers it, but thought I'd mention it in case it didn't.
« Reply #1 on: December 08, 2010, 02:47:07 pm »
Thank you Russ. I have seen this myself, and let it be (for now) on purpose. It may be "an" indication you left on A-B. I mean, I once have been thinking and thinking what could be wrong a "track part" suddenly repeated, while actually it is was an old A-B set. And, along with that goes the Wallpaper not being "refreshed".
Do I have stupid arguments or do I ?
yes
It may even be not easy to solve ...
