Josef
« on: December 05, 2010, 05:40:22 pm » |
I was rather ill past couple days and had to stay in bed... As I had nothing better to do I played with jplay and to my complete surprise found couple more things that apparently no other PC player is doing at the moment so I decided to try them out and see if they made a difference... Attached is small Sunday gift to everyone: 'New & improved' jplay but this time in _both_] 32 & 64-bit native versions. Oh, yeah - some people claim that native 64 sounds better! (Ah - It was about time for another controversy!  ) But hey, talk is cheap, so if you have Win7 64 or Vista 64 (=recommended) now you can try both versions yourself - Just like with previous experiment they are completely identical! (in terms of source code, of course). Those with 32-bit OS won't be able to run 64-bit version and test this - sorry. Nevertheless, please do give 32-bit version a try - you just might find it worth your while... Just unzip proper package for your OS, copy your WAVs in same folder and type 'play' from command prompt OR, simply double-click play.bat Again, please share your thoughts & have fun!
Marcin_gps
« Reply #1 on: December 05, 2010, 05:59:27 pm » |
At this stage I'm sure that 64-bit sounds better than XXHE in any configuration. Sorry Peter, but if you implement Josef's memory management and force 1ms timer, things might be totally different. Can't wait to hear it. Great times are coming for pc audio  Cheers, Marcin
« Reply #2 on: December 05, 2010, 07:42:31 pm » |
Hi Josef, I do not get your player to play. I have done what you asked (d) but still i get message (s) Any idears?  Thanx
goon-heaven
« Reply #3 on: December 05, 2010, 07:47:26 pm » |
Thank you Josef - I hear excellent dynamics, more emotion and still that super clean music on your 64bit JControversy!
I wish you a speedy recovery.
7Ultimate 64bit on Patriot Torq 128 SSD, XX on 2Gb RAMDisk, music on NAS, i7-860 HT Off / Engine#4 Special Mode / Q1/2/3/4/5 = 1(32 samples)/0/0/0/0 Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 Attended / FileSplit 1Gb / -> LynxTWO-B buffer size 32 -> EmmLabs DCC2 SE
« Reply #4 on: December 05, 2010, 08:29:45 pm » |
Gerard - Try this right after a reboot. Or did you already ? Otherwise your memory is too fragmented to allow for the large chunks which are allocated (and do the trick). Josef, great stuff. I hope I can keep up ! (spending more on the "DAC" emails I receive than I anticipated upon  ).
« Reply #5 on: December 05, 2010, 08:34:35 pm » |
Gerard - Try this right after a reboot. Or did you already ? Otherwise your memory is too fragmented to allow for the large chunks which are allocated (and do the trick). Josef, great stuff. I hope I can keep up ! (spending more on the "DAC" emails I receive than I anticipated upon  ). I did reboot but it does not work Will try my music pc tomorrow.
« Reply #6 on: December 05, 2010, 08:38:01 pm » |
(spending more on the "DAC" emails I receive than I anticipated upon  ). If it goes on like this the dac will be sold out before you can blink your eyes!!
Josef
« Reply #7 on: December 05, 2010, 08:46:02 pm » |
Hi Josef, I do not get your player to play. I have done what you asked (d) but still i get message (s) Any idears?  Thanx Hi Gerard - Can you double-click 'Lock Pages in memory' (uh, what was that in Dutch again?  ) and send THAT screenshot? (you should be listed there) Also - do you have enough RAM i.e. did you maybe make a HUUGE Ramdisk? If so, try making it smaller!
Josef
« Reply #8 on: December 05, 2010, 09:12:56 pm » |
Marcin wrote: At this stage I'm sure that 64-bit sounds better than XXHE in any configuration. Goon-heaven wrote: Thank you Josef - I hear excellent dynamics, more emotion and still that super clean music on your 64bit JControversy! Peter wrote: Josef, great stuff. I hope I can keep up ! Wow - thanks guys! I implemented these latest findings just yesterday and have not slept at all last night: it may sound crazy (well, it IS crazy) but I just couldn't get myself to stop listening! I thought I had too much wine (again  ) so your fantastic feedback is mucho appreciated! Enjoy the music!
« Reply #9 on: December 05, 2010, 09:54:23 pm » |
I have been trying Jplay 1,2 and Deux (32 bit) but not having much luck. When I first tried I was getting an error saying JPlay could not register my sound device (a HiFace) but after switching windows audio back on this went away. Now when I play (trying with JPaly1 so that memory config is not a factor) I get a message saying the JPlay is playing the WAV file but unfortunately no sound.
I guess the program is using the Vista default sound device, I was thinking a vanilla Vista install my help, has anyone got JPlay working with a HiFace so far.
I would really like to give this a go as the results sound very interesting, any thoughts ? Nick.
« Reply #10 on: December 05, 2010, 11:09:35 pm » |
Wow - thanks guys! Well, let me add my bit. It sounds really, really nice. The low-level detail is quite astonishing. Well done! Mani PS. Latest listening done with 64-bit version. PPS. It still doesn't like being installed and being run from my RAMDisk...
« Reply #11 on: December 05, 2010, 11:22:30 pm » |
It works here with the hiface, the 32 bit latest version. I haven't tried the earlier versions. Had to get the right username, which took a couple of tries cause I assumed that my administrator designated username would be the correct one, but it wasn't.....Anyway I was surprised when it worked that it set the buffer size with the hiface to 1024: The sound is very good "WASAPI sound" but it lacks the fullness of the lower mids and upper base that I get with XX kernel streaming. Is it being offered as an experiment for memory usage in xx or as an alternative to xx or both? Just wondering........
Josef
« Reply #12 on: December 05, 2010, 11:24:04 pm » |
Nick - What do see when you right-click your 'loudspeaker' icon in taskbar and select 'Playback Devices'? Is Hi-Face labeled as 'Default'? If not, right-click and say 'Set as default'. See Capture1. If it is, click 'Advanced' and make sure sampling freq is set to 44,100 (does not matter if it's 16 or 24 bits) See Capture2. EDIT - Also see if 44.1 is checked as 'Supported Format' - Capture3 Let us know what you find!
Josef
« Reply #13 on: December 05, 2010, 11:29:09 pm » |
.....Anyway I was surprised when it worked that it set the buffer size with the hiface to 1024: Surprised in what way?  If you'd like to change buffer size simply type jplay (from command prompt) and then edit play.bat accordingly - seems it can go down to 128 on my Vista 64 setup....
« Reply #14 on: December 05, 2010, 11:57:18 pm » |
Will give it a try, but I thought that the hiface was limited to a buffer size of 2048?.
Does anyone else find that japlay, though very crisp, clear, and beatiful sounding lacks the lower end "fullness" of XXkernel streaming. Its that fullness that makes xx kernel streaming sound so organic, especially with the lone female voice. My findings were confirmed with the wife test, the true litmus in my livingroom!
